Question about Kyocera FS-1118 Printer
How change the IP ?
I need to change the IP of the printer. How to enable the system menu/counting ? When I press the button system menu I can't enter to the menu... is there a secret code ?
It keeps saying "menu disable"
Please try to do the following steps to enable menu
1 Turn the printer off.
2 Press and hold Select and Return and turn the printer on.
3 Release the buttons when you see Performing Self Test.
Config Menu appears on the first line of the display.
4 Press Menu until you see Panel Menus, and then press Select.
Enable appears on the display and press Select.
5 Locking Menus appears briefly.
6 Press Menu until you see Exit Config Menus, and then press Select.
Sep 12, 2011 | Lexmark T630 Laser Printer
How can I cancel incoming fax on lexmar x646e
If the printer is connected to a network, get the IP address of the printer and access printers web interface. You may print a network settings page to get the IP address of your printer. Open a web browser and type the IP address on the address bar.
On the left side, click on the configuration menu and click on fax settings and select fax setup. Under fax receive settings, please uncheck enable fax receive.
You may also do this using the printer's operator panel. Just press on Menu button and select settings. Select fax settings and analog fax set up. Select fax receive settings and turn off enable fax receive then press submit.
Jun 20, 2011 | Lexmark X646e All-In-One Laser Printer
Is this unit (Tally 2265+) possible for LAN interface? If that so, can you give me a step by step method to do. Thanks!
The 2265+ has a LAN interface as standard, you do not need to install any options.
You can set the IP Address Via the control panel, go to the I/F section then select "Eth".
Set the IP Method to STATIC if you manually want to set an IP address.
By default the 2265+ has DHCP enabled so if you have a DHCP server the printer will obtain an IP address.
You can confirm the IP Address by printing out a configuration menu page;
Start with the printer Powered OFF
-Press and HOLD DOWN the SETUP button, and power the printer on.
-When the printer finishes initialising release the SETUP button. (this unlocks the menu)
-Ensure the printer is OFFLINE
-Press the SETUP button
-Press the BUTTON under MENU on the LCD display(Button 1)
-Press the BUTTON under PRINT on the LCD display (Button 2)
-The printer will print a menu configuration.
May 03, 2011 | TallyGenicom 2265+ Matrix Printer
Please tell me how to configure ip address in printer 4350
Press Check mark (SELECT button) to open the menus.
2. Use (UP button) or (DOWN button) to scroll to CONFIGURE DEVICE menu, and then press
(SELECT button).
3. Use (UP button) or (DOWN button) to scroll to I/O submenu, and then press
(SELECT button).
4. Use (UP button) or (DOWN button) to scroll to EMBEDDED JETDIRECT MENU
5. Use (UP button) or (DOWN button) to scroll to TCP/IP
Then: Select whether the TCP/IP protocol
stack is enabled or disabled. You can set several
TCP/IP parameters.
Select the TCP/IP CONFIGURE METHOD to
configure the EIO card. For the MANUAL option,
set the values for IP ADDRESS , SUBNET
MASK , LOCAL GATEWAY, and DEFAULT
GATEWAY
Nov 14, 2010 | HP LaserJet 4350 Printer
Fatal error 428056ec + 4280999c
Hello.
Try resetting the printer:
  1. Power on printer while holding both the "+" & "-" buttons simultaneously; release when "OKIUSER" is displayed.
  2. Press either the "+" or "-" button until "ENGINE DIAG MODE" is displayed; press "Enter" and "DIAGNOSTIC MODE xx.xx.xx" will be displayed.
  3. Press and hold both the "-" & "On-line" buttons simultaneously until "ENG DIAG LEVEL2" is displayed.
  4. Press either the "+" or "-" button until "CONSUMABLE COUNTER SET" is displayed, press "Enter" to go in the menu to set various consumables.
  5. Press either the "+" or "-" buttons to go to the desired consumable and press "Enter": the last digit of the count will start flashing.
  6. Press "Cancel" to decrease the digit amount or press the "On-line" button to increase the digit amount; press the "+" or "-" buttons to move along individual digits in the count.
  7. Once the count is at the level you desire, press and hold the "On-line", "Cancel", and "Back" buttons simultaneously until the "*" reappears next to the count; consumable's count has been reseted to the number specified.
