I installed a tv star box t1020 for saorview but the picture is reduced vertically is this a fault of the box
SOURCE: sharp 27" tv
ALways check for connections. Caps usally get better with heat not worse, but maybe. with out the resources of a service center id say if you suspect a cap change them all i would guess though more likely the IC or a connection becaues you say it is good cold and bad hot
SOURCE: tv repair
A vertical line means the line is up and down in the middle of the screen. That would indicate that the vertical IC and the surrounding components are working perfectly. A vertical line as described is the result of a lack of horizontal deflection (to move the beam from side to side) Since the high voltage is obviously OK, the problem is most likely a bad solder connection in the horizontal yoke circuit. Examine the bottom of the PC board in the area of the flyback transformer, and yoke connector (has four wires Red, Blue, Green, Yellow).and the pincousion coils, capacitors, etc in between. Flexing the board in that area may cause the problem to come and go. Resulting arcing should also be visible. BE CAREFUL, as hazardous voltages are present in the circuit!
it is due to vertical section failure.
Is there any software update on TV Star T1020 Digital Receiver?
