Question about Juicers
Juice comes out from spout and from point where chrome and black parts of juicer connected.. Can juicer be separated at this point?how can I get all juice to flow through spout only? KitchenAid juicer model #KJEmodel
  • 6 Answers
SOURCE: Juidelady jl500 juicer replacement parts
I also have a Juicelady, & need a part(s) HEre is a probable solution to your problem!
In the U.S.A. or Canada call 1-800-233-9054 to order the part. Or see if they have it in stock.They will ask for your address & phone number. Have your serial number ready-it should be on the bottom (or possibly the side) and you may need a magnifying glass to read it! It starts with the letters JL, and mine was JL500 (so look for that-but your may be a different model, I gave you mine so you have an idea of what to look for.)
Note: Anywhere else, or to check them out online:
The same warehouse is also at foxinternational.com if you'd rather see what they offer that way--but we got our call answered after waiting les than a minute. They even had the part we require but won't ship to Canada, so if your Canadian--call anyway, as it is a different part than we required,( the arms that brace the unit together.)
Hope this was helpful for you!
Posted on Oct 21, 2008
SOURCE: rival juice extractor model 965
I HAVE LOST THE BOOK AND PAPERWORK TO MY RIVAL JUICE EXTRACTOR MODEL 965. IS IT POSSIBLE TO GET ANOTHER BOOK AND PAPERWORK FOR IT?
Posted on Jul 12, 2009
SOURCE: My champion juicer won't expell pulp propperly.
Use the tamper?
Posted on Nov 20, 2009
  • 356 Answers
SOURCE: Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
Posted on Apr 04, 2010
  • 154 Answers
SOURCE: The juicer overheated and stopped working
The motor sounds like it overloaded, I doubt it has a thermal cutout fitted (in which case you could leave it off for a while and see if it works) I doubt it has this feature and if it is the motor then the unit should be replaced.
Posted on Jun 20, 2010
Do u have Panasonic Juice Extractor model: MJ 66PRA parts? Spout Cover!!
Fixya does not sell parts. Check with a local appliance parts distributor or directly with Panasonic.
May 25, 2016 | Panasonic Juicers
My juicer leaks under the spout. I can not figure out why. I have checked all the assembly and all the directions. It is only the second time I have used this. My machine is brand new. Any though
The spout, itself is hinged. It has two positions, an upper and a lower position. (Similar to a light switch). Make sure it is in it's lowest position when making juice, otherwise the liquid will collect in the inner bowl and leak out the sides of the juicer. Move the spout to the upper position to temporarily stop the flow of juice, such as when you change glasses or receptacles. Then, put the spout in the lower position to resume the flow of juice.
Dec 26, 2012 | Jack Lalanne Power Juicer 250 Watts
How do I remove the grater/filter from juice collector to clean it? Also the juice collector from the drive shaft? Thanks
You have to lift off the juice collector (the black part around the grater)-you have to use a little force-then you'll be able to take out the grater.
Jan 10, 2011 | Maximatic EJX9700 Juicer
Can't find the manual and have forgotten how to take it apart to clean it
Most juicers have a retention rod or side snaps that hold the top of the juicer in place. By loosening these, it will allow you to get underneath the juicer cap top. Once you have done this, you will have to remove the juice/ pulp wheel blade. Your juicer should have come with a two pin tool that facilitates this. Use the tool to loosen the juice /pulp wheel blade. Once you have done this, you should be able to remove the outer juice capture rim with that has the spout on one end. I hope this helps. Good luck and happy juicing.
Jul 18, 2010 | Juicers
Spout
Try this site for the juicer part you need ..
https://www.unitycart.com/pjss/accessories/parts_elite.asp
Please vote !!
May 12, 2010 | Jack Lalanne Power Juicer 250 Watts
Jack la lanne juicer
Heres where you can buy a new one:
https://www.unitycart.com/pjss/accessories/parts_classic.asp
Aug 05, 2008 | Jack Lalanne Power Juicer (Stainless...
Juicelady JL500 parts
Order Juice Lady replacement parts at 800-233-9054
Jul 21, 2008 | Juicelady JL500 Juice Extractor
How to dissassemble Jack Lalanne Power Juicer?
After about a half hour I finally figured it out. I'll go through all the steps.
1. Remove pusher from chute.
2. Pull the locking bar down over the spout.
3. Remove lid.
4. This part is tricky. Stick the orange crescent tool into the blade holes and while holding the filter basket steady with one hand, turn the blade couterclockwise while pulling up.You do have put a little muscle into it. And remember, if you don't hold the filter steady, the whole damn thing just spins.
5. Remove the receptacle.
Good juicer, but it seems unnecessarily complicated.
Jan 01, 2008 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
Top Juicers Experts
eyecam
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
