Question about Hobart P660 Stand Mixer
What do I do to change my p660 from a 3 phase to a 1 phase
I have Hobart D300 mixer which operates at 220V, 3phase supply and whereas the facility has 208V, single phase supply. Is there any recommended phase converters available for this product. Thanks
Hi Bill
I may be wrong here......
But I've been around Electricity for a long time.
Have Never seen a device that does phase conversion.
A Building site or home will either have Three Phase or Single Phase Power Available
BUT...A portable (Hired) generator could be "three phase" and you could use any one of those phases individually or all three phases.
I have 3 Phase supply to my house!
But I use 230 volt Single Phase for appliances.
My Bore Pump uses a 3 Phase Motor,
(so with a voltmeter it would read about 440 vAC to the pump motor).
Some Further Info:
A GENERATOR is basically a motor used the opposite way. Rotate a motor and it Generates.
The Phases refer to the THREE Windings in the supplying generator in your suburb.
A Large Magnet passes each winding in sequence giving you the three ripples in the supply.
Our houses can choose to have 1 Phase or Three Phases from the street when you set up your electric supply.
So... to confirm, look at the wires on the supply poles to the premises. Usually three in our area (Oz)
Most people are not aware that a car Alternator is actually three phase. The Rotor is the magnet that rotates.
The only difference with an Alternator is that each "Phase" is connected to 2 Diodes (6 total) to convert the three phase to DC to charge the vehicle.
The Regulator controls the voltage to the Rotor, thereby controlling the output.
So.... An Alternator could in theory supply 3 Phase in a mobile generator. Custom Made. Constant speed would determine the frequency of 50Hz or 60Hz.
Not sure what country you are in
Hope this Helps or gives you food for thought!
Three phase electric power
Jul 08, 2015 | Hobart Food Mixers
What is hobart h600, single phase or 3 phase?
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Jul 09, 2014 | Hobart H600 Stand Mixer
Hobart am-12 manual and wiring
need to know if the motor on a hobart dishwasher model # am12 can be changed from 3 phase to single phase ? If so how ? I have no diagram on unit .
Jul 09, 2012 | Food Mixers
I have a: H-600T. Serial #11-369-290. Is this a 1,2, or 3 phase?
It's either 1 or 3 phase. Check the data plate. If it has a two pole contactor it is three phase, if it has a three pole contactor then it is three phase.
Jan 07, 2011 | Hobart D300-6036 Mixer
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
Need to convert 3ph to 1ph older h-600 model
that means changing mtr , contactors,that 1 phase is expensive never mind the kit to c/o keep 3 phase set up install a roto-phase in building, not a static phase inverter . the money you spend on coversion of mixer, i think the roto-phase is the cheaper of the two
Oct 07, 2009 | Food Mixers
Can I cange 3x230v up to 400v
Are you stating you have an A200 mixer that is 3 phase 230 volt?
I was under the impression all A200's were single phase. The D300 floor model came 3 phase. In any regard, to change the input voltage to any maching, you would have to replace the rotor, stator, and control group, including wiring. It has to be kept to orgiinal specifications, and tech support would have to authorise the change. As you can imagine, it's not really an option. If you change from 50 to 60 Hz, you would have to change your worm gears also.
Oct 03, 2009 | Hobart A200 Stand Mixer
This is a 3 phase mixer. Is it possible to connect it to my single phase bakery without buying a 3 phase converter?
no not without changing mtr. contactors,installing a roto-phaseinverter is the way to go dont get static inverter
Aug 27, 2009 | Hobart D340-6007 Mixer
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
Converrt USA electronic to european electronics
I have the same mixer and I moved from the States to the UK.  I just bought a really good power step-down converter (has to be step-down rather than a standard adapter, and watch the wattage of the adapter).  It worked fine.
Jan 15, 2008 | KitchenAid KSM50PR Professional Series...
Hobart P660 Stand Mixer Logo
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
