Question about ASUS K53E-BD4TD 15.6in Laptop i5 2.4GHz 4GB 500GB DVDRW
Asus k53e backlight led screen - ASUS K53E-BD4TD 15.6in Laptop i5 2.4GHz 4GB 500GB DVDRW
3 Suggested Answers
SOURCE: Asus K53E will only load Startup repair screen, run this but nothing happens
When startup repair finishes even if it says it could not fix the problem try rebooting and select to run windows if it gives you that option.
Maybe you need to run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Posted on May 02, 2012
extremejojog
  • 64 Answers
SOURCE: MY ASUS K53E WILL NOT TURN ON THE SCREEN IS BLACK OR SOMETIMES IT COMES ON FOR A COUPLE OF MINUTES
Well i fix the problem...i dissasembly laptop to motherboard, remove all components and then i remove bios battery, put some little metal in her place , to charge off power...and then i try to turn on laptop and HE TURN ON, after that a put battery back and try again, and IT'S WORKED AGAIN...after that test I put all components back and assembly laptop and try and IT IS WORKING GOOD NOW! So Ithink that the bios battery need top be reset!
Posted on Oct 26, 2013
Laptop wont charge
I would get a new power charger. Walmart has universal chargers.
May 29, 2014 | ASUS Computer International K53e B1...
How do I clear hard drive on Asus K53E notebook and restore to original factory settings?
Go to the programs menu and look for the name of your manufacturer and click on that folder and look for the option to recover your PC. Click on the option and it will lead you how to do it. Some times you can restart the PC and click the F8 button while its rebooting and you will get a black screen with options on this subject.
Oct 21, 2013 | ASUS K53e B1 Notebook
ASUS K53E Laptop screen brightness is flashing
get the screen to be checked by a tech, its a sign of loose signal cable which might burn the screen or short circuit the board and or other components as well !
Sep 29, 2013 | ASUS K53e B1 Notebook
K53e asus has dark screen how do i find and replace the backlight?
The CCFL lamp is located at the bottom of the LCD screen behind the plastic bezel in between the hinges.
You maybe able to get a CCFL lamp from this WEB site.
LCD screens and Inverters www.lcdparts.net
Feb 12, 2013 | ASUS Computers & Internet
How to light up keyboard on asus k53e-rbr9 laptop
ive had this laptop for a few months now and unfortunately it does not light up. i really dislike that it doesnt. what i have to do is tilt the screen so the light reflects to the keys. but you can buy a little light up usb light for relatively cheap on ebay. just look up "keybord light"
Jun 11, 2012 | ASUS K53E-RBR9 15.6" Laptop
Asus k53e keyboard freezes and then fan blows out hot air
sounds like it's overheating turn over after shutting down and look to see if there's clogged vent for fan
use a plastic tip on vacuum to get dust out then try it again
May 22, 2012 | ASUS K53e B1 Notebook
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 17, 2012 | ASUS K53e B1 Notebook
No bass K53E Asus.
LOL, You've blown the itty ***** speakers.
Apr 22, 2012 | ASUS K53e A1 Notebook
ASUS K53E-BD4TD 15.6in Laptop i5 2.4GHz 4GB 500GB DVDRW Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
