Question about Fuji FinePix 2800 Zoom Digital Camera
My computer will no longer recognize the camera
I never used to have this problem. When I connect the cable into the usb port to download my images, nothing happens. When I go under "My pictures" and attempt to choose my fuji fine pix 2800 to download my images, its not listed. I have tried numerous times to down load my fujifilm fine pix to my computer, but only the fujifilm 700 is listed. I even tried the CD rom but nothing works. This is a new problem. I would always work as soon as i plugged the camera into the USB port with no problems. I hope you can help.
Mate I had the same thing happen to me, the problem is the batteries ...... sounds odd but it was for me at least. I have 4 rechargable batteries, if you remove the power lead while doing transfers and just let the batteries do the work ... all should be fine. Now why would this be a problem i dont know. Whatever it is, SOME batteries are not compatible when the power is plugged in. Check it out and let me know pls Albert, Brisbane albert58@aapt.net.au
Posted on Jul 13, 2007
Maybe you need to add a software driver for your FinePix 2800, got a disk with the camera? Try loading (reloading?) the driver.
Posted on Jun 11, 2007
Hi, I have a JVC GR-D750AA digital video camera. I do not know how to download the things recorded to my PC. I have also bought the USB cable n tried but the camera USB port is not recogned by the PC. I do...
Turn the power switch on your camcorder to "Off." Connect the USB cable that came with the camcorder to the USB port on the camcorder. If you are using the DV cable, connect one end of the cable to the computer first. Put the other end of the USB cable into the USB port on your computer. If you are using the DV cable, connect it to the camcorder. Power on your camcorder. Wait while your computer recognizes the attached JVC GR-D270U camcorder. Typically you will get a pop-up on your screen asking how you want to proceed once the camcorder has been recognized. Open your video editing software, such as Adobe Premiere, Roxie, iMovie or Windows Movie Maker. Import, or capture, the video from the camcorder to your computer using the video editing software. For example, in iMovie you click on "File," then "Import from Camera" to download the movie from your camcorder to the computer.
Jan 13, 2018 | JVC GR-D275 Mini DV Digital Camcorder
Trying to download apps but it won't register the fact that my calculator is connected
Use the TI USB Silver cable or a standard USB to Mini USB. The calculator shipped with one or both cables.
Before it can be recognized you must install the drivers. Download TI connect and install it on the computer before connecting the calculator. If you use the Graph link (black cable) you need to have a serial port on the computer.
COM3 is serial communication port. On newer computers (laptops) that port is no longer available.
Feb 03, 2012 | Texas Instruments TI-84 Plus Calculator
Hi, I can not tranfer images from camera to computer using a usb cord. I tried 2 different cords and 4 different computers. I do not have a card reader, so please don't ask me to go purchase a card...
Emily,
We need to rule some things out. Do the USB cables you're trying to use work on other "known to be good" devices? Do not reuse any cable(s) that doesn't work, even if new. Once you have a cable that has been proven to work, try connecting the camera to the USB port on the computer again. Make sure the camera power is OFF while connecting to the computer. Only after connecting should you turn camera power ON again. You can review the whole process starting on page 147 of the manual.
If it doesn't work, it is possible that the ports you're trying to use is either 1) defective or 2) overloaded. Try connecting to a different USB port on one of the computers. If you don't have another USB port, or if it still doesn't work as expected, remove all the devices connected to the USB ports that are not needed to operate the computer. This will lower the amount of power the computer needs to supply to USB devices (some - but not all - computers will flash a message on the screen if there's too many devices connected). Reconnect the powered off camera and try again after turning back on..
If you're still having a problem, suspicion turns to the camera's USB port. Resolving a problem within the camera will likely be the most expensive fix. It took considerable restraint, but I didn't even mention the other solution ;-)
I hope this helps & good luck! Please rate my reply - thanks.
Feb 11, 2011 | Canon EOS Rebel XSi Digital Camera
I get an error message in the Olympus software that the computer cannot recognize the camera's connection to the USB port cable so I cannot download any images. The USB port works for other devices but...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Sep 23, 2010 | Olympus FE-170 Digital Camera
When I connect the cable to the USB port the computer no longer recognizes the camera connection.
You may have to reload software that came with camera. Or go on line and search for it. It is also possible that your USB port is bad. Try a different USB port on your computer.
Jul 13, 2009 | Fuji FinePix S3000 Digital Camera
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
Camera No Longer Being Recognized
Does it connect to the PC via a USB cable? Then try connecting to a different USB port or if you have try a new USB cable. I had the same problem with my IXUS 400 and changing to a new USB port, directly to the PC - not a USB hub, it worked. However now I have several issues with my camera - no sound or image on the LCD screen, but I think these are unrelated.
Jan 27, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Download images to view the computer
With the camera turned off, connect the USB cable to the PC and plug the smaller end into the camera. The camera will turn on and display the selection screen for USB. Use the arrow keys to select the PC option and then press the OK button. The camera will be recognized by the computer as a removable drive. There are instructions available at our web site (http://www.olympusamerica.com/download). For editing and managing image files with a PC, install the Olympus Master 1.0 software from the supplied CD-ROM. After installing the software, connect your camera to the PC via the USB cable provided.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Download images
With the camera turned off, connect the USB cable to the PC and plug the smaller end into the camera. The camera will turn on and display the USB selection screen. Use the arrow keys to select the PC option and then press the OK button. The camera will be recognized by the computer as a removable drive. To edit and manage images with a computer, install the Olympus Master 1.0 software from the supplied CD-ROM. After installing the software, connect your camera to the PC via the provided USB cable.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Download images
How do I download images from the camera to view on my computer? With the camera turned off, connect the USB cable to the PC and plug the smaller end into the camera. The camera will turn on and display the selection screen for USB. Use the arrow keys to select the PC option and then press the OK button. The camera will be recognized by the computer as a removable drive. There are instructions available at our web site (http://www.olympusamerica.com/download). For editing and managing image files with a PC, install the Olympus Master 1.0 software from the supplied CD-ROM. After installing the software, connect your camera to the PC via the USB cable provided.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Fuji FinePix 2800 Zoom Digital Camera Logo
96 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
