Kwikset 4  Lido Lh Passage Levers Satin Chrome 200ll 26d Logo
A
Anonymous Posted on Dec 12, 2012
How to replace missing thumb press for door handle
Thumb press is missing, but door can open if us flathead screwdriver to unlatch
1 Related Answer
Anonymous
  • 963 Answers
  • Posted on Mar 06, 2011
SOURCE: We have the thumb press elongated handle on the
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
1helpful
2answers
How do I remove the front driver side power window switch on a 2008 Buick Enclave
Armrest Door Pull
Remove Rubber Cover
Remove 10mm *****
The first step is to pry out the plastic trim plate behind the chrome colored door release handle using a small flathead screwdriver.Then remove the 10mm ***** behind the plate using a ratcheting wrench with an extension bar attached.
Next pry out the rubber cover at the bottom of the door pull located in the center of the arm rest. Use a Torx T-25 (star bit) screwdriver to remove the two screws.
Remove Torx T25 Screws
2 T-25 Torx & 1 10mm *****
Pry Up Arm Rest Panel
Use a flathead screwdriver to pry up the rear of the plastic arm rest panel. There is a plastic hook at the front of the panel, so only pry it up from the rear edge.
Lift Rear End First
Plastic Hook At Front of Panel
Power Window Connector
After you lift out the arm rest panel, you'll need to disconnect the power connector for the window and door lock switches.
Push Connector Release Tab
Power Connector Unplugged
Two More T25 Screws
Push on the release tab with a flathead screwdriver and pull out the power window / door lock connector.Use a Torx T25 screwdriver to remove the two screws located below the arm rest panel.
Remove T25 Torx Screws
Outer Edge of Panel
Push In Center of Fastener
Then move to the outer edge of the door panel and locate the two small round fasteners. Use a small screwdriver to pop in the center pins of the two fasteners.
Pull Out Plastic Rivet
Black Plastic Fastener Removed
Remove Lower Fastener
Pull out the two plastic rivet fasteners and set them aside in a safe place.
Pull Panel Away From Door
White Plastic Pop Rivets
Pull Off Sail Panel
Grab the door pull in the arm rest and tug it towards yourself to disengage the pop rivet friction fasteners that hold the panel to the door frame.Move to the top corner of the door panel and pry off the triangular "sail" panel. On some vehicles, the sail panel contains the tweeter speaker.
Lift Panel Off Door Lock
Pull Out Door Pull Cable
Lift the door panel off the door lock button and tilt the top of it out towards yourself.Use a pair of needle nose pliers to gently lift the metal ball at the end of the door opener cable out of the mechanism.
Disconnect the door cable from the back side of the door panel.
Door Pull Cable Removed
Disconnect Power Mirror
Then disconnect the power connector for the side view mirror by lifting up on the release tab. Slide the power connector off the plastic anchor on the metal door frame.
Slide Connector Off Anchor
Unlock Connector
Connector Detached
Look behind the door panel and locate the large wire connector with the pink lever lock. Swing the lever open to unlock the connector and separate it from the socket.
Door Panel Removed
Power Window Motor
10mm Bolts
Now the door panel can be completely removed by lifting it up and off the door frame.To replace the power window motor, remove the 10mm bolts.
Stock OEM Door Speaker
Remove 7mm *****
The stock "OEM" speaker is held in place by a single 7 mm *****. Remove it with a socket and ratcheting wrench.
Pry Off OEM Speaker
Speaker Removed
Disconnect Power Plug
If the speaker is stuck to the door frame, gently pry it off with a small flathead screwdriver.Disconnect the speaker's power plug by pressing the release tab with the small flathead screwdriver.
Fits 5.25", 6.5", 6.75"
Re-installing Door Panel
According to the Crutchfield website, the 2008 to 2012 Chevrolet Malibu's front door speakers can be replaced withaftermarket speakers in the following sizes: 5 1/4", 6 1/2" or 6 3/4" speakers with the use of a bracket.If you'd like to reduce road noise, make your car quieter and also improve the sound from your speakers, I'd recommend applying some Dynamat Sound Deadener on to the metal door frame.
Re-Attach To Anchor
Plug In Power Side View Mirror
Re-Insert Power Connector
To re-install the door panel, first hold the panel close to the door frame before re-connecting the large wire plug. Swing the pink lever closed to lock it in place.Slide the socket for the power side view mirror back on to its anchor and insert the power plug.
Lock Power Connector
Pink Lever Locked
Re-Insert Door Pull Cable Ball
Insert the metal ball at the end of the door opener cable back in to the door handle mechanism.Slide the black plastic cone part of the cable back into the slot in the door opener assembly.
Door Opener Cable Reinstalled
Hang Door Panel On Frame
Gently lower the door panel down on to the edge of the door frame with the door lock switch through the opening at the top.
Line Up White Plastic Fasteners
Push On Sail Panel
Push Door Panel In Place
Move to the bottom of the door panel and line up the white plastic pop rivet fasteners with the holes in the metal door frame.Push all around the door panel to re-insert the pop rivet fasteners.
