I recovered an old kyocera. I would like to reset IP address, but pressing system menu has no effect...what's should I do to enable the system menu. Thank youI recovered an old kyocera. I would like to reset IP address, but pressing system menu has no effect...what's should I do to enable the system menu. Thank you
You can't post conmments that contain an email address.
Do you suggest, should I use the application "Driver KX" to access IP parameter of the printer ?Do you suggest, should I use the application "Driver KX" to access IP parameter of the printer ?
Documentation said : start system menu -> go to IP register. But pressing menu system button has no effect. Screen doesn't display the menu system. Any help ?Documentation said : start system menu -> go to IP register. But pressing menu system button has no effect. Screen doesn't display the menu system. Any help ?
i am also having same problem no effect after pressing system menu/counter button ..please help if you have any solution ..i am also having same problem no effect after pressing system menu/counter button ..please help if you have any solution ..
Ensure that you have the appropriate network key code needed to
enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address
restrictions, you will require pre-authorisation for the router. You
will need to find your Samsung Jet's MAC (Media Access Control)
address. This is a 12-character code which may be needed by the network
controller to enable the phone to connect. See Getting the Samsung
Jet's MAC address below.
You can get to the Wi-Fi
application either via the main menu or using a homescreen Wi-Fi Widget.
To get to the Wi-Fi application via the main menu, press the MENU
button (either on the home screen or the hexagonal button beneath)
In the main menu, swipe your finger sideways to go through the
menu
pages until you see the Wi-Fi icon. Press to
select.
The Wi-Fi application opens.
Alternatively, to
use the Wi-Fi Widget, from standby, press the home screen. The Widget
toolbar opens up.
Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi
Widget. The Wi-Fi Widget will pop
up on the main screen.
Press the Wi-Fi Widget on the main part of the
display to launch the Wi-Fi application. The Wi-Fi application opens.
Once
in the Wi-Fi screen, press the large Wi-Fi button in the middle of the
screen to turn it on. Wi-Fi is activated and the
button turns blue.
Press SEARCH Nearby Wi-Fi access points (APs)
will
appear as small circles on the display, with their names next to them.
Press the circle representing the Wi-Fi Netowrk you
want to connect to. An options panel appears.
You can press
CONNECT to
connect to the network or
press ADD if you want to add it to a list of preferred
networks for easy access later.
You are taken into a settings
menu for the Wi-Fi access point. If the Wi-Fi access point requires a
network key code,
scroll down to the Network Key panel. Press
to select.
The numberpad appears. Type in the network key code
and press DONE. You are returned to the previous settings screen. Press
SAVE
A list of connections
appears. Press the back arrow button
If you initially pressed
CONNECT, the phone will
connect to the selected Wi-Fi network and a confirmation message will
appear. The display now shows the new connection, illustrated by blue
dots linking the circles onscreen (Figure 15).
If you initially
pressed ADD, you will be returned
to the Wi-Fi screen. Press the circle representing the Wi-Fi network you
want to connect to. A pop up panel appears.
Press CONNECT. You
will be connected and the
connection illustrated onscreen.
Press the back button to return to the home
screen.
From the home screen press MENU to enter the main
menu (Figure 1).
In the main menu, press INTERNET
Choose which
browser option you want (Home, Enter URL, Bookmarks,
etc.) (Figure 18) and press to select. If you press Home you will be
taken to the pre-loaded home page.
If required, use the
numberpad to type in an URL or scroll a list to
select bookmarks. When an URL is completed press GO.
Alternatively press the bookmark you wish to access. You will taken to
the web page requested.
Activate Wi-Fi and press SEARCH,
as before.
When the Wi-Fi access point you want to connect to appears on
the
display (Figure 8), press it to select.
A pop up options panel
appears (Figure 9). Press DETAILS
Details of the Wi-Fi access
point appear onscreen.
Scroll down by dragging your finger up
the screen. Towards the
bottom of the settings list, DEVICE MAC appears, with a
string of 12 charactesr beneath (Figure 21). Each handset has an
individual MAC address, and this panel will display your Samsung Jet's
unique Mac address.
Make a note of the MAC address. You will need it if you want to use
the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC
address restrictions. This can be added into the wireless router
settings access list.
Hi, you will have to factory reset! Follow these instructions:
A.) With the device powered off, press and hold the volume up button (keep holding), then press and hold the power button at the same time. Keep holding both buttons. The Cruz logo will appear, you may then release the buttons. Then the Android robot and software package icons will appear on the screen.
B.) The moment you see the Android robot, you will need to access the System Recovery menu by pressing and holding the Power button, then tap the volume up button once, releasing both. This is in the opposite order of the sequence in Step A.
NOTE: The volume up button on the T408 is toward the power button, while the volume up button on the T410 is away from the power button.
C.) In the System Recovery menu, use the volume toggle to navigate up and down through the menu and hightlight your selection. Use the power button to activate your selection. Select the option that corresponds to clearing cache and data. Once completed, select the option to reboot your device.
Hello * Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items. * Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button 8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
hi, hard reset your droid to delete all info..do this trick
1.power off, then.
2. power on holding the power button and the camera button together, a
prompt will appear to release the camera button, release it .
3. D.O,S prompt appears
4. select system. recovery (volume down) you will get a exclamation mark with a triangle,
5.hold the menu button down an to the left for 30 sec.(square pad)( this may take several tries to activate the blue screen)
6. the touch screen is now active use the menu/scroll an highlight factory reset an press ok.
7. when done high light menu back option ON THE SCREEN an press ok.
hi do the follwing setting on your projector to reset the lamp hour
1.Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button to move a red frame pointer to SETTING Menu icon 2 Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button. The message "Lamp replace counter reset?" is displayed. Move the pointer to [Yes] and then press SELECT button. 3.Another confirmation dialog box appears and select [Yes] to reset Lamp Replace Counter.
After replacing all the items in the photoconductor kit, reset the maintenance counter:
1 Press and hold the Select and Return buttons while you turn the printer on.
2 Release the buttons when Performing Self Test appears on the display.
The printer performs its power-on sequence, and then Config Menu appears on the
first line of the display.
3 Press Menu until you see Reset Maint Cnt and then press Select.
Reset appears on the second line of the display.
4 Press Select.
Resetting Maint Cnt Value appears briefly on the display, and then is replaced
by Config Menu on the top line and Reset Maint Cnt on the second line.
5 Press Menu until you see Exit Config Menu, and then press Select.
Activating Menu Changes appears briefly, followed by Performing Self Test.
The printer returns to the Ready state.
