Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool Cabrio WTW5500XW
The "WASH" light stays on and doesnt do anything. I have to manually put it on the spin cycle. I don't have a digital display to give error codes. The "WASH" light stayed on all night long, only light that was on when washing towels. The lid came unlocked and all the lights went off but the "WASH". What is going on with this.
5 Suggested Answers
  • 1294 Answers
SOURCE: whirlpool Cabrio he clothes washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 12, 2008
  • 1382 Answers
SOURCE: Will start the wash cycle and DL come on and light
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Posted on Jul 28, 2010
ZJLimited
  • 17970 Answers
SOURCE: My Cabrio washer stops at
Some error code there? This may sound strange but give it a try. Unplug the electric. Leave unplugged 2 or 3 minutes, then plug it back in. This allows the controls to reset. It worked alot cases.
Inicially I could think in some drain problem, check hose for any clogged or obstruction there, try to jump voltage to the pumo to confirm if this device is working. If this dont solve it, you will need to check timer; in this link could finr some tip test: applianceaid.com/direct.html#burnt_timer
Visit this site to identify some parts replacement that you could need: partsearch/model.aspx?model_id=5152465&diagram
If you are not sure about how do it this job, or your machine is even under warranty, call the technician service.
Hope this helps.
Posted on Jun 24, 2011
Daniel S
  • 4323 Answers
SOURCE: my whirlpool duet will go
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Aug 28, 2011
Whirlpool Cabrio H2low is not draining after wash cycle
please check owner's manual troubleshooting. I'd guess load is, was out of balance and shut down spin cycle early.
Feb 17, 2015 | Whirlpool Washing Machines
Wtw5500xw2 will add some water, senses for a very long time. Sometimes it makes it to the "wash" cycle but nothing happens. When you come back later the machine is off and the lid is unlocked as if it...
Un plug it for a few minutes or even overnight and plug back in, that will reboot the electronic control, if that doesn't fix it and you do not have a good honest local repair shop call Sears. Good Luck
Oct 12, 2013 | Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top...
Why doesn't Cabrio washer wash the clothes?
This model has gone through different control board revisions, could be control board related, service mode would have to be accessed to have machine run thru self-diagnostics. if it does not agitate on self-diag mode, unit needs board
Apr 03, 2013 | Whirlpool WTW6400SW Cabrio Washer
Wash light remains on WTW5500XW
Sounds like a bad main board , Good thing its new under warranty
Dec 12, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio wtw5500xw starts sensing then it won't stay locked to start the cycle
This is a common problem with the Cabrio washer. The RPS sensor needs to be replaced. Here is the part to order.
Here is a video to show you how to do the repair.
Nov 10, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer will not start
I have one doing the same thing it washes but will not rinse.So until I can do better I just use the wash cycle twice first with detergent and once without.
May 30, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I just got my Cabrio washer and when I use a wash cycle the machine doesn't spin at the end. The machine says the cycle is complete but the close are dripping when I take them out so I have to put them...
Sorry to have to tell you, this machine is junk. Google search "Whirlpool Cabrio" and see the number of complaints for this model.
http://www.consumeraffairs.com/homeowners/whirlpool_washing_machine.html Here is one you can see, has 46 pages of complaints.
If you Just bought it, I would try to return it for refund or exchange for a different model, if you can.
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
345 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