Re-attach the sail panel at the top corner of the door frame.
Push Panel Flush Against Frame
Insert Side Edge Fasteners
Insert Larger Piece First
Next move to the side edge of the door panel and first re-insert the larger piece of the two fasteners. Then insert the smaller "pin" piece of the fastener into the middle of the larger piece.
Insert Small "Pin" Piece
Install Lower Edge Fastener
Tighten 2 T25 Torx Screws
Re-Attach Power Connector
Insert Front Hook First
Insert and tighten the two Torx T-25 screws located under the arm rest.Re-attach the power connector to the plastic arm rest panel.
First insert the hook at the front of the arm rest panel and then snap the rear end in place.
Pop Arm Rest Panel In Place
Tighten 2 T25 Screws
Replace Rubber Cover
Insert and tighten the two T25 Torx screws into the door pull cup. Then replace the rubber cover over the two screws.
Tighten 10mm Door Handle *****
Replace Door Handle Trim Plate
Malibu Door Panel Replaced
Replace the 10mm ***** that goes above and behind the door opener handle and tighten it. Pop in the plastic trim plate behind the door handle.
2answers
My glove box does not open. The glove box is stuck in the closed position,the handle did not break off,no plastic pieces broke off,the flap you lift up on has no tension
think like a thief... pry it open with some big flathead screwdrivers on each side of the latch
then, you can go from there and see if the handle/latch can be fixed
1helpful
How do I remove window door panel ?
By "window door panel" u mean driver and passenger doors to gain access to repair or replace window/window accessories or locking mechanisms or whatever the reason, removing any door panel requires these easy steps:
1. Search/unscrew all screws securing the panel. Theres usually one near the handle to open the door(plastic pc will need tip be removed from the handle), and one under the loop handle to pull the door closed.
2. If u have auto locks and windows, pull the panel of buttons up and unhook the wiring harness and put aside.
3. Using a flat edged tool(flathead screwdriver, small prybar, or butter knife will work), start to pry the panel from the door from the bottom up carefully so u don't break anything. *U now should've gained the access u were looking for
Instructions to replace door panel is as easy as the same directions in reverse, just be careful to inspect all pegs so tht none are missing or broken or will result in the panel being loose. Installing, u do have to carefully aline all pegs w/ corresponding holes on the door before firmly pushing panel bck on. Be sure to start from top down, top being the window strip on the top of the panel over the top of the doors window slot
1997 lincoln continental
Check the latch itself (on the door) is in the open position, ans didn't accidentally flip to the closed position. This has to be open so it can fit over the stud in the door jamb, where it flips over the stud to latch the door.
If so, while holding door handle (as if you were trying to open/unlatch door), flip latch open, with a finger or a screwdriver.
2helpful
The door handle of my Indesit WD10 washing machine has snapped off. I have wet clothes inside. How can I get the door open and my clothes out? It snapped the plastic where the door handle connects to the...
The same thing happened with my Indesit WD1. I now use a flathead screwdriver to open the door. There's a horizontal ****, about an inch high between the lever and the door (sorry, this is hard to describe). If you insert the screwdriver in the gap as far as it will go (at about a 45 degree angle to the door), then gently press the handle of the screwdriver towards the machine, you should feel the door release.
3helpful
Door panel removal for window switch repair
This is theinstruction on how to remove door panel of Toyota camry 1. Openthe door as wide as possible and roll the window up completely. Locate andremove five screws and two clips in the door panel. Two screws are located atthe rear of the panel, another two are located under the arm rest, one near thelight and the other in front of the light. The last screw is located in thefront of the arm rest behind a triangle shaped plastic panel, directly belowthe door handle. Pry this panel up with a flathead screwdriver to remove thescrew underneath. The two clips are near the front of the door and are smallplastic circles. Push them in with a small screw driver and pull them out. 2. Remove the plastic trim around the doorhandle. Use a flathead screwdriver or prying tool to pop the plastic out fromthe door panel. Wiggle it around until it comes loose from the door handle. 3. Use a flathead screwdriver or prying tool atthe bottom edge of the door. Pry away from the door until the clips under theedge pop out. These are plastic clips under the edge of the bottom and sides ofthe panel. Gently pop them out from the entire door panel. The top of the panelis held in place by the window trim. Move the panel back and forth until it isfree from the window trim. 4. Unclip the wire connectors and wires with aflathead screwdriver. The door panel is now free from the door.
2002 sienna right sliding door will not close
Hold the door handle in the open position while using a bent coat hanger on the door catch lever.Sometimes a flathead screwdriver works to pry the door catch as well. Good luck, keep me posted.
1helpful
2002 Silverado outside Door Handle
yes. you should remove the inside door panel.
to do this, remove all the screws you can see. One in the door handle, one by the mirror, then remove window crank/buttons
the take a flathead screwdriver and CAREFULLY pry the panel off. it is best to pry where the plastic pins are holding the panel on.
reverse procedure to reinstall.
Top Kwikset Locks & Locksmithing Experts
vince
john h
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
