Question about Toshiba Satellite P35-S611 Notebook
How do i lower my ping speed from 720 to 300
I dont know where to find it on my laptop
    New Friend:
To lower your ping you would have to:A.) Move closer to the geographic location of the server that you are trying to reachB.) Turn off all other computers in the house.
C.) Close unnecessary programs using the internet such as programs that run on start up that you do not actually open such as a messenger (AIM).
To do this you will hit the start button (I am assuming you are on windows) then in the search field at the bottom type in msconfig.exe if you are using windows 7 or vista
Once the program is open click on the tab at the top that says "startup" and deselect those that you do not need.
Posted on Dec 12, 2012
  • 1,591 Answers
Your ping speed is determined by latency to the internet.To decrease your ping speed, you need a faster internet connection, OR you need to check your wireless.
If you are too far from the router, your speed from the laptop to the router may be too low. Try using an Ethernet cable direct to the router from the laptop. If your ping is still too high, then it's your internet speed. If it does go below 300, then you need a better wireless router, or you need to be closer to the router, or put in a repeater between you and the router.
  • Norman Skinner
    Norman Skinner Dec 12, 2012
    A router that has WDS will also work in place of a repeater. I use a TP-Link model TL-WR740N with the Wireless Distribution system enabled. This lets you use the wireless router you already have as it's WAN port, and you have your laptop connect to the TP-Link. This allows you to put the TP-Link somewhere between where you are and your wireless router, without any cables actually attached to it, operating basically as a wireless bridge / repeater. The end result is much better signal strength and speed to the laptop, and thus to the main router, and therefore to the internet itself.
1999 F-250 122000 miles. I'm getting a pinging sound when stepping on the gas at low speed.
Cheap gasoline, maybe , moisture in the fuel cell (gas tank) ,will also do it, heet gas treatment will take care of it, used as recommended.
Dec 31, 2016 | Ford F-250 Cars & Trucks
Just upgraded my internet speed. Went from a ping speed around 85ms to 800ms. Because the Ping speed is so High I can not play my 2 online game I get lag.look at the ISP but it did not say what to do.
You may have to configure your new router to pass gaming traffic with a priority over other traffic. Can't help you much more than that without knowing more.
Jul 23, 2016 | Computers & Internet
Intermintent pinging on accerlation
Intermintent pinging Bruce, Try a couple tanks of better grade fuel (premium) to see if pinging reduces/ or goes away.
Mar 29, 2016 | Cars & Trucks
Pinging when on the thottle.and a wineing noise from lower end
Beings you DIDN'T give a YEAR (so I don't know if it's a carb or injection), I can only give generalizations.
Pinging in internal combustion engines occurs when air/fuel mixture in the cylinder has been ignited by the spark plug and the smooth burning is interrupted by the unburned mixture in the combustion chamber exploding before the flame front can reach it. The engineered combusting process ceases, because of the explosion, before the optimum moment for the four-stroke cycle. The resulting shockwave reverberates in the combustion chamber, creating a characteristic metallic "pinging" sound, and pressures increase catastrophically.
Some of the possible causes:
The hotter your engine is, the more likely your engine is to ping. The farther your timing is advanced, the more likely your engine is to ping. The higher your compression ratio is, the more likely your engine is to ping. The lower the octane of gas you use, the more likely your engine is to ping.
As far as the whining noise, does it sound like a chain noise?
Again, the causes/fix depend on what YEAR your bike is.
Jan 24, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
My networking has very high ping. How to lower my ping.
As far as I know, there is no way you can lower your ping from your end.
Try to contact your ISP and tell them to disable your "INTERLEAVING".
Most likely they would not do that even if you talk to their supervisor and manager.
But if you're persistent and you have a good reason why you want your ping lowered maybe they will grant your request.
Keep me posted.
Jas
Feb 18, 2011 | Computers & Internet
PING PROBLEMS
Yes. Ping depends on the speed of your internet connection.
To improve your connection, try to disable any downloads that are running.
Jul 23, 2010 | Video Game Consoles & Games
Need a better ISP, cannot play Online Games as i get ping kicked for my ping being wayy to high and there no way for me o decrease it except find another ISP, need an ISP with a plan which is super...
OK, the first thing I need to know is What System Are You Running? (i.e.: Windows XP, XP Pro, Vista? also, Manufacturer & Model of your PC)
May 15, 2010 | Computers & Internet
Hello, I saw the article on the fix on the BEFSR41 and the blinking LED, and I was able to find the firmware and put it on 10MB speed, but when I ping the 198.168.1.1 it says destination host unreachable,...
if you have lowered the card speed and cannot ping the 192.168.1.1, have you set a static IP address on the computer, if so what was it? because if you have set a static IP of 192.168.1.xx and still cannot ping the router, this means that your router is already defective. you may want to contact linksys for replacement
Nov 23, 2008 | Linksys EtherFast Cable/DSL Router
IBM thinkpad T21
Bad cable, bad network configuration or bad motherboard, in that order.
Try manual settings for the wired connection, do a repair and see what the comment is.
good luck
Dec 23, 2007 | IBM ThinkPad T21 Notebook
Toshiba Satellite P35-S611 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
