Question about Toshiba 37HLX95 37 in. LCD TV/DVD Combo
NO SOUND ON TOSHIBA TV, MODEL #37HLX95
WE TRIED REPLACING MAIN INPUT BOARD, AS WELL AS X BOARD, BUT STILL NO SOUND. ANY SUGGESTIONS?
    Genius:
  • 1,239 Answers
See attached instructions for service mode and default values. Although some of the settings seem to work straight away, I only got sound back when I turned the power off and on.
Cheers,
P.S The servive manual can be got from electromaniacs.com the file is "TOSHIBA 17VL46B LCD TV SM.pdf.zip" - too large to post here
Posted on Jan 14, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 14, 2009
  • ABHISHEK.C
    BUT: If it were the high voltage only, the sound usually continues working normally. With no sound nor picture it is usually the main power supply. Common on big tube sets is the failure of the rectifier bridge in the main power supply. Do you know how to check it? If you have a vom you can see if there is any B+ voltage coming off the rectifiers. Or, you can pull them/module out and check it with a ohmmeter. That is where I would suggest you start.
  • 10,594 Answers
Do you get sound in TV-Audio Out terminals if you hook any amp, receiver?
If yes, then sound amp is bad or not getting voltage supply from power supply.
If there is no sound at TV Audio Out terminals then it can be problem of sound processor.
Let me know, do you get ever sound on cable or dvd input?
Posted on Jan 13, 2009
    Genius:
  • 1,550 Answers
Have you plugged all the connection and did proper soldering after placing the Board and X board .
  • Toshiba Master
  • 4,806 Answers
Hi there
Make sure the settings are correct by setting them to the TV not an external device like a home cinema system
Good luck and thanks for using Fixya
Samsung UN50H6350AF LED TV. No picture. I do get backlights and sound. (See pic) I tried replacing the main board and the T-con board and there was no change. Any suggestions? Try power supply board?
You have wasted enough money guessing bite the bullet and replace the TV. I have done this same thing and regret it to this day, should have just junked it.
Dec 02, 2016 | Samsung Televison & Video
Toshiba model #37HLX95 won't power-up
More than likely its is a faulty component on the power supply, like a compositor. It is cheaper to buy a new tv then to fix many of these issues. Repair usually involves a lot of diagnosis and if it is a replacable component you will then have to solder out and back in the new part.
Aug 19, 2014 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
TOSHIBA TV No Power32WCT58
Check and replace damaged component/s at its main power regulator [SMPS] board or replace this board as card basis. Contact the authorized service center for Toshiba, to buy a genuine board. If you wish to get some details, http://electronicshelponline.blogspot.com/Pull up older posts.
Dec 18, 2013 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
LCD TV Has Sound, Backlights Work, but No Picture
I have been having the same problem with my LG. people say there are bad capacitors on the power supply board. I don't have the know how to replace them and don't have the money to pay. I can get mine to work by blowing hot air with a hair dryer into the back of my tv through the vents over the board. Heat it up for a couple minutes and turn it off and then back on and the picture comes back. I just never turn the set off now.
Sep 08, 2012 | Vizio M550sv 55 Inch Class Edge Lit Razor...
Toshiba model 42hp66 Plasma flat screen Problem No picture or sound. Pushing on button 2 clicks are heard A slight hum is heard at the Z SUS board. Green power light is on (power light is...
Hi
There are some factors of this kind of problem.
First you could have a failure in the power supply. Next could be the main board. Lastly you could have a problem with the panel itself, this would mean a new set for sure because the part cost is more than a new set.
However try troubleshooting the problem before spending money on repairing or replacing the television. Possibly you can restore the picture and sound to your television ...
Verify the TV is powered on by pressing the power button on the TV's remote or the front panel of the set. This may seem like an obvious step, but many TVs are equipped with a standby light that will illuminate if the TV is turned off, making it appear that the TV is on when it is not.Cycle through the TV's video inputs to verify that your TV is set to the right one. For instance, if you are attempting to use a digital cable converter box that is plugged into the Video 1 input and the TV is set to a Video 2 input that has nothing plugged into it, the TV will not display any picture or sound and may even say "No signal" on the screen. To cycle through the inputs, use the input selection button, typically labeled "input," "source," "TV/video" or the like.
Re-seat the video and audio input connections to verify a loose cable is not causing the TV's loss of signal. If you have a coaxial cable connected from your wall cable jack directly into the TV, it may have come loose thereby eliminating all picture and sound on the TV. Locate the connection cable or cables of whatever device you are attempting to watch and unplug them from where they plug into the TV. Plug them back in and check for a signal. If there is still no picture or sound at this point, the best option is to contact technical support for further assistance.
Apr 22, 2011 | Toshiba 42HP66 42 in. LCD Television
42 in. vizio. just went blank. no sound or pic. just blue screen. no words like no signal. nothing. tried tapping input button on side with tv on an off still nothing
The main board has become faulty. It is a logic issue that is causing the TV to fail. The only way to fix it is by replacing the main board.
Nov 09, 2009 | Televison & Video
Toshiba REGZA 37AV500A LCD TV when using HDMI input picture and sound intermitantly blacks out for about 2 seconds
Does this happen with all the HDMI inputs. If only the one then jack is bad. Replace the main board. If on all HDMI inputs see if replacing the cable helps.
Nov 08, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba 37HLX95 wont power on, just click sound. if i hold down power theirs a click as tho powering on and click again, but nothing, no pic no sound nothing. removed rear case cover and checked fuse, its...
I have the same problem. It happened once before about 4 years ago just after I bought it. I put a DVD in without the power on. I was able to take it out and it worked fine. This time my daughter put the DVD in, I took it out but still no picture or sound.
Have you had any luck?
Sep 11, 2009 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Toshiba 37HLX95 37 in. LCD TV/DVD Combo Logo
132 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
