Question about Electrolux EIDW6305GW
How do I adjust the door on an eledctrolux EIDW6305GW so that the top of the door is level?
    New Friend:
  • 3 Answers
I dont beleive the door is adjustable, as that would make the sides out of square.
can you run a piece of beading/cover strip above it to take away the lopsided look?
Posted on Dec 12, 2012
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
How can I level the refrigirator doors
By adjusting doors you mean the reason door look uneven or doors wont close them self.
Door can be adjusted by proper level of the fridge. Please remember the front legs or casters should be raised, so the door swings close. Also the door is attached to hinges which have some leverage.
May 24, 2014 | Sharp SJPT640RS Top Freezer Refrigerator
The bottom freezer door on my Kenmore refrigerator 795.7900 pops open each time I close the top door. I have tried adjusting the leveling screws and it hasn't helped. Any suggestions?
Glen you keep adjusting but before that try to find this unusual problem. On its own, doesthe freezer door close witha thud? If not it needs adjustment otherwise other problems could surface.
Mar 03, 2014 | Kenmore 72912 / 72914 / 72919 Bottom...
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
Leveling a refridgerator
if not level you need to tip it back and unscrew or screw in the feet on it. use a 2ft level on top to be sure which way to go. if just the door, open door and there is a bracket in between the freezer and fridge and it should be adjustable a little bit. unscrew til lose adjust door to right spot and hold while tightening bolts. that should work. if the fridge door is on top and freezer is on bottom then adjust bracket screws on top of fridge.
Jun 24, 2012 | Stainless Cal Flame Refridgerator Steel...
How do i adjust the doors so they dont touch each other when the doors are closed.i.e. sideways adjust ment,not up and down,i can see how that is done
It is a leveling problem, not a side to side adjustment normally. If you have a titt - left to right or right to left - then the door are thrown out of alignment.
So if you put a level at the top and adjust the up and down until it is level side to side.
Aug 18, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
I have a Miele W404SB WPS washing machine. Water leaks out of the door during the washing cycle. Do you have any suggestions how I can stop this. Regards, Teresa Rooney
1. Make sure the washer is level first, with a small torpedo level at the top center edge of the washer ,check at the front and one side. If its not, adjust the 2 front level foot adjusters (at the front of the unit where they touch the floor) to level the washer.
2. If level is ok, check the door seal and replace if cracked or torn or old and hardened.
3. If ok, look at the latch on the door and the washer. Some have an adjustment for how far the door closes to latch. There will be 2 screws or small bolts you will loosen to slide the lever or the latch plate to adjust so the door closes tighter.
4. If ok, then the water level sensor will have to be replaced by a qualified tech.
Sep 04, 2010 | Miele W4840 Front Load Washer
How do you adjust a door on the refrigerator. Our
under the door ,on the hinge side, is a bolt to adjust the floor level.using a level, make sure the unit sits square, before raising with blocks all round.
Mar 31, 2010 | Kenmore 64802 Top Freezer Refrigerator
Leveling refrigerator
you might lower the front ones to get it level thats the only sloution i can come up with
Aug 04, 2008 | Maytag MSD2656G Side by Side Refrigerator
Electrolux EIDW6305GW Logo
98 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
