Question about HP Office Equipment & Supplies
Hp 3600 54.17 error
The printer intialises and then comes up with an error saying 54.17 error
  • Renier Homan Dec 13, 2012
    Thanks for the advice guys but eventually fixed it by replacing the gear assembly.
  • 24 Answers
54.XX ERROR An error has occurred with one of the tonerlevel
sensors.
XX Description:
15 Yellow
16 Magenta
17 Cyan
18 Black
1. Make sure that connector J1020 on
the DC controller is seated correctly.
2. Replace the DC controller.
Posted on Dec 12, 2012
  • HP Master
  • 1,121 Answers
Error related cyan cartridge:
1. Remove the cartridge, check physically toner is available or not.(It may show in display)
2. check both left,right levers as shown in movie clip. If found any damage?, Replace it.
3. Check with another cartridge.
4. Reconnect J1020 on DC controller.Check cable end condition.
5. Replace DC controller.
2 Suggested Answers
  • 111 Answers
SOURCE: system Error: Cycle power is
please disconect the printer for 5 minutes from the e-socet then conect it and try, if it still not work deinstallate the drivers and reboot the computer then installate the driver's from the samsung download site to your download folder first so they are availebl later again then installate the printer driver and the scanner driver and Dr. Printer an reboot the system again now check it should work proper now.
Posted on May 24, 2011
HP LaserJet CP1215 Color Printer says Engine Communication Error
I would turn off the print and then turn on. This could be a main board issue.
Aug 26, 2014 | HP LaserJet Office Equipment & Supplies
Unable to print and make photocopies
when you try to print does it come up with any error message?
or does it get sent to the print spooler and then lost in cyberspace?
or does it get to the printer and then the printer says no?
for the error message follow what it says so if the error is no connection check that the wires are attached. if it comes up with an error code look it up on the HP website.
if it gets lost in cyberspace try reinstalling the printer with an updated driver.
and finally if it says no go to run and type services.msc and scroll down the list till you see print spooler if it says it is stopped start it and try again, if it still doesn't work try updating the firmware
Jan 03, 2014 | HP LASERJET PRO M1132 MFP
How to clear error 000732-0001 i rc5185i
Check the connections between the reader controller PCB and main
controller PCB. Check the power supply of the reader.
Jan 29, 2013 | Canon irc5185i
System Error: Cycle power is coming after intialisation for samsung scx4828fn printer
May 23, 2011 | Samsung SCX-4828FN All-In-One Laser...
HP DL380, drive 1 and 2 lights are not on, but 3 is. Can I swap new drives in those spots and it write automaticaly. Or is there and easy fix, I checked cables and connections, reset hardrives and powered...
Boot from HP Diagnostic Media (SmartStart CD)and check the status of Array.....or harddrives...
If showing any failed status or not supported..
Replace drives to check if new drives show status...
It could be because of Drives not intialise for Array..
Boot to Array Configuration Utility...during bootup and go to Intialise disks....
Use them
Oct 05, 2009 | HP Compaq ProLiant DL380 G4 Server
Error message -4431
If the scanners keeps blinking while powering on, it is because it has not been intialised. Check for loose shreds of paper in the paper path. Unless the scanner intialises, it cannot scan. If simpel 'countonly' option works, then the scanner is okay.
S. Mohan, Chennai, India
Sep 04, 2008 | Canon DR-2580C Path-Through Scanner
Printer does not intialise
Most likely, the main logic board has failed.
You might get lucky and find that it's only a corrupted flash, but that's a slim hope.
Steve W
LazerTek LLC
Jun 29, 2008 | Printronix Line Matrix P5005B Printer
SERVICE CALL 188 : FATAL ERROR
Service Call 188: Error: Sub-CPU Communication Error
1- Check the connection of the S2M board.
2- Replace the S2M board.
If the problem does not go away after a reboot you'd better call Oki (it should have a 3 yr. waranty) or an experienced oki technician.
This is not something you should want to fix yourself. The replacement of the s2m board is not an easy task (even for an experienced mechanic)
Jun 24, 2008 | OKI 9800hdn Laser Printer
2,135 people viewed this question
Seeker5211
Seeker5211
