Question about Dell Inspiron 1525 Laptop
MY DELL LAPTOP SAY 0 % NOT CHARGING
I RECENTLY PURCHASED A NEW BATTERY FOR MY LAPTOP AFTER 2 WEEKS IM GET A MESSAGE 0% BATTERY NOT CHARGING IS MY BATTERY DEFECTION OR IS IT ANOTHER ISSUE?
    Novelist:
    Champion:
  • 233 Answers
If your dell 1525 runs normally on the inspiron 1525 charger, but the battery won't charge, please try the following troubleshooting steps:
1) Remove the battery from the system.
2) Look at the connectors in the bay and on the battery for signs of physical damage.
3) Check the battery charge by pressing the status button or image on the battery near the LED's. Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press on the butto, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flashm or blinkm there could be a problem with the battery.
4) Reinsert the battery; puch until it locks into place and the latch snaps back to the locked position.
Posted on Dec 13, 2012
  • 3 Answers
Take it back to where you bought it from for testing.
Try putting charger in a different power point.
Posted on Dec 12, 2012
LaptopExpert
  • 458 Answers
SOURCE: battery not charging. i have changed the battery and charger,stil
Run A BIOS UPdate For Your Make/ Model...
Your Laptop Doesnt want to recognise it because it is not an OEM part... BIOS Update should have a fix in it for that.
Posted on Nov 17, 2008
haayz
  • 197 Answers
SOURCE: Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Posted on Jun 04, 2009
  • 3940 Answers
SOURCE: Dell Inspiron 1501 will not boot with battery or adapter
Take the battery out and try with AC only, if no change, then you will likely need a motherboard replacement
DosHog
  • 168 Answers
SOURCE: My Dell Inspiron 6400 laptop battery isn't charging, I think :(
Debby
Try booting without the battery installed. You probably will have no change but this eliminates the battery as a source of the problem. If it doesn't boot and you are sure that the external power supply is ok, you probably have a bad motherboard. At that point, the unit needs to be checked out by a pro or a really competent amateur.
Posted on Aug 01, 2009
issken
  • 1472 Answers
SOURCE: dell 1525 not charging. dc usb board replacement
rubberman
Sorry to hear that you are still having trouble. The only other thing to try is your battery on your buddies notebook. If it works there then it is the charging mechanism on your notebook and this would mean replacing the motherboard.
Issken
Posted on Jan 11, 2010
New battery not charging
the old power supply must not be putting out enough power to charge
Jan 31, 2013 | Dell Latitude E6410 Laptop Computer (Intel...
I've recently bought a new charger for my dell inspiron 1525. The green light still shines when its plugged in, but it doesnt appear to be charging the laptop itself. Before, i would have put it down...
enter the bios with F12 and battery status somewhere, you have to see if the battery is charging.
1 - if you do not recharge the battery, you can try a new battery if the battery schimnabata no (new) option 2 then it does not load.
2 - is necessary to change the motherboard, because the battery charging mode does not function normally.
warranty if you go to them to do.
Feb 12, 2011 | Dell Inspiron 1525 Notebook
I have a Dell Inspiron 1525, I purchased a new battery and a new charger and I still getting the message that it's plugged in but not charging. What could be the problem?
Your problem is that the power jack in your actual laptop is loose. it may not seem like it is but one of the 3 connections (positive, negitive, data) that hold the jack to the board broke. In this case its the data connection that tells the laptop what kind of adapter is plugged in, and dell laptops wont charge without knowing that. Solution- 1.Pay someone to replace the power jack 2. If you can solder, by a new jack (around $5) and disassemble the laptop and replace it yourself.
Jan 13, 2011 | Dell POWER SUPPLY Power Supply
Hello, I recently purchased a new battery for my dell laptop as I thought that was the reason it was not turning on. After putting the battery in and letting it charge 12 hrs it still does not turn on. ...
Hmmm, that is a good one. I take it the battery is a brand new one as if it were second hand, it may be faulty.
Does the laptop work on mains power? If it doesn't then you have issues with the mother board.
Does the charge light flash? If it does the battery is still charging and needs more time.
It is worth contacting Dell direct on the www as they have a lot of usefull suggestions and there is no point in me adding them to this note.
Hope that helps.
Nov 06, 2010 | Computers & Internet
My laptop will not charge up, it only works when plugged in. Official message it give me is: 0% available, plugged in not charging.
If the system is in warranty, contact Dell and get a replacement Battery. If system is over a year old you most likely need to buy a new battery. If replacing the battery doesn't resolve, then it will most likely require a motherboard replacement.
May 14, 2010 | Dell Latitude E5500 Laptop
Apr 06, 2009 | Dell Inspiron 9400 Notebook
Battery is not charging
when you first purchased your laptop did you plug in your adapter to give your battery a full charge? If not then try a new battery when buying something like that always charge at least 12 hours before play.
Jan 08, 2009 | KDS Datamation Systems DS-8BY-BC-820...
Battery not charging. i have changed the battery and charger,stil
Nov 17, 2008 | Dell Latitude D505 Notebook
Dell Inspiron B130 Laptop
email me at meanness628@aim.com i am not on here every day i need more information on this problem
Sep 29, 2008 | Dell Inspiron B130 Notebook
Dell 600m Laptop Killing batteries
If you are using known good batteries, and you have the most current BIOS Flash, then it is likely a failure of the charging curcuit on the motherboard. The flashing Amber (Some people see it as red) led indicates a failed battery
The Multiple good batteries, I assume have been recently purchased, because computer batteries are consumable and are rated for 300 to 500 charging cycles before they wear out.
I replaced my 700m motherboard with one from Ebay for about $170.00 about a year ago.
Jul 05, 2008 | Dell Inspiron 600M Notebook
Dell Inspiron 1525 Laptop Logo
135 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
