Question about Motorola Mobility FINITI Headset
Trying to pair my Motorola Finiti headset with my Windows 7 PC - PC says it can notfind the driver - where can I find it?
I have a Windows 7 laptop- the PC finds the device - but then comes up * says that the device driver can not be found.
Medion pc usb host controller drivers windows 7 64 bit
Medion Model number? Usually if you run Windows Updates Windows 7 will apply a generic driver. Did the Medion come with Windows 7? Have you tried a System Restore? If you oprn the Device Manager , do you see any Unknown Devices? Slects VIEWS, select Show Hidden Devices, open the Unknown Devices and try to Update Drivers.
Jun 30, 2013 | Computers & Internet
Win 7 driver
WINDOWS 7 DEVICE DRIVERS PROBLEM
Windows 7 should automatically install device drivers for the Audio, Video and Network. If you are unable to find/download a device driver that works on your computer and your computer is connected to the Internet then - 1. Remove the driver that isn't working if it was installed.
2. Set Win-7 "Windows Device Installation" to 'AUTO'
3. Windows will automatically search the Internet for the driver.
4. Reboot your computer.
Apr 01, 2013 | Computers & Internet
Base system device driver not found windows 7
You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Feb 21, 2013 | HP Pavilion dv2500t Notebook
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Nov 15, 2011 | Nokia BH-503 Bluetooth Headset
Compaq Presario 2050NX onboard pnp nic (LAN) device not found - reinstalled onboard LAN device driver, still can't see it
For Windows XP CLICK HERE
In Windows 7 the driver installs automatically
I would suggest uninstalling all drivers for the network adapter then reboot and allow the system to find the NIC again. If this is Windows XP uninstall all drivers for the NIC, reboot, and install the above driver.
If it is Windows 7 uninstall the drive, reboot and allow device manager to locate the driver itself.
Nov 14, 2011 | Compaq Computers & Internet
Hi, I have an ASUS K52je and my built in webcam is upside. I'm running windows 7 64bit. How can I fix this??
It appears this has become an issue with people with the Asus laptop webcams with Windows 7.
Windows 7 operating system goes out and gets drivers for components that are detected.
From what I can find, you can try to uninstall the device and go to the Asus web site below to install Asus driver for your webcam. Most who have this same problem have found this to be the fix.
Drivers and Software for Asus K52JE model latop and for Windows 7, 64Bit.
http://www.asus.com/Notebooks/Versatile_Performance/K52JE/#download
Aug 26, 2011 | Computers & Internet
When i insert device in Laptip, there always seen device not found. Please suggest me. i have laptop of windows 7, 64 bit.
Device not found is commonly caused by no or incorrect drivers. All devices usually require drivers, even hard drives!
Download all required drivers from the laptops manufacturers web site, no where else or you may get the wrong/corrupt drivers.
That should help.
Jan 27, 2011 | Computers & Internet
I installed windows 7 on my Satellite A135-S4527 and now my card reader will not work, no driver found on system. Where can I find this driver?
The Toshiba Site is the only place I can think of you could get this driver. The problem you will face will be finding it. If the computer did not come with Win 7 Toshiba may not have designed a driver for this device in Win 7. You might be able to locate a Win 7 driver by searching for other machines that were made with Win 7 and have the same device in them.
Aug 08, 2010 | Toshiba Satellite A135-S4527 Notebook
I have just purchased one of Bushnell digital binocular cameras, and found that it didn't come with a driver for windows 7 64 bit. Any suggestions?
I found a driver but it doesn't specify it's 64-bit. If you want to try it go here: http://www.bioticaindia.com/111025.html
Windows 7 is good at finding divers if they are available. Have you tried letting it search for a driver?
Mar 06, 2010 | HP Computers & Internet
Where I can find the drivers for the HP ZD8369EA for window 7
Windows 7 comes with a large stash of drivers if you are running vista the drivers for your machine will most likely be in windows 7 already. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892673&lc=en&dlc=cs&cc=cz&product=1139016&os=228&lang=cs is the link that tells you if your laptop will support windows 7. You could also go to the manufactures site of all the devices like broadcom and see if there are windows 7 drivers for but i would have to say that 90% of devices have drivers in windows 7.
Dec 29, 2009 | HP Computers & Internet
Motorola Mobility FINITI Headset Logo
156 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
