Question about Stanton Audio Players & Recorders
Stanton T.92 USB power problems
Just purchased and recieved the Stanton T.92 USB turntable. i connect to power and the internal fuse keeps blowing. Can you help please??
  • Stanton Master
  • 5,126 Answers
You should return it to where you purchased it from you are entitiled to either your money back or a replacement under law.
Posted on Dec 16, 2012
Noggin
  • 944 Answers
SOURCE: International Power
You have probably permanently damaged your turntable. The voltage supply in Germany is 220V AC, whereas in the US it is 110 V AC. It is just possible that all you have done is to blow a fuse in the unit, if no external fuse holders are visible then try opening up the case and looking for one near where the power cable enters the unit. If you have no luck with that then the transformer is almost certainly burnt out - this could be replaced but it is unlikely to be something you can do yourself. Please don't plug anything else that is designed for 110V into a European socket, regardless of being able to get an adaptor that will fit the socket - the voltage is different. It will almost certainly die as well and the possible risks of electric shock, fire etc. are quite significant. Hope this helps, if you want to try and get the unit repaired in Germany please ask again with details of your location and I will try and find you a reputable repair facility. If in doubt about which of your items can be plugged in in Europe then please ask as some can be switched to deal with the higher voltage, although not all. :)
Posted on Jun 25, 2007
djproaudio
  • 515 Answers
SOURCE: vestax pdx-2000mkiipro keeps blowing internal fuses
You have a short in your unit, and you will need professional assistance in determining the cause. You might also want to try a different outlet. If it fails, then you'll need to bring it to a service center for repair.
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Posted on Jul 24, 2008
SOURCE: home stereo audio problems
I've had some progress, have tried 2 different amps and 2 different mixer now... The weird thing is, if I plug a turntable directly into the receiver, everything is great.  Once I connect the record player through a mixer and then to the receiver, I can get sound, but its really bass-y and buzzy and essentially just terrible... Such a weird problem...
Posted on Oct 14, 2008
SOURCE: Stanton ST150 turntable won't spin
Hello DeKay,
I just had a spindle lock issue this past Sunday at my gig. I had the turntables out in my car and brought them in. I let then warm up for 2hrs before plugging them in.
Everything was good. Then mid set my right side turntable started spinning really fast and then DEAD STOP.
I was pushing the platter and it really hard to turn. I took off the platter and tried to turn it with my hand. It was dead locked, WTF?!!
So I limped through with one turntables since I use Traktor Scratch Pro and made it through the whole night successfully.
I searched the net and it was suggested to lubricate the 1200 spindle with 15W40 motor oil. Since the motor design is indentical, I picked up some 10W40 motor oil since I couldn't find 15W40.
I oiled both turntables to be on the safe since. I tapped the spindle on the locked turntable to help loosen it.
I drove back home which is pretty much an hour drive and let the tables sit for another 2 hrs.
I decided to grab a thick towel and vice grips to work on the locked spindle.
Clamping down on the towel with the vice grips on the brass fitting for the platter I was able to free the spindle quite easily.
I was then able to turn it by hands so I did in both forward and reverse directions to work the oil down into the spindle bearings.
I put the platter back on and spun it manually to check for resistance, it was spinning nicely!
Plugged in the turntable, set the pitch at 0 and watched the stobe dots. There was no waver in the strobe dots. YAAAAAAAY!
My turntable is back to new and since I only use them on the road they stay stored most of the time.
So I would suggest just oiling the spindles every so often to keep them tip top.
Hope this helps you!
Peace,
DJ Quartz
Posted on Feb 18, 2009
funkyparrot
  • 5 Answers
SOURCE: i hooked up my new stanton t-60 turntable to an
Are you using the phono input on the Sony? If so, you're getting too much gain, you've already got a phono pre amp in the Behringer. Try using the tape or C.D. input. That should solve it.
Posted on Jan 17, 2010
Stanton T52 Turntable. I get intermittent, loud popping, like static. I have checked ground wire, and it is hooked up to receiver just fine. I have cleaned my LPs in every way possible and have tried 3...
There are 3 possibilities I believe here. First a faulty connection to the cartridge or the cartridge itself. (2) internal (inside the deck) fault on a pre-amp. (3) Fault on the magnetic cartridge pre-amp in your amplifier. This would not effect any other functions on the amp.
Feb 22, 2015 | Stanton T52 Turntable
I have a Stanton turntable, model T52. I think that the internal fuse or the transformer has blown. How do I check to see if it is the transformer or the fuse or both? There is no power getting to the
I cannot view any more information in your initial post after
There is no power getting to the except that you think the fuse is intact. From my experience, there is no transformer driving the turntable motor since these operate directly from the power mains. Can you show us a picture? Dave
Dec 21, 2014 | Stanton T.50 Turntable
When connected to Denon 2808ci receiver i get humming noise.Since there is no ground wire to connect,how do get rid of the hum?
Sometimes the earth lead in the power cord can be the cause, either connect or disconnect it. Also check the earth connections on the cartridge.
Oct 13, 2013 | Stanton T.92 USB Turntable
Turntable Problem
If you ain't see anything else broken, i would first checking if the output of the transformer still give the right value, but i think replacing it is a good choice ,but also try if your rectifier gives vooltage or not
Aug 17, 2012 | Stanton T.92 USB Turntable
Convert 45s to mp3s - sound scratchy
Just check the connections to the cartridge on the Stanton. Make certain they fit and are correctly fitted. Also check or replace the stylus, if it is not new.
Jun 14, 2012 | Stanton T.92 USB Turntable
Connection
sounds like you need a phono pre-amp
Jan 27, 2008 | Stanton STR8-100 Turntable
192 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
