Question about Kenmore Refrigerators
Horrible oder There is a horrific oder coming from the bottom of the Refrig. Its coming from where air is blowing out of the bottom. It smells like somthing is rotten underneath but theres nothing there. what is this smell? how do we get rid of it??
  • 1,543 Answers
You are going to have to take the back cover off and investigate. Check the defrost drain pan first. If anything from the freezer, like raw meat juice, went down the defrost drain, it would end up in the defrost drain pan, usually located very near, possibly on both sides of, the fan motor at the bottom of the refrigerator. The next thing to look for is a dead mouse. They like the warmth from the refrig., and can get killed from a fan blade, electrocution, or if they ingested poison, that makes them thirsty and the warmth plus the availability of the water from the defrost drain makes an ideal place for the to curl up and die. (A dead mouse usually dehydrates and stops smelling after a few days.) All that sounds like lots of fun, right? Happy hunting and good luck.
Posted on Jan 14, 2009
A horrible sickly sweet smelling odor blowing out back of refrigerator
would check ur drain lines for food residue that rotted u may need to defrost and clean the drain line in freezer and fridge
Jun 22, 2015 | LG Refrigerators
Ge profile side by side 2005 psh25pswass small amnt of water on inside of refrig on the bottom of refrig floor on side next to freezer. vents in refrig appear to be bringing in very humid air that is
It can have an air leak, but also a clogged drain pan under the freezer evaporator coil. If the refrigerator is getting warm, then it may be another issue
Dec 17, 2014 | GE Refrigerators
How do I clean smokey smell from AC vents of 2010 Prius?
Remove the AC/heater blower motor and clean out the mouse nest or leaves you will find in the housing.
Jul 19, 2012 | Cars & Trucks
Side by Side GE Refrig/Freezer is blowing hot air out of the bottom - is this normal?
If your refrig is 10 yrs old or les , then yes , this is normal . It pulls air in from the back over the condensor coils then compressor and out thru the front . The refrig should be 3-4 inches from the wall so it can pull fresh air thru . If any closer , the hotter the air will be causing the coils and compressor to be hotter than designed for therefore causing less life for the refrig . The WARM air is good meaning the refrig is cooling properly .
Jul 18, 2010 | GE Refrigerators
Fridge blows horrible smell
poss drain holes blocked,use a syringe to blow through with clorine bleach.(clorine will gas off so no after smells)
Jun 08, 2010 | Whirlpool GD2SHGX Refrigerator
Why is my refrigerator producing an oder?
Feb 26, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE side by side refrigerator smells on the outside!
Mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section . Too much bleach and the smell of bleach would be circulated by the fan to the room , so be sure to add water .
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dc 14 animal emits a terrible smell after about ten minutes of us
You can take a Febreze sheet and put it into the canister/dirt bin where the dirt spins around. It'll spin around whilst you vacuum your house and it'll spread the fragrance through the vacuum and hopefully get rid of the smell for you.
You can also blow out the cyclone with an air compressor or a leaf blower by opening the bin door on the bottom of the dirt bin and blowing up the cyclone in the middle - perhaps there is something lodged up there that is causing the foul odor.
Mar 21, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Amana ABB2224DES Stainless Steel Bottom Refrigerator is warm however the freezer works fine. How do I solve this problem? I vacuumed the coil and renoved most of the dust accumulation. Is there a way...
check freezer for frost build up and if FAN is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, make sure u didnt turn up freezer control cutting air supply to refrigertor side should be 1/2 feel vent coming from freezer see if you feel any air coming in to refrig.
Sep 02, 2007 | Amana ABB2224DES Stainless Steel Bottom...
Refrigerators Logo
105 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
