Question about Boating
Bushings freedom vacuum
Can bushings be replace on Simplicity Freedom Model F3400
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
You need to replace the Brushroll. The bearing are pressed in. You can get your Brushroll here.
If you have any questions feel free to contact me.
Tim
TheVacCenter.com
Posted on Mar 13, 2013
SOURCE: Freedom 20 stopped working after ac breaker tripped
How do you get the PCB out all the 4 screws are out and clips are pushed off the pcb contacts on the sides. Unscrewed the antenna, but not the soldered in bulk antenna mount. I is still locked in somehow? how do I get the board out to look at the keypad buttons so I can see if threre is a bad contact?
Posted on Sep 11, 2009
  • 91 Answers
SOURCE: Wiring Freedom 20 inverter
make sure your new inverter is made for 220 volt supply as that is what the red wire represents. its the other leg of a 220 circuit and should not be connected to your new inverter until you read the manual to see if it is designed for this and if so how to wire it in. it could cause you are the unit serious harm if you connect a 110 inverter to a 220 circuit. consult an rv repair shop or a good electrition if you cant find the needed info. it may actually be printed on the side of the inverter as well.
Posted on May 28, 2010
  • 17 Answers
SOURCE: I need a replacement comm board for a Xantrex
I have the same unit that the charging function just died on. If I can't fix it and have to buy a new one, you can have my comm board for free. Should know my status in ~ a week .
Posted on Sep 27, 2010
  • 17 Answers
SOURCE: The cooling fan in my
Yes, *if* you can find an exact replacement and get someone to sell it to you. In order to protect their propriety designs, Xantrex only provides OEM replacement parts to its factory authorized service network, but you might find one of them locally who would be willing to sell you the part, especially if the unit is on a boat (a Marine Freedom 25?), and can't be brought to them.
mwoodring1
  • 496 Answers
SOURCE: I have a xantrex 2000 watt freedom 458 freedom
this isn't an answer but i would like to just clear the water a little. how old is the unit? you say it the inverter works when on shore power ( 110v A.C. wall plug or 220 ) but it will not charge the batteries while hooked up to shore power? are you trying to use a generator to run the inverter and charge the batteries? I just need to a little more so i can better understand you problem and help you better
Looking forward to hearing back from you.
M.Woodring
Posted on Jun 21, 2011
I have a simplicity freedom Model S10E we cleaned out the hose and now it will not self adjust to my carpets. I have one carpet that is higher and its hard to push and I have a rubber smell
The rubber smell is the belt slipping up against the roller since it does not have enough friction to fully turn the roller. Either fix the adjustment for a high carpet or install a tighter belt that can cope with the job.
Sep 06, 2017 | Simplicity Vacuums
Simplicity freedom vacuum will not self propell ?
there is a seperate belt.one that turns the brush,one for propell..
Dec 13, 2015 | Simplicity Vacuums
I have a simplicity freedom F3700.2 upright vacuum. It has been working wonderfully until now. I plug it in and it won't start. I have tried removing the bottom and cleaning the roller, the bag isn't...
Sounds like a break in cord or plug somewhere. I am not familiar with the particular vacuum myself. Another thought I have when looking around your vacuum cleaner have you seen a red reset button anywhere at all?
Or by chance does your vacuum cleaner have a plug comes off....... (i.e. like a computer)
a few thoughts
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Sep 02, 2013 | Simplicity Vacuums
Im trying to replace a fan on a simplicity freedom f3300 vacum. HOW DOES THE OLD FAN COME OFF? It seems to be pressed on but I dont want to brake anything.
Assuming you have the motor out of the fan housings, check to see if you can move the fan around clockwise/counter-clockwise. If the fan is not moveable, the fan has probably melted to the motor housing. Replacing the motor is recommended as the plastic motor housing under the fan is probably damaged/melted. It could still be fixed but there is a possibility of damaging the housing. If after removing the fan following the directions below be sure to remove/trim any melted plastic away from housing before replacing fan. Not trimming the plastic could result in your new fan melting again to the housing when the machine is turned on. If you have an older model pay careful attention to the carbon brush area, if there are plastic posts holding the carbon brush springs, these are easy to break.
If the fan is movable, remove the nut and washers from fan. Use two large flat head screwdrivers and place them opposite of each other under the bottom lip of the fan between the fan and motor housing. (it might be a little easier if you have an extra pair of hands to hold the motor). With the flat heads in place, push the handles of the flatheads toward the side of the motor where the belt shaft is. If the fan does not pop off rotate the position of the screwdrivers and try again. Pay close attention that the fan washer is installed before replacing your new fan. after installing the new fan, rotate it several times making sure it isn't rubbing anywhere.
If you need any further help feel free to contact me.
Tim
TheVacCenter.com
Mar 02, 2013 | Simplicity Freedom Cord - F3300 -...
My freedom vacuum does not have enough suction to pick up dust, it just pushes it ahead.
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Aug 20, 2010 | Kitchen Ranges
The plastic bushings in the weight plates of my Spirit Freedom Series 1 are loose and need to be replaced. Where can I get replacments?
You may have to call spirit direct to to find out if they even have these bushing. Call them @ 1-800-258-8511
One Other place I found a plastic bushing is at www.fit-senior.com
| Fitness Equipment Replacement Spare Parts | Weight Stack, Weight Stack Keys and Weight Stack Plates | Weight Stack Plates & Bushings
Jun 12, 2010 | Exercise & Fitness
Simplicity freedom vacuum has a burnt rubber smell
If the belt is continually wearing out I would think that the brush cylinder is not free to rotate. Take the belt off and ensure that the brush cylinder moves freely. If is does not, then you need to investigate why - probably something wound round it that has jammed it.
Apr 06, 2010 | Simplicity 7250 Deluxe Vacuum
Hi. I purchased a Simplicity Freedom about 2 years ago. I have had it in for various repairs several times. One persistant problem that the repairman cannot seem to fix is the dirt does not fall down into...
You can let the vacuum run alittle longer so the bag fills up with air, also make sure that the bag in on correctly and you have the right bag for the unit. Let me know if this helps.
Oct 12, 2009 | Simplicity Vacuums
Simplicity freedom model f3300 makes loud noise when running.
sounds like the fan might be broken in the motor
Oct 02, 2009 | Vacuums
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
