Question about Xerox WorkCenter Office Equipment & Supplies
How to replace fuser web
I have an error 010-320 on my xerox workcenter 5222/5225/5230. the serial number is 3315844117
  • 7,627 Answers
  • 208 Answers
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
  • 186 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
time to replace the fuser assembly.
Posted on Jun 21, 2007
  • 2072 Answers
SOURCE: Cant locate the printhead on xerox C2424
Remove the covers. But before you go to eh print head itself, there is a print head pivot block that often gets contaminated with ink. The code you are having, is related to the print head not being able to move freely side to side, or tilt properly.
To access that block. You have ot remove the document feeder and scanner. To do that you disconnect the cable, it runs from the back to the scanner to the opening where the power cord plugs in, remove the 2 thumb screws and unplug it. You slide the doc feeder and scanner back, then depress the two tabs and completely remove it.
There is one screw in the back that holds on both the left and right side covers. You have to lift and kind of twist the covers in about the middle of the machine, The front cover will also pop off, it has tabs that holds the front covers together. Then remove them.
Look on the left side of the machine, looking from the front. You will see a stainless steel block, about one inch square, located about 2/3rd of the way back on the lower 1/4th of the frame. It has a spring and a clip over it. Just pull out on the spring bracket and locate it up and to the left, It is meant to be put there for servicing.
Look at the block. it may be filled up with yellow ink. If so , remove it with channel locking pliers. It may be VERY tight, so work it out slowly. Then soak it in hot water, that softens the ink , and clean it and the shaft thouroghly and remove as much excess ink from teh surrounding area as possible. Also, IF that is the problem. Probably a 75 percent chance, then when you return the printer to service. Get a small level, and make sure the printer is level BOTH side to side and front to back. To do that , you place the lecel on the platen glass, sideways then front to back. Often times those printers are not level and that causes the problem. The other things that happens is simple spill over from the ink catch tray, It is imperative you have those printers sitting level.
If thats not the problem. let me know We will go from here.
Posted on May 18, 2009
  • 406 Answers
SOURCE: fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
Posted on Nov 16, 2009
SOURCE: Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Posted on Jul 04, 2010
Xerox 7242 error 010-328 i have a xerox workcenter 7242, it is giving me error code 010-328. how can i fix this error please
That error points to a fuser problem. Replace the fuser and see if that works for you. If not then you need some add'l parts and a service tech to install and repair it for you. Hope this helps.
Sep 03, 2016 | Xerox WorkCenter Office Equipment &...
Workcenter pe 16 open heat error
Bad Fuser. Google a business called The Parts Drop to order.
It is not difficult to replace. Remove the back cover, 4 phillips screws pull out slide the new one in.
I would remove the fuser first though. And check the plastic in the ends of the fuser. If they are melted, then the power supply has failed and you will have to replace both the fuser and power supply. If the fuser looks normal no plastic on the end of the rolls melted, then just replace the fuser.
Mar 12, 2011 | Xerox CopyCentre C20 Black and White...
Hi i have a Xerox work centre workcenter m15i which when it turn on, it display heating Error.what could b the problem.assist
Heater quarz lamp is blown/cut. You can access it by removing the right side back vertical panel, removing a connector and four screws. You can pull the whole fuser assembly out very easily.
There is no spare part for the lamp itself. You must replace the fuser unit (which contains the lamp + thermostat).
Sep 15, 2010 | Xerox CopyCentre C20 Black and White...
Xerox Workcenter 24 randomly and frequently gives 10-398 error.
That is a pretty common problem. The fuser fan is not running right. You can try removing the fan located behind the fuser unit on the back frame and taking the center cap off and lubricating it. but most likely it will have to be repalced. The part number is 127K29340 .
google a business called " the parts drop". Give them a call they will have one and at the right price you should pay for it.
Aug 17, 2010 | Xerox WorkCentre M-24 Color Copier
We have a workcenter pro 45. The new fuser module is on order, but the fuser model went out today. Is there a way to override the error until the new module arrives?
What error? H4? If so then you can get the reset procedure by searching my tip for this under "Sharp AL series H4"
Your Xerox XD100 is made by Sharp
Mar 19, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
I have a Xerox Workcenter M20i.
You need to replace the fuser. There is a heating coil in the fuser roller that opens. Replace the fuser and it will resolve the problem.
Jan 25, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox workcenter pro 765 error 22
That is a fuser not reachine tremperature fault.
Most likely the fuser will need replaced.
Go to google and type in "the parts drop".
Call Britt and he should be able to fix you up with that part for a fair price.Just tell him the model number and code.
Aug 18, 2008 | Xerox Office Equipment & Supplies
315 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
