Question about Colubris Networks (CN3200) Integrated 802.11a, 802.11g/b
Can i conect my colubris cn320 to my computer via ethernet port and use it to get on open wifi access points? like starbucks?
Cn320 wlan acess device 48vcd/.35a ieee 802.3af
How do I get NETFLIX on TV
You need a internet capable device a wwii blueray player or plug your computer into your tv .
Dec 12, 2014 | Netflix
Tip
Wifi Guide For C3 also other phones
<span><b><u> <span><b><u><img src="vhin100889_25.jpg" /><br /></u></b></span>* How to deal with WLAN (WiFi) *</u></b></span> <span><b><u><br /></u></b></span> <span><b>Setting 1:- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Internet connection &gt; Ask first<br /><br />- Goto Menu &gt; Settings &gt; Configuration &gt; Default config. settings &gt; myGlobe (or Smart)<br /><br />- Goto Menu &gt; Settings &gt; Configuration &gt; Preffered access point &gt; myGlobe Internet (or Smart Internet)<br /><br />- Goto Menu &gt; Internet &gt; Web settings &gt; Configuration settings &gt; Configuration &gt; myGlobe Internet (or Smart Internet)<br /><br />- Goto Menu &gt; Internet &gt; Web settings &gt; Configuration settings &gt; Account &gt; myGlobe Internet (or Smart Internet)<br /><br />- Select your preferred scanned network, then Connect.<br /><br />- You will notice a WiFi signal logo ..oo)))) on the top screen indicating you're connected.<br /><br />- Go to MENU &gt; Internet &gt; Go to address <i>(and enter the website you want)</i><br /><br />- Done. Enjoy browsing via WiFi.</b><b><br />Setting 2:- Go to Menu &gt; Settings &gt; Configuration &gt; Personal Settings &gt; Add &gt; Access point (leave others as is) &gt; press back &gt; Option &gt; Activate- Goto Menu &gt; Settings &gt; Configuration &gt; Preferred access point &gt; My access point- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Internet connection &gt; Ask first<br /><br />- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Available WLANs<br /><br />- Select your preffered connection, then connect.</b><b><br />Note:- Update your phone to the latest firmware, preferrably version 7.20 or higher. Firmware upgrade might solve Web browser bugs and WiFi issues.<br /><br />- Check your WLAN server, you might have a weak WiFi signal.</b></span> <span><b><u><br /></u></b></span>
on Jul 12, 2011 | Cell Phones
Cant conect to 02 internet on nokiac3
go to menu->settings->connectivity->wlan->internet connection
Please check your phone sw version from this link and update if necessary.
Please do not forget to back up your phone before you update.
http://europe.nokia.com/support/download-software/device-software-update/can-i-update
The latest sw is 4.60 depending on the sales areas and variant.
Please also become familiar with the FAQs :
http://europe.nokia.com/support/search?comp=Nokia+C3-00&qt=wlan
How do I manage WLAN internet access points on my Nokia C3-00 device?
How can i use always WLAN connection on my Nokia C3-00 phone for Internet instead of GPRS?
I hope this helps.
First of all you delete all current settings, these are for 02 and will not work on giffgaff. To delete settings:
  1. Press the navi key and go to Menu
  2. Go to settings
  3. Go to configuration
  4. Press the navi key on Default config. settings
  5. On both 02 Pay&Go and 02 paymonthly press the backspace key (inbetween the p and enter key)
  6. Select Yes to delete on both
Now that you have done that you need to set up the giffgaff settings, I recommend using this method to do it:
  1. Go back to configuration
  2. Select personal settings
  3. Select Options then Add new and then Web
  4. Put the Account name to anything you want (I put Giffgaff web)
  5. Put the Homepage to anything you want (I put http://www.google.co.uk/)
  6. Put the Username to giffgaff and the password to password
  7. Put Use preferred access pt. to No
  8. Select Access point settings
  9. Put Proxy to Enabled
  10. In the Proxy address type 193.113.200.195 and select OK
  11. In Proxy port type 8080
  12. Go into Bearer settings
  13. In Packet data access pt. type giffgaff.com
  14. Put the Network type to IPv6 (IPv6 appears to be faster)
  15. Leave the Authentication type at Normal
  16. In User name type giffgaff and in password type password
  17. Go back until you see your Personal accounts and press Options on your settings and select Activate
  18. Go back again and in Default config. settings select Personal config.
  19. Finally press Default in all apps.
Now that you've done this set up the packet data settings:
  1. Go back and select Connectivity and then Packet data
  2. Put Packet data connection to When needed and select Packet data settings
  3. In Active access point select Access point 5 (Access point 1 is known to have some problems, select Access point 5 to be on the safe side)
  4. Go into Edit active access point
  5. In Access point alias type whatever you want (I typed in Giffgaff)
  6. In Packet data access pt. type giffgaff.com
Okay so finally for wifi settings:
  1. Go back and go into WLAN
  2. Select Internet connection to Ask first (so that you can choose to use wifi)
  3. Now select Available WLANs and wait for the search
  4. Simply find you WLAN, select it and enter the security password for it
  5. When it asks Save network for future use select Yes
Now you have giffgaff internet and wifi set up on your Nokia C3-00! For any issues you can message me, I will be willing to help!
Update: You may be experiencing problems with using wifi with the browser or any other application, do this to fix it: "I had the exact same problem. What I did was that I removed all network Internet settings, GPRS, WAP, etc. because I do not want to use them which is when I lost the ability to select which AP to use.
So what I did was I created a personal setting:
Settings > Configuration > Personal settings > Add > Web
Then go to the main menu > Internet > Web settings > Configuration Settings > Select the personal settings that you created
Now try to access the internet and it will ask you to choose, choose Wi-fi
Then go back to the personal settings and delete the setting that you created. From now on, you will be asked which connection to use everytime you access the internet
If you want to restore your GPRS settings, you can just request it from your network provider and they will send it to your phone."
Source http://discussions.nokia.co.uk/t5/Cseries/ANOTHER-NOKIA-C3-WLAN-PROBLEM/td-p/754515
Dec 03, 2011 | Nokia C3 Cell Phone
Can you connect several n300 routers
Connect a computer to one of the Belkin's "LAN" ports with an Ethernet cable.Open a Web browser and enter "192.168.2.1" into the address bar. Press "Enter."Click "Login," then click "Submit."Make a note of the WLAN MAC address on the Status page.Click "Wireless Bridging" under the "Wireless" category.Click to check the two boxes "Enable wireless bridging" and "Enable only specific access points to connect."Type the MAC address of the Belkin router and the MAC addresses of the other wireless routers or access points that are participating in the bridged WDS network. If using Belkin devices, repeat the previous steps to obtain the WLAN MAC addresses, otherwise refer to the owner's manual of the wireless device to find the WLAN MAC Address.Click "Apply Changes" to save the settings.
Nov 19, 2011 | Belkin Wireless Surf Router (F7D2301)
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
May 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
I have a iphone 3gs and want to access wifi or wireless on toshiba satellite pro x200
Laptop normally have single chip WiFi or Wireless Cards...
These cards could be used as client(connecting to wireless router), adhoc or access point(a WiFi card could be used as Access Point to route your LAN(Wired) connection on WLAN)...
Your laptop WiFi card is already busy as a Cleint, so if you want to use it as AdHoc, you have to remove all the other connection with the WIreless...ie, Disconnect the WLAN from connecting other devices, and follow the below mentioed steps to connect your device..
When you are using Client mode you are not able to use it on Ad-hoc or Access Point feature...
Setup laptop to Ad-Hoc
1)Navigate to control panel and choose network connection, Right click on the Wireless network connection and click on the Properties on Wireless NIC
2) Click-Wireless Networks Tab
3) Click-Add
4) Provide SSID Name, name to identify you rnetwork
5)Security -Net Auth: Open
6)Make -Data Encryption: Disabled
7) In the check box present-Check on This is a Computer to Computer (ad-hoc) network.
