Question about HP Pavilion Tx1110us Notebook
Motherboard needs replacement
My tx1110us is dead. When you press the power button, the lights go on and the screen flashes for a second and then it goes back off. Power supply and battery are working fine. I test the ram and they are okay. It used to overheat a lot. I think it's from the motherboard or graphic card. Either way the motherboard has to go. Can someone tell me from where to buy a new motherboard and how to install? (I'm not a complete moron when it comes to pcs). Thanks Rob.
  • weide_33 Mar 27, 2009
    i have the same problem with this hp pavilion tx 1110 us entertainment notebook pc. when i turn on the power button, all the lights were running but sad to say no display at all.
    is there any recourse to fix this problem? does hp company make something on this matter?
    or anyone else there knows how to fix it?
    thank you and more power..
    Problem Solver:
  • 10 Answers
Try to power up laptop when battery is taken of, if symptoms are the same try to replace CPU and keep battery of the laptop at all times, chenge power supply if this deos not help then possibly your motherboard need repairn. You can sent it to me to have a look, inspection is free. go to www.laptoplabs.net to find my address.
Posted on Jul 20, 2009
Hp pavilion ze1210 intermittently boots up or will not turn on at all.
ok it's a laptop., old.
let me guess 2003 made, square 4:5 screen
XP removed, (smart idea) Linux installed.
I guess the screen is 100% dead, not one pixel ever glows, right?
no text, ,no BIOS screens on demand, (esc key pressed, power on)
1: step 1 is always remove the main big battery. run now?
2: try external VGA screen yet, to see if the old internal screen is dead? see that VGA jack on the rear, and the hot function key that turns it on, bingo.?
(use a flash light to see if screen internal has data but the
CCFL back lamp is dead.?)
4: if bios is dead and both screens fail,what is next.?
19vdc from the power pack must reach the guts (MOBO)
if not all HP lap tops die. use a voltmeter or get a spare power pack
many power packs this old are now bad. 14 years old,
the can be good, bad, or weak. weak is bad.
5: sparks is a bad thing, in all cases, when heard it needs service.
BSOD:
http://pcdied.com/#black-screens
May 04, 2017 | HP Pavilion ze1210 Notebook
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Acer x3400 wont start up
Remove the Power Cord and then press and hold the power button for 30 seconds. After 30 seconds plug the power cord back in and press the power button. If it reboots you had a Static Charge Buildup and released it by holding the power button for 30 seconds.
When you press the power button do you hear the fan running, disk drives running, cd drive clicks once, anything on the lcd screen? If not I would think your Power Supply is bad and needs to be replaced.
It's either the Power Supply or Motherboard.
Mar 23, 2012 | Acer Aspire X3400 PC Desktop
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
My HP G60-230US Computer will not start. The computer is a little more than 2 years old. Every so often when I would start the computer it would say "No boot device found". I would restart the...
sounds like your motherboard malfunctioned. the board was probably starting to go out. thats why it would see the hdd then not.
you sound like youre familiar with computers. you may want to invest in diagnostic cards to troubleshoot problems like this. theyre fairly inexpensive on ebay. basically you insert the card into pci slot and it displays an error code. then you look up the code in a book. works like the obd2 reader for your car.
good luck
Feb 28, 2017 | HP G60-230US Notebook
My 1501 Dell Inspiron turns on but I have a blank black screen. The only light that shows is the power light on the upper right side of the laptop.
Power getting to the laptop. Try first to see if this will give a screen image on an external monitor, listen for the sound of the cpu fan, hard drive and DVD rom drives clicking, see if the DVD rom drive will open if pressed.
Then remove battery and AC adaptor, press the power button for 30 secs, refit mains only and try this on mains supply (no battery)
If this fails to boot, check the light on the ac adaptor is a steady green, flashing green indicates power is not fully reaching the laptop (motherboard problems)
If it is steady and the LED power light on the laptop is steady, suspect the DC jack socket. If this feels loose or sloppy, it will need replacing, depending on the type fitted, it may be soldered onto the board, or a wired connector, which sometimes goes bad.
After that, I'd suggest that a capacitor has gone on the actual motherboard and you will need to strip the laptop to check it.
Jul 18, 2011 | Dell Inspiron 1501 Notebook
Bios Faile
bios is always risky update, and toshiba is very well known to stuff up they bios...
first advice, never, ever, update bios from inside of your operating system...
as your computer is already dead, try this method, i cannot recall if you have phoenix or amibios but should work on both:
1. remove power and battery from dead laptop
2. download again bios and unfold it, remember the folder, do not run it!
3. go to this folder and find file with suffix *.rom, rename it to amiboot.rom
4. copy amiboot.rom to usb drive
5. plug usb drive into usb port
6. press and hold fn+b, plug in power cord and press power button
7. if after few seconds you see screen flashing and toshiba logo then returns, you just saved your laptop and few dollars...
8. allow it to boot, switch off, re-insert the battery and use as before.
if this do not work, i am afraid tha tyou need to find some toshiba centre which will flash and re-program bios for your. do not get conned into replacing motherboard! there are non-toshiba repairers which charge between $30 and $100 to flash "dead" bios, toshiba for replacement motherboard want over $300.00
if you find my advice helpful, plese do not hesitate to leave comment and vote 4 fo rme, thanx!
Aug 01, 2010 | Toshiba Satellite P205D-S8804 Laptop
Power light is flashing green. i hold the power button it turns red. i press it again it turns yellowish then solid gree the screen comes on the 3 second later screen goes blank and flashing green power
Sharp tv are famous for this problems.Take ur tv aparts,where the a/c power cord go into it.That ur tv power supply board,check for all those dead leakage capacitors parts that bulges up on it top or puff up on it top.Than it ur power supply board,replaced those dead leakages capicitors or replaced the whole power supply board.No leakage capcitors on the power supply board.Than it 100% the Tuner board it dead,this board is where the coalax broacast tv signal cable go into it.This board can't not be repair only replaced,because it alway some ICS it the problems it dead on this Tuner board.Tries websties like Shopjimmy.com,Ebay.com to buy either or both refurbishes the power supply board or the Tuner board.
May 26, 2010 | Sharp LC32D47UT 32 in TV
HPG6000 Power Problems
Your motherboard is dead. u need to replace your motherboard. if it was any hardware device problem it will stay on but will not show any display but the leds will stay longer than 10 seconds. i suggest you find a hp authorised service center and let them diagnose. i'm pretty sure your motherboard is dead.sorry to say man.good luck
Sep 20, 2009 | HP Compaq Presario F500 F700 and G6000...
Power goes off when power button is released
More than likely it is a dead motherboard
however....
you can try to reset the BIOS and see if that fixes it. To reset the BIOS, UNPLUG THE POWER CORD FROM YOUR COMPUTER (FAILURE TO DO SO MAY CAUSE A DEADLY SHOCK) open your computer. Discharge and body static by touching the side of the computer. Remove the BIOS/CMOS battery which looks like an oversized watch battery. Leave it our for 1-8 hours. Replace the battery and cloase your case. plug in the power cord and try to turn on teh computer. If this fails then you have a dead motherboard taht you have to replace
Jan 01, 2009 | E-Machines eMachines Desktop PC
HP Pavilion Tx1110us Notebook Logo
135 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
