Question about Watches
Remove link from Watch Band
I need to remove a couple of links from a metal Fossil watch band
    Problem Solver:
  • 4 Answers
I would suggest that you take it to local jewler or watch repair center, it normally runs less then $10 to remove an unlimited number.
Wal-Mart used to be a good place to go, but have since decided to support only watches that are sold in the store, which are crappy at best.
If you want to do it personally...I would discouage it. It is normally a simple process but without training, can turn into a big problem with minimal effort.
Have a great day!
Posted on Jan 13, 2009
Where can I get extra links for the band?
Moto 360 - Extra links for metal watch band - Motorola Support
https://motorola-global-portal.custhelp.com/app/.../prod.../2815,9141
Your metal watch band can be expanded by adding links. The small gray envelope inside the watch box (see image below) contains four extra metal links.
Order Links & Bands - Fossil
https://www.fossil.com/us/en/.../order-links-and-bands.html
Fossil GroupOrdering Links & Bands (U.S.). Order Links. Extra links can be ordered with a U.S. issued credit or debit card by calling the Metro Service Center at ...
Parts Archives - Citizen Watch - English (US)
Dec 25, 2015 | Watches
How to remove links from a metal fossil watch band
mcdevito75 here, To reove the links you"ll need a special tool called a link remover available on ebay, or you can look for a small watch repair shop in your area for about the same cost of the tool and save on delivery time as shop can do the job right away.
Aug 07, 2010 | Fossil AM3726 Wrist Watch
How to adjust a metal watch band Fossil Casual Metal Dial AM3861 Watch for Women
mcdevito75 here, Best bet since you would need a couple of tools to adjust the band size is to look for a small watch repair shop in your area to save on the cost, the cost of a shop to adjust the band is about the same as the tools needed, since these adjustments are in frequent let the watch repiar shop do the job.
Jun 18, 2010 | Fossil Casual Metal Dial AM3861 Watch for...
Watch band link removal
Find out here in my tips.
Feb 04, 2010 | Fossil AM3726 Wrist Watch
How do i remove links from a fossil metal band.. watch
Look for screws in the links or pins. Sometimes "hairpin" looking keepers are used to remove a link.
Dec 05, 2009 | Fossil AM3726 Wrist Watch
Remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Jan 09, 2009 | Fossil Arkitekt watch
I just bought a fossil watch ch2331 and need to remove a link. how do i do it?
Some of the links are removable on this watch & some are not. Look inside the band you should see some tiny arrows on the removeable links. You need to push the pin through in the direction of the arrows & remove the link. Then to put the band back together you need push the pin through in the opposite direction of the arrow. Make sure the widest part to the pin goes in last or it won't fit.
Mar 09, 2008 | Fossil CH2331 Wrist Watch
Fossil watch band adjustment
throw the ******* thing away
Dec 26, 2007 | Fossil AM3695 Wrist Watch
Watch band
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Dec 25, 2007 | Fossil AM 3688 Wrist Watch
Watches Logo
731 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