Change the IP address of the Wireless NIC card, by choosing TCp IP in the properties of WLAN and choosing TCP/IP v4 from the installed service
TCP/IP on Laptop
-IP: 10.0.0.1
-Subnet: 255.255.255.0
TCP/IP on iPhone
-Static IP
-IP: 10.0.0.2
Now try searching for Wireless through your phone, you should able to connect..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Nov 01, 2009 | Computers & Internet
How do i connect my symbol ap-5131 to my computer?
exist 2 ways to do it...
first if you now te ip address and the user and password of admin, conect the ap at the ethernet port of you pc and configure it with a ip in the same range that the ap, put the ip direcction in the web browser.
the second way is conect the ap to the serial port and run the hyperterminal if you have windows, maybe you need configure the values of the conecctions.
Sep 15, 2009 | Symbol AP-5131
How can i take internet in my psp
The PSP is more than a gaming platform. It has WiFi connectivity, and that means that setting up PSP Internet is possible, just like on any computer. The WiFi feature is intended primarily to be used for upgrading software and for downloading games. But you can go several steps further than that, and it isn't difficult to do either.
You need to have access to an Internet connection first and foremost. This can either be at home where you really need a wireless router, or use you can try accessing a public WiFi hotspot like your local Starbucks or wherever.
The most common home set up is an Ethernet cable running from the computer to the DSL or cable modem, which in turn is connected to the telephone line. By installing a wireless router between the computer and the DSL or cable modem, you should be able to connect your PSP to the Internet too.
Of course, setting up PSP Internet isn't just as easy as that! And if you don't have a home Internet connection of any kind, then you'll have to find a WiFi access point that will allow you to connect. This should be reasonably easy in most medium to big cities. But if you live in a small one-horse town way back in the sticks, then maybe, maybe not.
The PSP also needs WiFi access that is the 802.121b wireless networking protocol.
Hmmm... I know what you're thinking. You're thinking, that's it! Way too technical for me! But hold on, it isn't.
This protocol is, thankfully, the world's most popular one. So the chances are excellent that if you find a suitable public WiFi access point, it will be the good old 802.121b wireless networking protocol.
Most people find problems when they come to the more technical bits. Finding the Network Settings, choosing a New Connection, making sure it's Infrastructure Mode - it's all too much for many who try it. Then there's the WLAN Settings to access, a scan to implement for an SSID of any access points nearby, hoping it's not using WEP encryption!
Time to think again...
This isn't rocket science, though some may think it is.
You need, in this order:
1. To have some kind of a proven Internet connection.
2. Select the Infrastructure Mode in Network Settings and start a New Connection.
3. Access the WLAN Settings and initiate a scan to search for suitable access points.
4. Select a suitable access point that is not encrypted.
5. Test the Connection and enjoy!
Sep 10, 2009 | Sony PlayStation Portable (PSP) Console
I m havin BSNL ADSL2+ DNA-A211-1 modem..i don know how to connect my laptop wit modem in wifi mode..pls tell how to configure n connect it..modem has ethernet port oly not having usb port..pls suggest some...
Secured Wireless is better than a unsecured one. Configuring a secured wireless network easy.
· First Check it the Wireless is turned on in the modem.
You must see the wireless light glow on.
Wireless LAN (WLAN) should be Enabled before configuring the wireless network
· To make sure, if the WLAN is enabled you can check the WLAN light glow.
· If it is off, then you can be sure that WLAN is disabled.
May 27, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Iam not remembre the username and passworld i want username and passworld preicipal i have the same problem my colubris cn3200 WLAN Access Point/controller. im in a computer course and we where given it...
To reset to factory you have to hold reset button until ALL THREE LIGHTS FLASH 3 TIMES!!! Then you can access it through web portal at 192.168.1.1 with admin/admin. (Make sure you set a static IP on your computer 192.168.1.2 and gateway 192.168.1.1 and use a crossover cable). After factory reset the power light should flash rapidly letting you know its in controlled mode. Once you log in you can switch it to autonomous mode.
Feb 02, 2009 | Colubris Networks (CN3200) Integrated...
Colubris Networks (CN3200) Integrated 802.11a, 802.11g/b Logo
141 people viewed this question
Top Colubris Networks Computers & Internet Experts
David Payne
David Payne
Are you a Colubris Networks Computer and Internet Expert? Answer questions, earn points and help others
