Question about Samsung Refrigerators
What starting relay does the sd162q-lou2 take
I need to put a relay in my fridge because its making a clicking sound how do i take it out the old relay KIC motor is samsang SD162Q-L1UA W51
if it is clicking, I would say the relay is working. The question would be "What is making it go on/off?"
Nov 28, 2016 | Refrigerators
The Asd and the fuel pump relay will start to click fast and then they'd slow down and stop,then it would start,but now the relays won't start clicking at all
Could be corrosion. The ASD runs all the others. Start by pulling it out and putting back in. If it still doesn't work, swap it with another relay, Not the fuel relay. If it starts, replace the relay. If still no start, you need to start checking the relays power and ground. Check fuses also.
Mar 06, 2016 | Cars & Trucks
Car wont start turn ignition to start nothing happens,checked relays,turned on ignition jumped starter car started right up.wont start by useing ignition
Try replaceing starter relay with another of your relays. make sure they have the same part number on them if you switch them and it starts replace relay with new.
Feb 20, 2015 | 2004 Lincoln Aviator
Does the main relay being bad make your car not start sometimes
Relays rarely go bad. If you have on that gets really hot. It could be the relay or the wiring. And yes, main relays and even secondary relays can keep an engine from starting/running. First check which relay is getting hot. The swap it with another relay in the panel. If it still gets hot. you will have to start checking the wires to it. If the relay you swapped to other spot gets hot, replace the relay.
Nov 05, 2014 | 1992 Honda Accord
2004 Nissan armada we changed the fuel pump and a new battery but it still won't start like if gas is not passing thru??
check you fuel pump relay. located on IPDM marked as ECM relay in the picture. Just change places of ECM RELAY and FOG LAMP relay and try to start. If it starts change the ECM relay. good luck
Feb 22, 2014 | Cars & Trucks
Engine wont turn
1. Make sure your battery is fully charged.
2. Check connections from battery to starter relay.
3. Make sure you have voltage going to the start side (small wire) of the relay with the key in the "start" position.
4. If you don't have voltage going to the start side of the relay (small wire) with key in the start positon, then your starter switch is faulty (under dash usually mounted on top of steering column).
5. If you have voltage to the start side of the relay (small wire) with key in start position, and it don't click when trying to start your car, then the starter relay is bad.
6. If your starter relay clicks, but engine don't turn over, then the starter is faulty.
Dec 09, 2013 | Cars & Trucks
Started relay in a 1999 Altima
Dec 08, 2013 | Cars & Trucks
1994 astro van wont start seems like no fuel,how to test fuelpump?
If you don't have fuel pressure test equipment then try spraying engine starting fluid in the air cleaner if it starts then you probably have a bad fuel pump, fuse or relay. The easiest is to check all your fuses if they look good. Look for the relay center under the hood the cover to the relay center will tell you which relay is the fuel pump relay. Try swapping relays with one that looks the same in the relay center. If it starts after swapping relays then you have a bad relay. Hope this helps you :)
Dec 17, 2010 | Chevrolet Astro Cars & Trucks
No start condition new battery , good starter, turn key to start position light come on dash, go forward to start light go out and you hear click under dash area like relay, no power getting to starter....
no starter relay is always at the fuse relay box at the engine compartment. The relay that you hear is the relay for the accessories to turn off the power during starting position.
Feb 01, 2010 | 1999 Ford Windstar
I hear a buzz sound for 5 seconds when compressor starts.
The grommet simply holds the start relay in place.  Unless it is torn, you won't need it.  Likely the start relay.  The buzzing is possibly the relay contacts on the start relay burning if the problem occurs when the compressor starts...although it could be the compressor making noise as well.  You might try to "hear it out".  The start relay gives a boost to the compressor by adding in another winding inside to 'kick' the compressor.
If all you hear is the buzz, you might just wait a bit to see what fails!
Nov 14, 2008 | Refrigerators
Refrigerators Logo
70 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