  8. Press the "+" or "-" buttons to move to the next consumable and repeat at step 5.
  9. Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, use the "Back", "+", and "-" buttons to exit through the menus (reverse of steps 2 through 4) until "INITIALIZING" is displayed.
  10. Turn off the printer and turn on.
Hope this helps.
Nov 08, 2010 | OKI C5400 Laser Printer
I changed the IP address range of my LAN and need to assign the new range of addresses to my HP printer P2015dn
Press the Menu button on the printer to open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
Then set the Subnet Mask IP address to 255.255.255.0
Jan 13, 2010 | HP LaserJet P2015dn Printer
Error 55.1 and also language need to change english
get the relevant firmware update from the hp website and update the firmware ( I think there is a firmware update manager for hp printers so maybe check that out )
Also with regards to changing to english you may be able to do that through the web interface using its ip address or if you do the following
Set the default language and paper size by performing the following:
  1. To start press the button (CANCEL JOB) to make sure that the printer is on ready state.
  2. Press the button (SELECT) to enter the main menu.
  3. Press button (RIGHT ARROW) one time to enter on main menu / system setup.
  4. Press the button (SELECT) twice to enter the system menu / language.
  5. Press button (RIGHT ARROW) until you get the desire language.
Apr 20, 2009 | HP Color LaserJet 2600n Printer
Tcpip is disable on a xerox 8550 printer. How to enable it manually
Here are the steps to set up a static IP on your printer.
  1. With the printer displaying 'Ready to Print', press the [Up] or [Down] arrow button on the Control Panel and select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Connection Setup], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Network Setup], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [TCP/IP Setup], and then press the [OK] button.
  5. If necessary, press the [Up] or [Down] arrow button to select [TCP/IP], and then press the [OK] button to select [On].
  6. If necessary, press the [Up] or [Down] arrow button to select [DHCP/BOOTP], and then press the [OK] button to select [Off].
  7. Press the [Up] or [Down] arrow button to select [TCP/IP Address], and then press the [OK] button.
  8. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the address.
  9. Press the [OK] button to accept and move to the next three digits. Repeat until the required IP Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  10. Press the [Up] or [Down] arrow to select [TCP/IP Network], and then press the [OK] button.
  11. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the network mask.
  12. Press the [OK] button to accept and move to the next three digits. Repeat until the required Network Mask is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  13. Press the [Up] or [Down] arrow to select [TCP/IP Gateway], and then press the [OK] button.
  14. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the Gateway Address.
  15. Press the [OK] button to accept and move to the next three digits. Repeat until the required Gateway Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  16. Press the [Up] or [Down] arrow to select [Exit], and then press the [OK] button.
May 20, 2008 | Xerox Office Equipment & Supplies
Putting right the ip address ?
Before you proceed you need to know the static IP, Subnet Mask and Gateway address for this printer. Once you have them: -Enter the menu mode by pressing the + button -Press the + button till you come to the Network Menu. -Press the Enter button. You should now see TCP/IP. Make sure it says Enabled which is the default setting. -Press the + button till you come to IP address then press the Enter button. - IP addresses (for now) consist of four octets or four groupings of three numbers such as in this example *192.168.001.123*. Using the + or - buttons (+ counts up 0,1,2,3?.; - counts down 255,254,253?..) you are going to set the number of the first octet or in the case of the example *192*. Once you?ve set it correctly hit the Enter button. -Do the same for the other three octets. Hitting the Enter button after setting the fourth octet will set the new IP and take you back to the TCP/IP menu. - Press the + button till you see Subnet Mask and press the enter button. - Just like the IP address the Subnet Mast consists of four octets. Set the value to you needs just as you did with the IP address. Again when you hit the enter button after setting the fourth octet you will be taken back to the TCP/IP menu. - Again press the + button till you come to Gateway Address and hit enter. Enter the Gateway IP address exactly like you did when setting the IP address. Don?t forget to hit the enter button to set the address. You should now be at the TCP/IP menu again. -To exit the menu press the On-line button on the printer. Your printer should now be configured with you IP address, subnet mask and gateway address. As an added check I would go back into the menu by pressing the + button, going into the Information Menu and printing selecting the Print Menu Map option. Verify the setting we just made with what is printed out at the top of the page. If everything matches you?re ready to go! Let us know how it goes and please don?t forget to rate this posting.
Jan 22, 2007 | OKI C5100n Laser Printer
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if donĀ“t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
Kyocera FS-1118 Printer Logo
22 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
