Question about Sterling Plumbing Home
How do I stop shower taps from leaking - Sterling Plumbing Home
    Sergeant:
  • 462 Answers
Remove fawcet handle take out the cartride and replace the rubber oring and bevelled or flat rubber washer on end make sure to shut off water supply first if cartridge is in bad shape buy a new replacement one at hardware or plumbing store reinstall
Posted on Dec 12, 2012
2 Suggested Answers
  • 54 Answers
SOURCE: leaking faucet
Most likely bad solder joint or leak where shower arm is screwed into fitting.
Posted on Sep 26, 2009
Have changed all washers and reseated taps in shower but shower head still leaks
hi mark.
this is all i could find on the internet,if this is no good to you go to the link at the bottom and see if it helps you out.
First, feel the water leaking from the tub spout or shower head. If it's warm, you know that the leak is coming from the hot-water valve. If the water has been dripping for a while and it is cold, the leak is probably coming from the cold-water valve. 1Start by removing the faucet handle.22 Nov 2016
How to Repair a Leaky Shower Faucet Valve - HomeTips
shower head leaks Google Search
Nov 18, 2017 | Home
Methven beta shower mixer rose is leaking
the problem will be at the tap washer
replace it and the water will stop from the rose
Sep 23, 2016 | Home
Why would my shower switch back on after turning it off
What brand and what type of tap is it.? Delta single lever, or is it an older type of 2 handle tap?
Apr 20, 2013 | Home
My shower faucet is leaking
this could be abad tap washer
a faulty loose pipe connection
or a faulty tap
turn of your water supply at the outside your house before proceeding
remove the handle on your tap then remove insert screw valve usually with a spanner or shifter
you should see a copper or plastic stem inside with a flat washer at the end which
http://www.videojug.com/film/how-to-fix-a-dripping-tap-bib-or-pillar
hope this helps
Nov 06, 2011 | Moen & One Handle Tub & Shower Faucet
The cold water stop working in my shower. I have a
Two posebel coses i can think of.
1. the taps plunger is stuck in the off posision or 2. there is dirt loged in cold side of tap.
take off head part of cold tap and c if mabe the rubber is stuck or if u maby see some dirt in the tap ietself
hope it helps
Jul 11, 2010 | Price Pfister R897EBK Brushed Nickel...
Got a gocta w-26mixer shower bar fitted cold tap
from a plumber all hot and cold connections on all major showers are hot on the left and cold on the right just like the taps on your sink or washbowl
Dec 09, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Leaking faucet
Sep 26, 2009 | Home
SHower noise
Loose washer in hot or cold tap. Replace or tighten.
Sep 10, 2009 | Water Pik Shower Head
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Home Logo
737 people viewed this question
Top Sterling Plumbing Home Experts
Donni Steen
john h
Mike
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
