Question about AOC Envision L32W461 32 in. LCD HDTV
My 6 year old 32inch envision tv no longer has picture or sound anymore even after its properly connected to cable
First of all I got a white screen with a green bar running down the middle of the screen. then I turned it off now theres no picture or sound whatsoever and its still connected to the tv and cable digital box.
    Top Expert:
  • AOC Master
  • 14,553 Answers
Based on the brand parts may not be available and six years is better than average life for this type of set.
Posted on Dec 12, 2012
The 32inch flat screen tv has sound but no picture the screen turns blue
If the TV is still under warranty return it ASAP. The set will need to be serviced
Oct 22, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Bought an 32inch LCD HDTV DVD Combo not even a year ago---there is picture but no sound---can't turn up sound with remote or even turn up sound manually--any ideas?i
Good day!!!
That problem is usually cause of low reception if you are using aerial antenna,if your are using cable or digital signal check your wiring and the worst is you have defective audio IC..
I will teach how to determine the exact trouble just click this link LCD HDTV ASSUMED TO FIX and click "get service"..
Thanks for using fixya...
Nov 03, 2011 | RCA L32HD32D 32 in. LCD HDTV
The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
Mar 08, 2010 | Daewoo DVRS04 DVD Recorder/VCR
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
Envision LCD TV L32W698 has no sound suddenly
Check to make sure its not muted, if not then your main board most likely has failed
Dec 28, 2017 | Televison & Video
I can't get a picture on tv when turn on dvd player why? brand new, never used before.
have you connected the DVD into the right plugs, also are you using the correct AV channel on the TV?
RED WHITE YELLOW yellow is video red is L sound White is r sound. check both TV input and DVD output
Aug 14, 2009 | RCA DRC8335
Philips 7 year old 32inch cuts off while a high pitched buzzing sound stays until the tv is switched off at the mains
IF PICTURE PULLS ON RIGHT ADJUST BRIGHTNESS AND AND TINT UNTIL SCREEN SHOW FULLY AROUND PICTURE
Apr 04, 2009 | Philips 32PT5441/37 32" TV
Shaky Picture only during Advertisement or... Mitsubishi SC 27403
If you have cable then put the cable wire directly in the TV, bypassing the cable box. If the pix is Ok it proves that the problem is the cable box. If the problem is still there then it proves the the TV needs parts inside.
Mar 24, 2008 | Televison & Video
Picture wont turn on
Red LED flashes probably five times.
You have not mentioned the model no, so I have to guess it is few years old model.eg FE2 chssis or similar.
Most common reason, R618 270k ohms in power section has gone high.
Second, screen voltage control is slightly misaligned.
Third, high value resistors on tube base, normally two connected to screen voltage control pot have gone high.
You need to have some knowledge , a multi meter and soldering iron and know safety procedures before trying yourself.
Regards
capital98
Nov 30, 2007 | Televison & Video
AOC Envision L32W461 32 in. LCD HDTV Logo
161 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
