Question about RTO 50cc Moped Scooter
Malaguti 50 cc starts and runs fine but cuts out when gets wet
I've not bin on my malaguti 125 for 2 days was running fine now won't start
Hi, John and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.apriliaforum.com/forums/showthread.php?179110-Malaguti-f12-won-t-start Scooter Troubleshooting Scooter won start All about Scooters
Malaguti MADISON 125 Manual
MALAGUTI MADISON 125 150 Wiring Diagram Parts and Electrical Components...
MalagutiScooters and Motorcycles Spares Parts and Accessories Fast Free UK...
Oct 22, 2016 | Malaguti Motorcycles
Malaguti Drakon 50 will not start on electric starter.
I do not know what a Malaguti Drakon 50 is BUT what are you saying?? Are you saying that the bike will not turn over or that it will turn over but even so it will not start with the bike electrical system and battery but that it will turn over with a booster battery but will not start with the booster battery or are you saying that it will turn over AND start with a booster battery attached??
May 18, 2014 | 2000 Harley Davidson FLSTC Heritage...
My tzr 125 runs fine till it rains then it runs for a bit then cuts out and will not start again and ideas??
probably air filter getting wet which restricts the airflow. Make sure you have a new air filter thats not already clogged. Add the rain to a bad filter and it will starve it for air. If not that, check all hot wires for cracks in the insulation which could get wet and short the bike out while youre riding.
Mar 28, 2014 | Motorcycles
How do i adjust mixture on malaguti grizzly 12
the idle screw on the right side of the carb
Feb 17, 2012 | 2010 Malaguti Grizzly 12 Enduro
Leaking oil from a pipe and running really poor
I am not a Malaguti expert but your problem sound like a clogged exhaust canister on the header. You probably need a new one. You can make sure of that if you can get your hands on another, even used, one to swap and test.Once you take off the exhaust canister, check the exhaust port on the cylinder if it has reduced diameter from burnt and solidified oil. You need to clean that carefully not to scratch the piston or drop solidified oil into the cylinder.
Also check your oil pump (if there is one) to be properly adjusted and not to overfeed the engine with oil. If you mix the oil with the gas in your fuel tank, never exceed 2% oil in the mixture. You do more harm than good.
Feb 07, 2012 | 2007 Malaguti XSM 50 Supermotard
Malaguti grizzly 10 no spark
I would recommend that you check the main fuses located somewhere near or behind the sidecovers on either side of the motorcycle, If that is unsuccessful...You know, fuses are okay looking, then at that point check the electrolytic acid level in the battery. (usually located under the seat or behind the sidecovers as well). If the battery acid level is too low the engine will not run properly and if it is super low you will not even have enough energy to create a spark.
Good Luck my friend,
Phillip
Dec 27, 2011 | 2010 Malaguti Grizzly 12 Enduro
2 stroke engine not starting
Head or base gasket leak, spark is happening at the wrong time. Any of these will cause it to not run.
Oct 02, 2009 | 1976 Honda CB 100
Gilera noly starts when revved
hi mate on the carb there will be a screw get a cross head screw driver and turn this screw in a 1/4 of turns this is the idle screw which should bring the revs up a tad remember its the screw that is sticking out good luck
Jul 23, 2009 | 2005 Gilera Runner VX 125
2nd hand Suzuki RAN won't start
drain the oil(all of it) and put on a new filter.sounds to me like you are missing a gasket to the crank case.
Apr 26, 2009 | 2004 Suzuki RM-Z 250
RTO 50cc Moped Scooter Logo
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
