Question about Intel Server Board SE7501CW2 Motherboard
Will 1TB HDD will support SE7501CW2 - Intel Server Board SE7501CW2 Motherboard
  • 2,878 Answers
There is a 2TB limit with MBR and Windows 32 Bit OS. This is the low end of the spectrum.
Sky's the limit with 64 Bit and GPT. Well, not really but for us home users it is. You are good to go.
Posted on Dec 12, 2012
I buy a hard drive 1tb to go with my aspire5532 but I can't get it to work can anyone help me.
Did you simply place this new 1TB hdd into your computer replacing the one that was previously in it? If that is the case, you will need to re-install your operating system onto the new hdd
Apr 14, 2016 | Hard Computers & Internet
Sir, Im having P4BP-MX Motherboard 2GB DDR 40 GB HDD, CAN I GO FOR 1TB HDD for my Motherboard. I bought 1TB its not identifying Is my P4BP-MX Motherboard support 1TB or Not ?
There's two things wrong:
1. You can't simply install a hard drive and then use it. You have to format it and/or install an operating system on it.
2. Your motherboard is a very old model. While it is new enough to support LBA48 mode (which is necessary to fully use hard drives above 127 GB), it is possible that it has an old BIOS version that does not support it. You should check ASUS' website to download and install the latest BIOS update.
Dec 11, 2014 | Samsung Computers & Internet
How connect Magnavox DVDR to Comcast Cable Box ?
You'll need to use the direct input on the rrcorder from the DVR video output.Some channels won't record as they're encoded
Sep 25, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Hd recording
If the digital tuner can pick up the HD channels, then I don't see why it can't record them. However some TV channels have blocking on them to prevent recording. If it can't record a channel it will say so with a message, generally.
Jan 22, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
What size of sata hdd i can connect to mb mercury pi945gcm????
you can connect any size SATA HDD to your system. Depending upon the OS and drivers you may have to create logical drives to handle the capacity. If you decide on a large capacity HDD such as a 1TB drive, backup becomes an issue. You may want to keep your working drives to a manageable size and attach a backup hight capacity drive for backup.
If you have any questions, please let me know.
Please rate this solution. Thanks.
Aug 30, 2010 | Mercury P4VM800M7 Motherboard
I can't get Vista Ultimate set up to recognize my WD 1TB HDD in a new build. Is this a software problem or problem with the HDD. I get the short beep at BIOS start up so I don't think its with the...
Few steps to check your harddisk status on the motherboard would resolve this issue. Checkin to the cmos setup and look for the detection of the HDD and the size it shows once you have done a formating.
Vista 64 bit shows issues at times while installing a new SATA 1TB HDD. Check if the 1TB HDD is installed on to SATA 0.
Use a WD Disk Manager and format the HDD initially and then try install Vista on to it. Else if this doesnt work on the system, Put the HD on to another working system and Format it with NTFS File system and try installing Vista.. You will be successful. Good Luck.
Feb 13, 2010 | Gigabyte GA-MA785GPMT-UD2H AM3 AMD 785G...
I have a Toshiba 1tb external hdd (px1396-3t01) and when i connect it to my laptop i see a blue flashing light..The disc is not recognised by the laptop! what can i do..???????
How old is your laptop? Are you running at least Windows XP Service Pack 3? If so, Right-click My Computer, then left-click Manage\Storage\Disc Management. Do you see your 1TB HDD listed? If so, is it described as Unallocated Space. If it says that it's Unallocated, then right-click in the black area and choose format, then follow the prompts from there. You should probably format it as NTFS. Be careful not to accidentally format a drive other than your 1TB HDD. If you don't see your drive listed in Disc Management then double check your connections. If all is connected well, then you should probably return it to wherever you bought it.
Nov 30, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
New HDD = 80GB but, Bios sees >1TB unpartioned space.
Whenever you switch drives, you must access the BIOS and have it redetect the drive every time. Try the new drive again. Have the BIOS detect it. Use the Windows XP disk and do a full fomat (youll get an option to quick format it, but dont) If the format fails, then the drive is defective.
Feb 26, 2009 | Dell Latitude 110L Notebook
Intel Server Board SE7501CW2 Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
