Question about Proform Exercise & Fitness
How much AVR watts i need for proform 930i cooling breeze from 220v to 110v
SOURCE: mabe oven
Hi, well i have researched the mabe oven problem and it turns out that mabe used to make a 110V oven bake element for the ovens made in Mexico. However it appears that they no longer make that model oven and it's parts. Isn't that just golly gee terriffic!I am still searching for an element for it as GE who is also a share holder about 42% worth also has parts that sometimes will fit the Mabe made in Mexico, and not to be left out of the programe Camco is also part of the GE Mabe family so they are also a source to check with, and yes even whirlpool who is nothing to do with any of those other than a competitor sometimes has parts that will fit the Mabe made in Mexico. I'm not saying it will be a perfect fit but if it works, it works, but i'm not recomending you do it to a customers appliance at least not without asking if it's ok.
Posted on Feb 20, 2008
  • 3 Answers
SOURCE: Modifying the DC18RA from 110V to 220v
Hi there the solution for how to mod a DC18RA charger can be found here. The "how to" comes with pictures and descriptions and it should be easy to follow, and best of all it works :)
Posted on Nov 11, 2008
Bat1956
  • 585 Answers
SOURCE: change from 220v to 110v on air compressor
I can't blame you for askig, but here's my response. 5 HP is 3750 running watts. or about 35 amps at 110 volts and it would take somewhere around 50 amps to start it provided the motor could even be wired for 110 which I don't believe it can and for that exact reason. I'm sorry, but it's just not practical.
Posted on May 18, 2009
  • 145 Answers
SOURCE: 110V 6ohz - 220V 50hz
Kitchenaid mixers are not recommended on the use of a converter as they are not tested under such conditions. Understanding this, using a convertor on your mixer may automatically void the 1 year warranty regardless of age.
There are international Kitchenaid dealers available if you are requiring 110V. You may contacted Kitchenaid Customer Service for more information.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
freetek
  • 5568 Answers
SOURCE: I've the 325 watts its 110V kitchen aid and I
You will need a 'step-down' transformer with a rating of at least 500 watts (~500 VA), a primary designed for 220 Volts and a secondary rated at 110-115 Volts. This type will have four terminals or leads and isolates the input from the output.
There is a non-isolating type called an 'autotransformer' which has one winding with a tap (total of three terminals) roughly in the middle. I use this type for certain devices but it is not as safe as the first-described type.
If you are living in a foreign country that uses the ~220 Volt standard, you can sometimes get one on 'semipermanent' loan from the local utility.
Posted on Oct 07, 2009
I have an ELNA 3210 is 220v I live in Florida and need voltage transformer. from 220v to 110v for it and how many watts does it need? Thank you
From this document
http://edrenzi.com/Code/Trans%20(1p).pdf
the power is going to be the same as it was with 220V
However you need a step up transformer
if the supply voltage is 110V then the primary voltage needs to be 110V and the secondary voltage needs to be 220V dependant on your Elna needing 220V to run.
Does the ELna have a power rating plate at 220 V AC and if not does it have a current rating at 220V as power = voltage x current
so if it was 1 amp at 220v the power rating would be 220 Watts
When a transformer is involved the current on the primary coils of the transformer will half due to the 1:2 ratio of the transformer and will drag the same wattage as 220 V .
Another consideration is the frequency of the supply I am guessing the ELna is looking for 50 Hz and I think Florida will be on 60 Hz - not sure if this will be an issue in the ELNA but there are frequency adapters on the market to convert 60 hz to 50 hz if it is an issue.
You might be able to check the elna circuitry to see if it has a transformer inside it that you might be able to change to run at 110V down to whatever the elna runs on internally at its internal transformer secondary voltage.
Also check there is not a switch on the elna to switch from 220 v to 110v on the unit - not sure if it has this feature ?
