How to adjust bass and treble
SOURCE: Unlock Philips HTS-3565
Hi
TURN ON THE PLAYER
PRESS OPEN/CLOSE TO OPEN THE TRAY
WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL BE DISPLAYED.
PRESS "0" TO UNLOCK ALL
PRESS "OK"
SOURCE: Region Unlock code for Philips HTS 3152
Thanks dude,
Not sure which trick worked, but i did ur classic 7,3,4,4,6,6,0 trick, got no message from the player. So i did pressed 0000 after that. Still no message appeared. But when i pressed start....it worked!!!!!!
Thanks a ton!!!!!!!!!!!!!!!!!!!!!!!!!!!!! God Bless...
SOURCE: finding treble and bass adjustments on my stereo
Here is a manual for the radio. If you go to page 14 it will tell you how to set the EQ.
http://vault.alpine-usa.com/products/documents/OM%20CDA-9835.PDF
Good Luck Please Rate FixYa!
SOURCE: adjust
I have an Alpine CDA-9813 and to access bass, treble, fade, and balance, you need to press the volume button. This button is usually rotated to adjust the volume but on mine, if you press it in, first time accesses bass, second press accesses treble, 3rd press accesses balance(left to right), and 4th press accesses fading (forward to rear. Press it a 5th time and it either brings you back to volume or back to the main screen. I think it is volume tho. I would assume that the 9853 would work very similar, if not the same.
SOURCE: HOW TO ADJ. REAR SPEAKERS AND BASS,TREBLE , ECT. THANK YOU
the option will be available on your remote... tell me the product name and model..
