Question about Fujitsu Televison & Video
410501282009 The code displayed on screen and power indicator show red&no lit.
2 Suggested Answers
electrotech1
  • 1126 Answers
SOURCE: TV would not power on - no green or red indicator.
It is your power supply, if you replace it. It will take care of your problems, The power supply is weak.
Posted on Nov 02, 2010
Samsung 50 Plasma TV- No picture but sound works.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 01, 2016 | Samsung 50 in. Plasma TV
Denon CD deck
This unit needs a service visit. It may be a common problem with that model but to me it sound like a power supply issue as when you play a disc more power is used to rotate motors and move the sled. This is indicating to you that it is in a weakened condition and will soon fail more significantly. The problem may be as little as a solder joint or a defective Filter capacitor which is common in some models of equipment.
Dec 11, 2012 | Audio Players & Recorders
My universal rf10 shows empty. how can I reprogram it
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Apr 08, 2012 | Televison & Video
No display
The following applies to Acer Laptops...
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
May 09, 2011 | Acer Aspire One PC Notebook
Power is on but no signal output to the screen
The following applies to Acer Laptops. You did not specify the brand of laptop you had. If your laptop is not Acer, the specific keys mentioned may be different and you should adjust accordingly.
Apr 04, 2011 | Computers & Internet
Shut down my Acer 2480 wrong by pressing the power button. Now it doesn't reboot or boot up. I tried to pressing F2 to reboot but it doesn't do anything. Any suggestions?
Look at the power indicator:
If it is not lit, no power is being supplied to the computer. If the computer has a battery, it may be low and unable to power the computer. Connect the AC adapter to recharge the battey pack and make sure the AC adapter is properly plugged into the computer and to the AC power outlet.
If the power indicator is lit, check if a non-bootable (non-system) disk or USB thumbdrive is in the computer. If so, remove it and press Ctrl + Alt + Del to restart the system.
Pressing F2 by itself is only used to enter the system's BIOS on startup. If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
Apr 03, 2011 | Computers & Internet
I have a toshiba laptop a3056872...on a friends pc now....when i go to turn it on..all the lights come on....the page tthat says toshiba innovation....hit f2 or f12....it doesnt go any further i have a...
1. Remove the battery & switch on the PC in AC mode.
2. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
3. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
4. If still no display, connect an external monitor, check if display is comming.
5. If Display is coming then your LCD is faulty and need to replace.
Aug 23, 2010 | Computers & Internet
Red rings on the xbox 360 wont connect to live wont let me recover gamertag
The red rings are a fatal Xbox 360 error. There is no way to solve this problem except by having a qualified professional perform a reflow to the problem Chip. This can usually be determined based on the number of quadrants lit.
  • 1 Red Quadrant is usually System Error. A "E##" error code will be displayed on the screen. Most common is E74.
  • 2 Red Quadrants indicates the console is overheating.
  • 3 Red Quadrants indicates hardware failure. A secondary error code can be acquired by pressing and holding the sync button then while continuing to hold the sync button repeatedly pressing the eject button and noting the number of red quadrants that becomes lit.
  • 4 Red Quadrants indicates that either no A/V (Audio / Video ) Connection is available.
Good Luck! Let me know if you have any further questions. If you tell me which number of quadrants or the error code I can point you in the right direction.
Jun 04, 2010 | Microsoft Xbox 360 Console
When I plug in my jet 3 ultra the ammeter reads 0. If I turn on the vsi controller the top led display( 3 red, 4 yellow, 3 green) are all lit. I see where that means high battery voltage. The lower led...
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
Mar 03, 2010 | Jet 3 Ultra Power Chair
Televison & Video Logo
18 people viewed this question
Top Fujitsu Televison & Video Experts
Tony
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
