I have no sound but perfect picture TCL l32m61az can you help
Was working last night and was on standby, had a major storm and now the picture works but no sound
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Remove set and a cable or sat box or a receiver if in line , remove all from power for several minutes and then power back, a reboot may help and cannot hurt.
Posted on Dec 12, 2012
  • 33 Answers
SOURCE: Flashing Standby Light - Sony 40 in Bravia
Similar problem. Unplug for 36 hours solved the problem.
Posted on Aug 31, 2009
Shuttle83
  • 1139 Answers
SOURCE: toshiba 50in plasma
Hello brattbabie1,
Ok you have sound and no picture. This denotes that since this is a plasma TV the circuitry that controls the activation of the screen may have become defective. You will need the schematic to show the voltage levels that need to be present on the cable that connects between the screen and the control circuit and a voltmeter to measure those voltages. I would suggest that you get a qualified TV technician to work on this problem, due to the technical nature of this issue.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 10, 2008
  • 58 Answers
SOURCE: sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Posted on Dec 08, 2008
  • 30 Answers
SOURCE: Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Posted on Sep 26, 2009
Testimonial: "A quick one to respond with a good answer to the problem."
SOURCE: Phillips 42" LCD, turned off last night, turned on
LCD inverter backlight board is out 42pfl7432d/37
Posted on Jan 15, 2011
TCL model:l32M61AZ. how do I get a channel?
usually by setting it to the proper input .then do an autoscan for channels
Oct 24, 2015 | Televison & Video
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
Tv does not turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_19_2012_1_16_49_pm.jpg
Apr 18, 2012 | Televison & Video
I own an LG 42LB1DR-UA. After a major lightning and thunder storm last night, I see that there is no voice when watching cablevision which is hooked up with HDMI cable. When I use other cable [3 color], I...
Sir try to use a dvd and put a movie if your unit produce normal sound and picture the problem is the digital receiver. Good day and best regards.
Aug 19, 2011 | LG Televison & Video
Need a user manual for TCL TV Model L32M61AZ
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 03, 2011 | Televison & Video
I have a 50 inch avol flat screen. it has worked perfect for the year i have had it, last night put it on sleep timer and now the sound works but there is no picture, please help
I'm fixing a tv with this same problem. I think its the glass / flourecsent bulb, all my boards are good and clean no burn marks and no fuse issue. Also i checked all my capacitors, I all ready broke the glass trying to remove it so i don't recommend that but after i replace it , if it works i will let you know. but the bulb/glass is only thing that makes sense if everything has power and it hasn't been in a electric storm. and the bulb/glass is soldered with cables and that has to be where the light comes from.
Sep 07, 2010 | Televison & Video
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
No picture, no sound, standby button doesn't work normally
Make sure all your connections are tight and if you're using hdmi try using component cables.
Feb 04, 2009 | Sony Playstation 3 (PS3) Console
Circuit board was damaged in electrical storm. Replaced with new board. Now, screen comes on full raster, but with retrace lines. Picture is very faded and barely visible behind lines. Sound is OK and...
I am unable to find in your statement about which brand or type of motherboard is used. One thing i come to know your using service mode kit. knowing in your statement your are a technical person. My simple idea is first you set the TV in standby mode using remote. Then in FBT reduce the screen control minimum position, the release standby. Now the tv is oscillated, now slightly increase screen control till get maximum video and zero retrace line set in position. Even no improvement give me clear picture of brand and microprocessor ic etc. there is a chances to solve by having the above details.
Aug 27, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Electro Med Services...
