Question about Joal Dynapac CA512 Roller Drum Die-Cast Collectible - 135 Scale
Dynapac mutiwheel roller wont drive when hot
Machine drives fine in both directions, but once machine gets hot it doesnt drive in reverse and then forwards drops out
My Dolphin Deluxe 4 works through the cycle but doesn't shut off.
possible bad control board if not shutting off possible bad drive and pump motors or board if voltage to motors bad motors if no voltage to motors bad board
Jul 10, 2018 | Pool & Spa
1989 volvo 760, 4 cyl turbo. our stationwagon is having a little problem starting. in the morning or the first drive of the day the car starts fine but every once in a while we drive it and go into the...
Check the connection at the starter relay. The battery cable should run to the relay and another runs from the starter relay to the starter. If the connection seems fine, the relay itself may have a crack within., preventing a starting connection. If this isn't the problem, the starter solenoid may be getting to hot and not engaging the starter bendix.
Jan 07, 2010 | 1989 Volvo 760
Spin cycle locks up
it is the clutch and be repalced fairly easily
Oct 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Shifting problem?
2\3 solenoid stuck on. Direct clutch malfunction.
Jun 27, 2009 | 2002 Pontiac Grand Prix
Hoover six express wont spin
all hoover machines spin in a clockwise direction the fact that you say the machine only washes in an anti-clockwise direction is a good indication that the reversing switches have failed (these provide the switching to drive the motor in either direction) if your machine uses a mechanical type programme timer this has failed if it it is a processor controlled machine it will be the motor drive card will need to be replaced either way not a diy task
Apr 21, 2008 | Washing Machines
Self propel will go foward, but will not reverse. Seems like handle is all the way extended.
There is a cable that connects to the handle and goes down to the powerdrive transmission. It is visible at the actuator arm on the drive if you look at the bottom of the handle where it pivots on the main housing. It will be on the right hand side, front corner of the handle bottom. You should be able to see the cable connected to the arm of the drive and will move back and forth with the top handle. Sometimes, they break at this connection. The cable may be frayed and broken, or the acuator arm may be broken where the cable connects.
This could also be a simple worn belt problem. The roller is always rotating in a direction that pulls the machine forward and if the belt is worn, the roller will turn sluggishly but still enough to pull forward, but the belt also drives the transmission and a worn belt will not have the capacity to overcome the forces involved to propel the machine backwards. Always change the belt(s) yearly.(on average)
Dec 22, 2007 | Hoover U6630-900 WindTunnel Bagless...
Joal Dynapac CA512 Roller Drum Die-Cast Collectible - 135 Scale Logo
Top Joal Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Joal Toy Expert? Answer questions, earn points and help others
