I have a toshiba_42av635d and when i press the power button in it clicks at its going to come on but most of the time the swtch makes a crackling noise then it goes off. sometimes the tv then does come on. The power switch is connecting when i press the button. Is this a known issue? Thanks
  • dan123_05
    dan123_05 Dec 12, 2012
    no toshiba tvs listed
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in Timeslide or Flipcard option, which can be selected from the drop down box menu by the Sidebar tag, at the top left corner of the display window. You can also click the Home tab to see the latest updates. It will make search easier. There are more than 1400 posts to different brand TVs till now. Setup proceedings and code list to different brand remote controls also included. Pull up older posts or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Posted on Dec 12, 2012
  • The Knight
    The Knight Dec 12, 2012
    You might not have noticed. Please type in the model number to your TV in the search box at the top right portion of the display window.
  • 15 Answers
SOURCE: crackling noise from tv
That crackling noise has nothing to do with the television and everything to do with your antenna. It is merely signal breakdown, when you get signal interference with analogue tv you get snow, with digital you get little squares on the screen and/or sound breaking and cutting in and out, get a licensed antenna repairer to come out check your signal strength as you may need a booster or your antenna could just be a few degrees off....
Posted on Dec 30, 2007
SOURCE: clicking noise sony bravia kdl-40v3000
http://forum.ecoustics.com/bbs/messages/2/176039.html <-- Check that out.
Also I have a Sony Bravia and it clicks while it is on as well. I read that forum and some people said to disconnect the cable box for 10 sec. and then some said it was the heat from the summer.. i don't know.. I just turned my tv off and then back on and it stoped. I read this is happening with all kinds of TVs....
Posted on May 23, 2008
  • 187 Answers
SOURCE: how to reset lg lcd tv
Whe you press the power button the TV led have to blink several times and the it have to change to blue, meaning Tv is on.
If you press the power button and the led start blinking and goes off, then you need to replace the mainboard because it is damaged.
Bye
Posted on May 27, 2009
  • 325 Answers
SOURCE: i need the sky+ remote codes for my toshiba
please follow the steps below:
TV
RED + SELECT
TV
0156
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
Please leave a thumbs up when this sorts you out. cheers
Little Dish Fitter
Posted on Sep 29, 2009
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
How to go back to factory settings
All data will be erased on your hard drive if you proceed. Make sure that the power wont be interrupted during this process. Do not switch off or restart your computer either.
-Shut the computer down completely
-hold the 0 (zero) key down and at the same time press the power on button release the power when the machine turns on
-when the computer starts beeping release the 0 key
-when the prompt comes up choose YES to continue with system recovery
-Select recover of factory default software and click NEXT
-Click Next again to start recovery
Hope this helps!
Apr 14, 2011 | Toshiba Satellite Pro L300 Notebook
I am trying to reset my toshibe m45 s165 to its factory settings, but when i try the whole press "0" and power at the same time, the laptop keeps turning off since im holding the power button,...
Do not hold the power button down while pressing the "0" key - it'll shut the computer off again. You just need to push it once to turn the power on and then hold the "0" key immediately after you push the power button on - just like turning on the laptop, but this time you're holding the "0" key down.
Feb 05, 2011 | Toshiba Satellite M45-S165 Notebook
Nokia phone 3100
following this instruction,
1.remove the white rubber ontop the power botton.
2.find a metal that can touch both edges of the tip where the power botton was removed from (positive -positive).
3.your phone will come on then you can enjoy your phone without switch botton.
Jan 11, 2010 | Nokia 3100
I need the sky+ remote codes for my toshiba 42av635d tv
TV
RED + SELECT
TV
0156
Little Dish Fitter
Sep 29, 2009 | Televison & Video
Toshiba A135 random shut downs
chect the operating system maybe some files or configuration change.. try to re install the operating system,, save first you data or make back up.. in another drive.
Jul 06, 2009 | Toshiba Satellite A135 Notebook
Cant connect new toshbia l300d to wireless says no hardware installed
press f8when the toshiba name comes on screen at start up.on the menu that appears click on restore HDD.it takes about 25 mins to complete.should be installed then
Oct 17, 2008 | Toshiba SATP L300D Notebook
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
