Question about Kitchen Ranges
Why is my ravelli stove saying waiting for flame and later on blackout
    Sergeant:
  • 462 Answers
Possibly a flame sensor
Posted on Dec 12, 2012
How do I keep the flame alight in my Indurama. Monte carol model stove. It keeps going out after half an hour of baking
Somethin in the control or gasvalve. Unplug system to see if reboot ir search utube...great repair
Dec 25, 2015 | Kitchen Ranges
Gas stove blows off the knobs
When you went to use the stove again it sounds like a burner did not light. The gas built up and then came into contact with a flame and ignited. Gas, propane or natural, does not float around and dissipate, it settles and builds up, which is what it sounds like happened, and then ignites with a flame or spark. When you suspect that gas has been on, it is best to wait and turn a fan or something on to dissipate the gas before trying to light a burner...
Feb 07, 2013 | Kitchen Ranges
Need to replace the ravelli quick release plate for ballhead tripod
Here is the complete unit replacement:
http://www.amazon.com/Ravelli-Professional-65-inch-Carbon-Release/dp/B004RCHX0W
No parts lists are available on line for this tripod.
Jan 14, 2013 | Ravelli Professional 65" Ball Head Camera...
Kitchenaid Model KGSK901SSS. This is a brand new stove functioning at 6500 ft. altitude. In the morning, the flame from the burners is primarily orange flame. Later in the day and evening, the flame burns...
is the temperature in your kitchen a lot lower in the mornings than later in the day. If yes the problem is caused by the orifice shrinking n low temp .
Oct 04, 2017 | KitchenAid KGSK901SSS Gas Range
Hello, We have a Kenmore gas stove model # 71761. The burners on top work good.The issue is with the oven portion. Oven is working. Flame comes on upon ignition to desired temperature setting and then...
It sounds like yous stove is working fine. Cycles fine. If you think the stove is cycling more often than when new then ck the seal on the door. You may be loosing heat.
Jan 14, 2011 | Ovens
Hi my enviro windsor pellet stove will not light however it will still feed the tray with pellets but no flame is it the electric ignition
I'm having the same issue with my Enviro Windsor pellet stove. I called a technician and he says that the igniter likely needs replacing - still waiting to see how much that will cost!
Dec 08, 2010 | Heating & Cooling
The kozy wold heating stove flame has irruglar
kozy world KW112, 1 burner is dim flame 2nd flame is bright red. What is the problem?
Dec 09, 2009 | The Companion Group Kozy World Portable...
Coleman 424 Dual Fuel -- High, yellow flame
Are you pumping the tank up all the way? I have the same problem if I have too little pressure in the tank. The instructions say pump 35 times. Try pumping 50 or 60 times- that seems to help.
Also, you can't light this one like an old 425. My old stove you could turn the gas on and then take a match neat the burner. For this stove, hold the match near the burner with the gas off and quickly turn it on.
These are two things that seemed to help me with the same problem.
Jul 11, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Stove stop pilot light sparking flame with noise. all i did was clean the stove with an oven cleaner. serial number is sf330peww9 and the mnaufacturer number is p11 431 09nw
We ended up unplugging the stove and waiting a day or two while everything dried out and now it is working fine again.
May 26, 2008 | Kitchen Ranges
Flame on gas hob not correct.
I'm not sure what you mean by a proper efficient flame. I just recently went through an experience I'll relate to you here. I purchased a GE Profile dual fuel range. I can get more specific if you'd like but here's the point. The highest burner on the range was rated at 17000 BTU's. A friend recommended the range to me and sang it's praises. I took delivery of my new toy and couldn't wait to get a pot on the stove to start cooking a long wait for pasta. Twenty minutes later I was finally seeing bubbles! I spilled the water out and measured 12 cups of water into the pasta pot at room temperature. That's three quarts of water. 20 minutes to see bubbles and never would it come to the expected "rolling boil". My experience has always been with electric ranges and I am new to gas but 20 minutes? Something had to be wrong, right? Wrong! Much research later I've found it is common for natural gas to LP conversion stoves to lose a good deal of their oumph when converted. GE as it turns out is one of the most notorious for a serious degredation in BTU output. After exploring GE's site I found that this same stove running under LP gas is rated(for the highest burner) at 11000 BTU's! No wonder I couldn't boil water! Back to the store it went and I am still in search of a stove that will meet my needs. Don't know if this will help you or if this is the same issue you are dealing with but maybe just maybe. Good luck!
Apr 29, 2008 | Cooktops
Kitchen Ranges Logo
78 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
