Question about Orion1934 19" TV
The cable receiver broke off the set
It is part of a larger component, can i solder it back on?
    Champion:
  • 240 Answers
If you can solder yes.
i use a specil fux .
you can make it your self works well for this job use a 2 pary joy dishwashing sope to 1 part denatured alc.
and make shure you have a cabel conected to the part or it will over heat and melt inside. also need to take side of tuner off to solider the inside conection back inplace.
daniel.
Posted on Jan 13, 2009
    President:
  • 2,992 Answers
This connector is either mounted right on the tuner or on a small interface box that plugs into the tuner (depends on the model). It can be soldered back into place, but it's not an easy job unless you have the tools and experience with electronic soldering. The connector itself requires high heat to get the connector shell and area where it's mounted hot fast enough to make the connection. This means a soldering gun in the 150-watt range (Weller 8200 is the ol' standard). Then there is also the connection to the center contact which needs to be repaired, and this needs a lower-heat iron. You may also need some light-gage wire to make the connection if the original tab is too short to reach back where it originally went (and usually it is). If the connector was part of the tuner, you'll need to get the tuner open to make the repair, and this sometimes means removing it from the circuit board. You may be able just to pop the cover off and reach the connections; again, depends on the set. I'm not familiar with this model so I can't tell for sure. It sounds like a lot of work, and it can be, but it is certainly possible. (In my road service days we usually saw one or two of these every day. The cable company guys were famous for overtightening their connector and breaking the TV. Or customers would trip over a cable and yank it loose. Our charge was about $60 including the trip.)
How I do I repair cable connection from back of TV. It broke off when I tried to unscrew the cable to it
unless you have excellent desolder and soldering skills plus the special tools needed, you will have to replace the board that the broken connector is on. Or use a cable box/satellite box and the component, composite, or HDMI input
Oct 20, 2014 | Seiki Televison & Video
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
I keep getting a Protector reding on my screen and it will not let me do anything. What do I do to fix this?
Try disconnecting everything (speakers cables, signal cables, all other units) except the power cord, then turn the unit on, if the protector message persists, then the fault is in the reciever.
If this is the case, you should check the speaker and signal connectors for any damage, shorts or loose solder contacts, also check the unit for any shorted or broken wires, loose wire connections, bad solder contacts on connector pins, bad solder contacts on ANY other components (give some extra attention to the components that tend to warm up while they operate, like main power amp transistors / ICs, voltage regulators, power resistors, diodes, also coils, capacitors, etc). Any loose solder connections should be resoldered.
If there's no message when you've disconnected the outside equipment, you have either a bad speaker, a bad speaker cable, a bad signal interconnection cable, or a fault in any of the units that were connected to the reciever. You can find which one is the cause by turning the reciever off, then connecting one cable or unit, turning the reciever on again, see if there's a message, if there's none, turn it off again, connect the next unit / cable and so on, until you get the protector message. The cable or unit that will make the message appear is most probably the cause for the trouble (there might be loose solder connections on other units' cable connectors or other components). When you plug and unplug the cables many times, with time this will loosen the solder connection on the pins inside the unit, so these need to be resoldered.
Hope you can find out what it is.
regards
3rq8 (Triarcuate)
Aug 08, 2009 | Sony STR-GA8ES Receiver
Antenna/cable socket
yes it can be repair..You would have to take it to a repair center so they can repair it for you..
Apr 24, 2009 | Panasonic PV-C2541 25 in. TV/VCR Combo
EWF TV ANT IN BOKEN
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
My cable connector (the thing that I screw my cable sord onto) broke off and I need to fix it
you have to open the tunner up and solder it back only conect the pin to the place it broke from and becareful of your solder and solder mounting to for ground in the same position
Oct 18, 2008 | Televison & Video
DVD no signal HDMI
Loose or crack or cold solder joint holding the socket of HDMI.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the TV turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If this solution help you understand the problem :rate as fixya..
Good luck;
Jul 16, 2008 | Onkyo TX-NR801 Receiver
No antenna detected
The wire is soldered to the board after going through the white insulation inside the connector barrel. After opening the unit, place the solder iron in the hole provided where the barrel is attached to the board. Push the broken piece out using a piece of 18AWG bare solid wire. This is a little tricky... make sure you don't damage other components on the board while pushing the old piece out. Then use the same 18AWG wire for the repair. Push it though from the outside of the barrel. Use the small lower opening to get the solder in place. Leave some space to move it back further when you solder into place. Then cut the wire flush with the outside of the barrel. Warm the solder again, and pushed the wire back in a little so it is recessed in the barrel. Let the solder get hard, and that's it... Works perfect. Should take 5-10 minutes.
Jun 04, 2008 | Sirius Starmate ST2 Satellite Radio...
Will not come on
go over you solder joints again and make sure nothing is cross soldered, also check the larger resisters on the board.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 10, 2007 | Panasonic PT-47WX53 47" Rear Projection...
EWF TV ANT IN BOKEN
ANGLS186-YES YOU CAN RESOLDER THE ANT. IN COAX CONECTION BUT KNOW YOU MUST FIRST SOLDER THE CENTER WIRE OF COAX TO TUNER BD. THEN CAREFULLY INSERT COAX BACK INTO ORIGINAL POSITION.THE EASIER SOLUTION IS TO USE A VCR OR CABLE BOX HOOKED TO YOUR SETS' VIDEO IN PORT AND CHANGE CANNELS W.THAT COMPONENT.JOE TV
Nov 19, 2007 | Emerson EWF2004 20" TV
Orion1934 19" TV Logo
46 people viewed this question
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
