Question about Ricoh Aficio Sp 1000sf All-In-One Laser Printer
Ricoh sp 1000s multifunction printer doesnt work with windows 7. Any solutions?
  • 111 Answers
SOURCE: cannot faind Ricoh Aficio SP C410DN Laser Printer driver
you can find the driver here http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11540&ricohmodelid=6342&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fcl410%2Fcl410en%2Ehtm
Posted on Mar 21, 2009
EmmettPinger
  • 63 Answers
SOURCE: Ricoh Aficio SP-C210SF
driver mismatch don't use the postscript driver unless you have the option installed as an option
Posted on May 01, 2009
EmmettPinger
  • 63 Answers
SOURCE: Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Posted on May 04, 2009
Ickoajnc
  • 183 Answers
SOURCE: I just bought a Ricoh Aficio SPC232SF
Hello
Well you do not need to return the printer because the files you have downloaded are drivers just they are installing on other way.
If you follow the explanation in the text below it will be very easy.
First as you say i think that you had already unzip the .exe file or if you did not follow the next steps:
1. Create one folder on the desktop named as you want or as the name of the printer for you after easy to find it.
2. double click on the " r41337en.exe " file that you had downloaded from the web site and click browse to find the folder that you had previously created on your desktop when you will locate the folder click unzip and after the message "successfully unzipped files " close the self executing program and see do in the folder are some files if there are some files, continue with the next step.
3. Click on the " Start " menu,
from the desktop in the left down corner,
and then click on "devices and printers"(doubleclick)
4. One window will open and than in the upper left corner you will find "add printer", click that button and it will appear a "add printer wizard" , click twice on the button "next" and select up the port you will use for the printer (do it will be a USB connection or with network cable is up to yours notion)and after you will select the type of connection click "next" again.
5. On the wizard on the right side has a button named "have disc" click on it,
it will appear window named " install from disc " than click the button named "browse" and then browse the folder which you had previously created on the desktop, in which you had unzip the files for the printer installation.
6. When you will locate the folder click on it with double click, then will apper folder named " DISC 1" click and on it with double click and then will appear file named " PCL6.INF " click on the file with double click ,
7. Then will appear a window named,
" install form disc" click on the button "OK" ,
then click on the button "next" three times and then click "Finish "
That is all the printer is now installed and ready for use.
Please answer do this was helpful for i to know do i need to post some more information
If you need something else please ask
Regards
Posted on Jan 13, 2010
Dicedonions
  • 118 Answers
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Posted on Apr 29, 2010
Scanner not seen under windows
Can double check the model number please as our ricoh system doesnt have that model number. otherwise contact our support office from 8.00am to 5.00 pm Mondays to Fridays
Level 2, 60 Stanley Street, Parnell
P.O. Box 68-024, Newton
Auckland 1010
Phone 09 - 374 0701
Fax 09 - 368 6001
Email ricohnz@ricoh.co.nz
Mar 07, 2014 | Ricoh Aficio SP 4410SF - multifunction fax...
How to enter SP Mode for Ricoh Aficio sp 3200sf
"Menu" ? "#" ? "1" ? "9" ? "3" ? "4" ? "Menu"
The display shows "Tech Mode> Tech menu"
Press "OK" to enter Tech menu.
Jun 06, 2012 | Ricoh Aficio SP 3200SF Multifunction...
How i can operate my ricoh sp 1000s/aficio 1000s if it writen fuser temp
It is strongly recommended to call an authorized technician to reset and fix this problem because defected parts must be replaced/repaired before resetting these errors otherwise it may result in fire or other damages.
Nov 30, 2011 | Ricoh Office Equipment & Supplies
I have Printer and Scanner type: ricoh aficio sp 1000sf But now I don't have driver for it So, I need printer driver, scanner and fax driver of ricoh aficio sp 1000sf
Hi Mach,
Click on the download link below to goto the driver and software download page of Ricoh.
Download Link
E.g : If I want the printer/scan/fax driver for windows 7, I will click on the download icon under Windows 7 as shown in the image.
shreysri_7.png Regards,
Shrey
Jun 02, 2011 | Ricoh Aficio Sp 1000sf All-In-One Laser...
I have a Ricoh sp c222sf multifunction machine. I'm running Windows 7. I loaded a driver for both the printer and the scanner from thier website. All seemed well until I went to scan from the ADF. It...
u got to unscrew the scanner a bit and arange the adf left or right depending your line position. the adf is not positioned perfect on the machine , and at the end it scan the adf back , thath is the line come from on your scanned document
Feb 02, 2011 | Ricoh Aficio SP C222SF All-In-One Laser...
I need driver for Ricoh aficio sp 1000s, can you help me
Here is a link to the driver for the aficio sp 1000s:
http://support.ricoh.com/bb/html/dr_ut_e/rcn/model/sp1000/sp1000en.htm
Choose your operating system and download the appropriate driver for it.
I hope this helps,
Adam.
Jul 21, 2009 | Office Equipment & Supplies
Linux driver for aficio sp 1000s
Ricoh support is assisting and we hope to get it solved
Jun 02, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio Sp 1000sf All-In-One Laser Printer Logo
74 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
