My laptop screen regularly turns black even though the computer is still on. If I close the lid and open it again and press the on button it usually comes back on. I have changed the time out settings
If it does not turn on when I re-open the lid I then turn it off with the power button and reboot completely. I then choose the safe mode and the computer will boot successfully but it will randomly turn black again and I have to start all over again! Help please. I am afraid that I will lose access to all my files and photos etc. next time.
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Dec 12, 2012
Soulvisitor
  • 1113 Answers
SOURCE: Incomplete Boot-up of Compaq Evo N800c running Windows XP Professional.
Your problem is not a capacitor problem, that is so remote of a possibility it is it's a one in a million!
I Have read all the info here and find Darklord has already posed the correct solution (with explaination) 3 days ago,
Have you since verified hard drive and I'm just missing that fact?
Posted on Jan 10, 2008
rickyostrom
  • 270 Answers
SOURCE: Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
Posted on Nov 30, 2008
leecom72
  • 4806 Answers
SOURCE: cannot start up the laptop
Hi there.
That really quick flash of a blue screen is the blue screen of death and there is a possibility that the error could be memory related.
What you have to do is remove and clean the system memory and the slots the memory goes into.
Take out the battery and the AC power (if attached)
The memory will be located behind a panel underneath the laptop, unscrew the panel unclip the memory, clean the brass contacts and the slots with a clean, dry, soft paintbrush, then reseat the memory making sure it clips into place, replace the memory cover and reboot the laptop, see if it lets you into windows.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
Posted on May 20, 2009
  • 12 Answers
SOURCE: Toshiba Satellite Goes completley off! Black screen, NO POWER!
This problem is likely caused by overheating. The CPU reaches a temp to high and shuts the system down. When you try to turn it on the system is still to hot and it will not let the computer power on. You can try blowing out the fans and heat sink with an air compressor or can of compressed air. If this does not help the problem you may need to have thermal compound reapplied. If that does not fix it it will need a new heatsink/fan/
Posted on May 21, 2009
SOURCE: Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
Posted on Oct 01, 2009
My laptop shows black screen after turn on the system there is no start up display in screen.
Possible faulty backlight. Wait for boot-up and then close the lid or press the power button to put the laptop into sleep/standby mode. Open it up again and see if the screen comes on.
Aug 30, 2011 | Computers & Internet
Everytime I lock my computer,shut the lid or leave it untill it goes black, it will not come back on when I touch the mouse pad. However when I got this laptop it worked and when I opened the lid and...
Well by default Closing the Lid will cause computer to go to Sleep mode and you can't wake it up using mouse. However you need to press power button to wake it up.
But as you said it was working the way you explained then seems like Power settings on your computer are changed
To check the settings Got0 -Control panel and click on power Options Goto - Advanced and find the Lid open/close actions You can change it there If you don't want your computer to goto sleep mode with the lid close, you can simply disable it.
Hope this worrks
Jul 14, 2011 | Computers & Internet
If my battery gets too low or i put the computer into sleep mode the screen goes black, i cant figure out how to get the screen back on besides popping the battery out and restarting the computer. please...
In my experience, i will press the power button(if my battery gets too low and the screen get black), then the laptop will get to the previous screen automatic As the set of my laptop is that, when I closed the lid, laptop will go to sleep but not turn off, and the laptop will woke up after I opened the lid. try and to see anything helpful?
Apr 15, 2011 | Lenovo IdeaPad Y430-3231U Notebook
Hi i have an msi u130 and i got a problem when i turn on the minilap shows a black screen and the led of the little moon its ON but doesnt work what can i do? please help me
The moon icon usually indicates that your machine is in SLEEP mode. Try closing and opening the screen lid. If not, there might be a problem with your laptop waking up from sleep mode. Try holding the power button. This will turn it off. Turn it on again by pressing the power button once more. Hope this helps! Have a nice day.
Apr 11, 2011 | MSI Wind UmNotebook
Hope this helps
Oct 01, 2009 | Dell Inspiron 1300 Notebook
The screen on my Lattitude 120L won't come on after I close it
goto control panel click on DISPLAY then screensave then POWER SETTINGS and on the left side there is a section called what to do when i close my lid click on that and for lid settings click on do nothing so after u close ur lid it wont disable ur screen
email me at dragonslair2@hotmail.com
names mark
Jul 18, 2009 | Dell Latitude 120L Notebook
Screen stays black after closing and then opening Inspiron 6000
you try pressing the power button once?  or maybe even pressing any keys.
also try adjusting your power management
vista) start. control panel. power option.  Edit plan settings.
xp) right click anywhere.  properties.  screen saver tab.  power management.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
IBM Laptop A2629 LCD Problem
sounds like your video is going out wheather its your card or lcd not sure but kinda sounds like the screen
Dec 24, 2008 | IBM ThinkPad A20 2629 Notebook
Screen went black
When you close the lid, there is a small pin that engages the case and flips a switch to tell the laptop the case has been closed. The monitor will ALWAYS turn off then, because otherwise, the heat build up would burn the screen! Do not try to defeat this, replacing an LCD screen is usually more expensive than the value of the laptop!
Now, that all being said (and please remember), the situation you have now is (hopefully) just that the laptop tried/succeeded in going into ACPI "suspend" or "hibernate" mode.
1. Remove all cables and 10/100. Remove all USB devices. Just leave the PSU (AC power supply) connected.
2. Press the power button firmly, JUST once. Wait. And I mean WAIT, because some laptops can take 2 minutes or more to come out of suspend/hibernate, if they were very busy at the time it was shut down.
3. If the LCD screen lights up. you are done. But if it does not light up now, then proceed to step 4.
4. Press and HOLD the power button down for 10 seconds. This forces the laptop to shut down completely, even from suspend/hibernation. Some unsaved files may be lost, but tghe laptop goes cold, so you can start ACPI over again.
5. After a few minutes, press the power button again, firmly, just ONCE and for 1 second max. Laptop should start up OK.
6. Once it starts up, go to START MENU/SETTINGS/CONTROL PANEL/POWER SETTINGS and search for the "hibernation" tab. Turn hibernation OFF. your laptop obviously has some problems or lack of responsiveness with hibernation (most do). Use suspend, instead. It is much safer,. faster, and still does a good job of saving HDD and LCD wear. Please let me know how this goes for you, there are other more detailed problems that may be involved here, but I suspect this is most likely.
Feb 11, 2008 | Dell Inspiron 710m Notebook
Computers & Internet Logo
David Payne
David Payne
