Question about Electrolux Washing Machines
EWN 1220 washing machine goes into pause mode after starting new cycle?
I turn off the machine at the power point and sometimes when switched on and reprogrammed the machine will run and wash as normal. The machine goes into pause mode a few seconds after programming and pressing start. When machine pauses the door light stays on and the start/pause button flashes. I have tried switching off and reprogramming but just goes to pause mode. The water connection must be ok because the machine sometimes works. It doesnt spin so efficiently anymore?
rachael
  • 4 Answers
SOURCE: Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
Posted on Dec 17, 2007
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Posted on Sep 09, 2009
SOURCE: Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Posted on May 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: Zanussi 1000XC Washing Machine - Pause Light Flashing
The ECU is failed. unplug for 40 minutes to try to reset it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
  • 713 Answers
SOURCE: I have a problem with my MW512AU. Sometimes it
Hi just read your posting.This problem sounds like your control module is doing funny things.Does it show an error code at all and beep?What part of Australia are you in?There is a place in Melbourne that tests these modules.Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on Sep 19, 2010
I have a LG Tromm it starts running in wash mode then a few mins. into cycle it shuts off no codes there is nothing on display
Here's a reset that could work:
To fix this:
  1. Press POWER, and turn the machine OFF.
  2. Unplug the machine.
  3. With the power being disabled, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in.
  5. Power the unit back ON.
  6. Press-in on the door firmly.
  7. Select any cycle, and press START/PAUSE. Good luck
Mar 07, 2018 | LG Washing Machines
Hot point washer VVSR1040V1WW stops after fill on rinse. But slight nudge to dial, it goes. What part to replace and how?
Sometimes a washing machine timer needs a little nudge to get it to fill. Call it manufacturing tolerance.
The knob action you describe is normal.
Jun 19, 2017 | Washing Machines
Why is the SP light flashing when the machine has filled with water and is ready to go
sp is the code for stand by or pause
so if you have set a soak period then it will stay there until the soak period has finished
if it is sp and you have pressed pause/start extra time the machine is in pause mode until you press start again
Sep 29, 2016 | Simpson Washing Machines
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
How to reprogram lg washing machine wf t6560cp
The machine cannot be reprogrammed, by unplugging the power source for at least 5 to 10 minutes will normally solve any problems normally caused by electrical "noise" from fluorescent lamps etc.
Sep 30, 2015 | LG Washing Machines
Zanussi aquacycle 1200
Turn the machine to the off position. Unplug it and then plug it back in. Now try to restart the cycle. If this does not help find a local washer and dryer repair shop
Jan 24, 2014 | Washing Machines
I did try: change fuse as first it was without any lights. Then checked sockets. It started again by itself. Then I reprogram it-switch off-turn on 90'C-press start button- switch on- keep pressing f
Try this reset, it may work:
-Turn Off power switch
-Select 90 degree washing
-Press and hold Start
-Turn ON power switch and keep pressed Start button 10 sec
-Depress Start button
-Turn Off power switch and turn On again and thats it...
Credit to original poster :)
Oct 19, 2012 | Washing Machines
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
