Question about Hardware & Accessories
How do I use the analogue glide down timer
This timer is fitted to a Gloworm Flexicom 30cx boiler
  • 5,245 Answers
1) Copy following link for setting analog timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/pdf/Glowworm-flexcom-analog-timer-manual.pdf
2) Add a comment Dec 2012 for additional information.
Posted on Dec 13, 2012
Boiler will not switch off
Morning, Many answers to this question. But usually if your timer is not shutting down you boiler its time to replace the timer. Try removing the boiler leads on the timer. (the loads). To see if this shuts down your boiler. We can try this step first.
Jan 11, 2014 | Hardware & Accessories
I am wanting to wire a Baxi 105E boiler to a Danfoss 102 mechanical timer. The boiler has 5 wires = red, blue, earth, black and yellow. The Timer has six terminals = 1 DHW, 2 HTG, 3 COM, I (earth), 5...
1) Contact baxi:
http://www.baxi.co.uk/contact.htm
2) Which boiler wires? I don't know. Page 24 manual.
Manual says to disconnect link between terminals 1 and 2, and instert timer in-line.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Baxi/Combi%20instant%2080E%20&%20105E.pdf
2) I can tell you about the timer wiring.
Timer is 230Volts
Not sure if you have British Hot-Neutral 230Volt, or Hot-Hot 230Volt.
Wiring is same 2 wires, but words to describe are different.
Let's say you have Hot-Neutral 230V
Connect Hot to L6
Connect Neutral to N5
This will power the timer so it runs and keeps time.
You can get Hot-Neutral wires from Hot-Neutral that arrive to power the boiler.
Now the timer terminals are separate.
E terminal is Earth or ground.
The Common is Hot wire.
The timer then turns on-off and switches back and forth between DHW and HTG.
HTG is heating
DHW is defrost.
Timer has 2 sets contacts.
When timer activates first set of contacts, then DHW defrost terminal receives power from Hot wire on Com terminal. At this time, all power is cut to HTG heating terminal.
When the defrost cycle ends, then the heating circuit receives power, and then the timer has programming that opens and closes a second set of contacts going to HTG heating terminal.
Which wires from boiler connect to each terminal, I am not sure.
Feb 03, 2013 | Hardware & Accessories
F9 on gloworm cx24
its pressure problem make sure the pressure is at 1.5 bar heres a link to the manual http://www.glow-worm.co.uk/stepone/data/downloads_sd/b6/00/00/flexicom-cx.pdf
Feb 10, 2011 | Heating & Cooling
My gloworm 30cx boiler keeps showing fault f1, what does it mean ?
Low gas pressure or flow: make sure you have gas to the unit.
Dec 19, 2010 | General Heating & Cooling
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
Gas boiler cuts out after about 60 seconds
It may be fixable but any work done on any gas appliance must be done by a properly qualified person and in the UK must be Gas Safe registered. I am not nor do I claim to be so registered, this is for information only.
Jul 03, 2017 | Uniflame 200209 Open Flame Patio Heater
Boiler keeps losing pressure when the heatings off
Hi Leehardcast,
Yes the problems are related. The system is low on water. So now instead of water you have air in radiators which is easily compressed when it heats up. Then pressure loss when it cools down.
Add some water to your system until you have 15lb pressure and bleed out upstairs radiators at the same time.
Please rate this response and Good luck, Phil
Jan 13, 2009 | Watts 3/4 Pressure Relief Valve
Hardware & Accessories Logo
128 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
