Question about Sewing Machines
Cotton snapping on back stitch - Sewing Machines
  • Sewing Machines Master
  • 1,564 Answers
That sounds like a needle timing problem. Since you gave no info on your sewing machine... please take your machine in to your nearest authorized dealer for clean and adjustment.
Posted on Dec 15, 2012
  • 32 Answers
SOURCE: Top thread snapping during quilting
Have you tried bees wax?
Posted on Aug 06, 2009
SOURCE: top stitch ok, underneath 'birdnesting' then
Clean shuttle and shuttle race fee of lint. If problem persisists please report again
Posted on Oct 17, 2009
  • 1116 Answers
SOURCE: tention on light cotton stitches too loose
If your sewing machine has a pressure control for the presser foot, loosen it or move to a lower number, however it is set up.
Make sure to thread your sewing machine with the presser foot up as this has a major impact on the stitch formation.
Posted on Mar 05, 2010
  • 1564 Answers
SOURCE: i have a brother vx-1125 the cotton keeps snapping..but the tension is correct..please advise..
I agree with Debbi. Tension adjustments must be made with each change in fabric type and thread type.
You don't say whether the thread breaks at the top thread or the bottom thread. Maybe more detail is advisable.
Posted on Aug 17, 2012
SOURCE: overlocker cotton onleft needle snaps
1. Try rethreading the machine
2. Is the needle inserted correctly
3. Is the needle bent
4.is the tension adjusted correctly
5.is the tension adjusted to accommodate the thickness
Of the thread being used
6.is the thread good quality thread
7.is the thread feeding off the cone or spool freely
8.is the needle size correct for the type of fabric being used
Posted on Oct 11, 2012
What stitch should I use to sew stretch cotton fabric
Hard to tell because your machine is unidentified.
Jul 14, 2017 | Sewing Machines
Janome mylock 134d
Hi ,
Make sure your tension is not to tight and that there is now fluff or cotton stuck in between your tension plates. I sometimes use a string of the stitch to pull in between the tension plates. I always set the needles tension first and then i balance the tension of the upper and lower looper.
Make sure the cotton are not looped around a guide. Black cotton and some cottons can build up their own tension. Try different cotton. I\'ve had many a headache with this problem.
Check that the needles are not blunt or bent. I always use schmetz needles. If your needle plate has any damage where the cotton can get hooked. Use a small file or sand paper to remove it. The stitch tongue must be very smooth and the stitch must slide of smoothly. Check that your lower looper point does not have a sharp hook on it. You can use a very fine water sand paper to remove it.
If your needles are touching the looper, i could indicate that your lower looper is out of position. *.*(Always check this with new needles)
Regards
Rob
www.electronicrepairs.co
Dec 30, 2013 | Sewing Machines
Singer featherweight 11 cotton keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 28, 2013 | Singer Featherweight II 117
Cotton is bunching up on the bottom of the fabric and then it snaps
Do you happen to have your feed dogs lowered? Tighten the top tension a bit and make sure you are holding both threads when you start a seam.
Also make sure you have recovered all needle pieces.
Dec 11, 2012 | Sewing Machines
Overlocker cotton onleft needle snaps
Oct 10, 2012 | Sewing Machines
Tention on light cotton stitches too loose
Mar 03, 2010 | Sewing Machines
When I start to sew, the top thread breaks, before it makes a stitch.
obviously you've slackened off the tension so thats not the problem, try changing the neddle as some times they get a sharpe edge that cutts the cotton as soon as tension is applied, if the needle passes through the plate before it snaps the timing may be off.
Aug 23, 2009 | Sewing Machines
Thread loops on back using quilt stitch
You need to put more tention into the Corners, Try puttin a tention of 10 into the Quilt. And it should work fine. 10-12 Maximum, don't go pass 12 because it will probably Rip, or Shrill up. Hope this Helped.
Thanks for Using FixYa! -CA
Jul 14, 2008 | Elna Quilter's Dream 6003Q
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