Apr 18, 2018 | Audio Players & Recorders
I bought a rotary hammer drill from Asia 220V/60Hz & I want to use this in Canada 110V/60Hz Can I use Step down transformerconverter available in amazon or ebay?
Yes you can.
Make sure the transformer is rated for more power than the drill label states so that you don't burn up the transformer if you stick the drill bit.
For instance, if the drill is rated for 5 amps at 230 volts you should get a 1500 watt transformer. 230 x 5= 1150 watts; the next common size up is 1500 watts. You don't want an 1200 watt if it is available.
Transformers are also rated in KVA [Killovolt-amps] so the same transformer would be 1.5 KVA.
Do the math for your drill and save future problems. If a transformer doesn't have a rating with real numbers, avoid it. There are lots of really cheap ones on the market that you will regret buying.
Feb 07, 2015 | Bosch Drills
What to check if Wrong Electricity input is made
It's dependent on the extent of the damage; you may need to replace the electronic circuit board and/or the motor.
Can you described what happened when you turned on the treadmill while it was plugged into a 220v outlet?
What happens when you plug the treadmill into the 110v outlet?
Jul 09, 2014 | ProForm 690 LT Treadmill PFTL06009
How to change 110v to 220v on sonance cinema 260 subwoofer amplifier
I suggest contacting the manufacturer as there may be an internal "reconnect" that would allow 220v operation. Good luck!
May 21, 2014 | Audio Players & Recorders
HOW TO USE CUSINEART GRIDDLER WITH 110v TO 220v
Get a step down transformer/converter. Grill consumes 1500watts of energy. Converts cost 200 dollars here at sim lim tower/square. Make sure get the correct watts, it is very important.
Apr 06, 2014 | Cuisinart Microwave Ovens
Need a power transformer from 220v input to 120v output
Yes, you need a step down transformer. These are often rated in watts (the power rating is the same on both sides of a transformer) so it is easy enough to match this with the power consumption of the stereo. Apparently you will need about a 4kW transformer eg
http://www.220converters.com/store/p/45-Simran-THG4000-4000-W-Watts-Step-Down-Voltage-Converter-220v-to-110v-Transformer.html
Ugly things.
Jun 23, 2017 | Crest Audio CC5500 Amplifier
I want to buy a festoon light (10 lamps) to light my attic. It is advertised as 110V is it safe to pkug it in to my socket (UK)?
In esence the answer to the question is yes, but you need to take a few things into account.
Obviously, you are going to have to put a UK socket and 220v bulbs into the unit, but the main issue you need to be aware of is the capacity of the wiring in the unit to take the load in the UK. What you want to know is how many amps it used to draw when it was 110v and how many amps it will draw now. Clearly, a UK 13 amp plug will be man enough for almost any light unit (with the correct fuse fitted) but you would do well to ensure that you don't exceed the original planned load for the current, because the WIRING in the unit is the weakest link.
Working it out is fairly easy: Watts/Volts = Amps
So: When it was 110 volts, it maybe had 10x25 watt bulbs in it.
10 25 watt bulbs is 250 watts
250 watts divided by 110 volts means it was drawing about 2.3 amps, so set your limit as 2.3 amps load on the UK curcuit to ensure that the unti wiring can handle the load.
The easy way to fugure this when swapping lights from 110v to 220v is that if it was 110v, then you can use up to double the wattage on a 220v curcuit (and consequently, if you're going from 220 volt to 110 volt, then half the wattage.
Ensure that you use the Watts/Volts=Amps to calculate the correct fuse rating for the item
Sep 09, 2011 | Kitchen Ranges
Hi, Toroidal transformer in Sakura AV-200T input is 220v I need 110v Thanks
Hello shole135, Hi, you need a 110v to 220v step-up transformer with 200 watts power specification. you can visit your local hardware store and find one. Don't replace the toroidal transformer.
Dec 02, 2010 | Audio Players & Recorders
Exercise & Fitness Logo
21 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
