Question about Behringer Dsp1124p Feedback Destroyer Pro with Parametric Eq
How do i hook up a feedback destroyer to my EQ,COMPRESSOR,COSSOVER
  • 109 Answers
Put at end of the chain. In this order: (1) EQ (2) Compressor (3) Crossover, (4) Feedback Destroyer.
Posted on Jan 16, 2013
2 Suggested Answers
  • 4234 Answers
SOURCE: how o u hook up
In order for this to work properly it must be inserted between the last pre-amp stage and the power amp. Can you please update this with the mixer that you are using? With the make and model of the mixer, I can provide you with a connection description. Since each mixer will have different labeling and options, it is not possible for me to accurately describe the connections without hte make and model.
Thanks,
Dan
Posted on Feb 02, 2011
Excessive feedback
On mic? On guitar? Take top frequencies off EQ, point mic away from speakers. Use decent dynamic mic or feedback resistant condenser such as Sennheiser e865. Try Behringer feedback shark
Feb 06, 2014 | Music
What is the best way to connect an external EQ or Feedback Destroyer unit to a Behringer PMP3000
Get an "insert snake" which splits each of two TRS plugs into TWO TS plugs.
Plug the TRS ends into the MAIN INSERT jacks and each of the "TIP" plugs at the other end into inpout jacks of the destroyer. Plug the "RING" plugs into the output jacks of the destroyer. You will need a snake with at least two sets of splits. I use a Behringer PROCOM compressor. For those the TRS plugs go into the channel insert jacks and the tips and ring plugs go to the in and out of each channel of the compressor respectively.
Jan 11, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
No problem. just bought it and a pair of thump 15s what cables are best. and we want to play our accoustic gigs through this and dont know how to set eq i know its different each room but a starting point.
Use balanced lines for the audio interconnects. Use XLR low noise mic cables or TRS type cables. IMPORTANT: Power the speakers and the mixer from the SAME receptacle, even if it means running extension cords. Ground bounce in building wiring can destroy the circuits in the equipment.
Jul 11, 2011 | Mackie ProFX12 Professional Compact Mixer
APX900: Feedback at seemingly normal playing volumes. I've had this problem playing both indoors and at outdoor venues. I use a Fender Passport 250 sound system and run my guitar through a Digitech...
Make sure the passport speakers are NOT where the guitar can hear them... they need to be toward the audience from where you are. Also do NOT boost the high end frequencies with the EQ. That guitar probably has a hot pickup subject to ambient sound. Beyond this, you might have to use one of the feedback destroyers. If you are using monitors, take the guitar out of them.
May 03, 2011 | Yamaha APX900 COMPLETE GUITAR BUNDLE
Do i leave feedback ferret on all the time or take it out when feedback is measured
Normally you find where feedback occurs, notch it out with the EQ and recheck for feedback. When system is stable you can take out the ferret.
Feb 04, 2011 | Peavey 32fx USB 32 Channel Mixer
How o u hook up behringer feedback destroyer to a powered mixer
Thanks,
Dan
Feb 02, 2011 | Behringer Dsp1124p Feedback Destroyer Pro...
How to connect feedback destroyer pro dsp1124p ?
It all depends what you are connecting it to... Essentially wire it someplace between the preamps of microphones and the power amps that drive speakers. The only stipulation is that you want the levels to be "line level" signals.
If you are using a powered mixer, you will do this as an "insert" using the insert effect jacks. The preamp signal goes to the "in" of the destroyer, and the "out" goes to the following amp.
Dec 13, 2010 | Behringer Dsp1124p Feedback Destroyer Pro...
Show me how to hook up the Behringer destroyer pro?
What are you going to hook up to?
Essentially you connect the power cord to power and connect outputs from say a mixer to the inputs using TRS balanced cables... and connect the outputs of the unit to your power amplifier.
Note taht there are MANY other possibilities using "inserts:on some devices.
Dec 02, 2010 | Behringer Dsp1124p Feedback Destroyer Pro...
Hello, Effects and EQ hook up problem
Many of those connections REQUIRE using TRS cables (stereo style) rather than TS cables (mono style). It is possible you have mixed the cables if it worked before.
Any cable plugged into an "insert" should be a TRS (tip-ring-sleeve) cable.
Look up these connections in your 1604 manual.
Feb 18, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Behringer Dsp1124p Feedback Destroyer Pro with Parametric Eq Logo
96 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
