Question about Sewing Machines
I have a Pfafp1475CD it needs a fuse & green batteries
It needs green batteries and a new fuse which i have no idea were to find it on my machine the fuse that is.
  • Sewing Machines Master
  • 7,365 Answers
It should tell where the fuse is in the manual. here is a link for a
manual
http://sewusa.com/Sewing_Machine_Manuals/Pfaff_Manuals/1475_CD_Instruction_Manual.htm
or check the base plate area
Posted on Dec 12, 2012
Hat is voltage on 3.15 amp fuse and 2.5 amp fuse for Elna 7200 Pro Quilters Dream sewing Machine
I would not worry about the voltage, it's the amp rating that really matters. Match the size and amp rating, and you should be good to go.
If the fuse keeps blowing, that's an indication that there is something seriously wrong with your machine.
Jul 14, 2015 | Elna Sewing Machines
Machine left unused for a long time;pedal & everything missing except the machine itself ; The problem is: when I plugg & switch the machine on, in the display nothing appears ! HELP!
No make or model mentioned. Guessing, some models have fuses in bottom of machine in base, then again some have a couple back up 1.5 batteries in base which can leak and cause a disruption of an electrical circuit. Other than that take to certified repairman or contact me for more ideas, need Make and model. Thanks, hope it helps.
Apr 02, 2015 | Sewing Machines
I just bought a Singer Stylist 457.
if you bought the machine used, then it's possible that a
cam or gear is either worn or damaged. & needs to be check at a sewing machine shop.
if the machine is new,,then take the machine back to where you
bought it & tell them about the zigzag, even let them try it & see
what happens, I been sewing for over 30 years & I wouldn't keep
it,, if you bought it new,, I'd get another one
Aug 10, 2012 | Singer Sewing Machines
Bobbin case falls out and will not catch upper thread
try a new needle--make sure the presser foot is at it's highest
position
also make sure the bobbin is not damaged or warped
clean under the needle plate & in the bobbin area for lint or loose threads
the bobbin case or the hook & hook race may have to be
replaced. it would be a good idea for the machine to be check
Jun 05, 2012 | Singer 2263 Mechanical Sewing Machine
Need fuses for janome 4000
You can get the fuse at Radio Shack. Part number 270-1065. It is a 3.15 amp 250 volt slow-blow fuse.
If you replace the fuse and it blows again, you need a new A circuit board part number 829606005.
Nov 03, 2010 | Janome Memory Craft 4000 Sewing Machine
What is the blue wire for:; Is it positive or negative please what is the brown wire for: Is it positive or negative and is the yellow and green the...
Blue = Neutral, Brown = Live and you are correct Yellow & Green = Earth
The live wire (brown) must be connected to the fuse if there is one.
You could say that the blue wire is negative (or zero) and the brown wire is positive as this is the one the high current passes through. The blue wire completes the circuit, which is needed for current to flow.
Hope this helps!
Oct 13, 2010 | Riccar Sewing Machines
E1-Error message is apparently the fuse were is
The E1 error message. This is due to the fuse having to be switched from the 2.5 amp to a 3.5 amp. they did not recall the machine because of the low cost $2.99.
The Fuse is Located on the Board itself.
I guess the Part Number for your model is 000182177.
You could Purchase that from :-
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=000182177&productGroupId=0020&supplierId=385&pathTaken=&filterPart=&pop=flush
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 23, 2010 | Kenmore 19233 Computerized Sewing Machine
NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Oct 24, 2009 | Singer Featherweight 140Q
Machine has stopped completely
This model is known to blow the fuse (3.0 amp) in the power board. A repair shop can replace it with a new style one (3.15 amp).
Jan 26, 2009 | Janome 6019QC Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
