Question about Coffee Makers & Espresso Machines
My tchibo machine has come up with an error message saying temp. Too low, and ten temp. Sensor? Any ideas please
    Genius:
  • Coffee Maker... Master
  • 1,669 Answers
The "SORRY NOT IN USE" gives me a hint that the heating coil is not getting power. It has to be powered to get the water up to temperature. There must be a fuse or button to press to put "MACHINE IN USE" on the screen.
Posted on Dec 31, 2012
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
I have a hdd error when I try to record on my jvc
that is a dew sensor message /mean warm up your cam room temp press eject and get an air dryer
and blow hot air inside for a few seconds ,do not set the dryer at high level /medium or low to avoid damage to the plastic or inside it if that does nt work
you got to replace the sensor in the camera.....
Feb 25, 2010 | JVC GZ-MG175 HDD Camcorder
Receiving E,2,7 Error messages. Can't clear. help please!
Canon support says reset machine by holding power button for one second until the display shuts off. Wait ten seconds, press power button - allow machine to completely turn back on. Otherwise, they say your printer may need repair.
(If holding the power button will not turn device off, you may unplug the power cord as an option).
Nov 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Frigidaire oven F-10 error
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
May 24, 2009 | Frigidaire FGB24S5A Gas Single Oven
Canon copier error message "error001"
"E000" Low fuser temp. (Heat lamp, thermoswitch, thermistor, SSR) "E001" High fuser temp. (Thermistor) "E002" Fuser temp. too low "E003" Fuser temp. too low "E004" SSR, Fuser temp too highchange thermistor in fuser
Aug 27, 2008 | Office Equipment & Supplies
Eror code on sharp copier AR-M276
UNRELATED PROBLEMS.
H4 = MAIN HEATER LAMP ABNORMAL LOW TEMP. THE FINAL UNIT BEFORE PAPER EXITS. HAS TO BE HOT. LAMP OR THERMO-FUSE? CHECK CONTINUITY LAMP WIRE IN THROUGH WHOLE PATH TO OTHER LAMP WIRE OUT.
E1-15 = IMC board Page Memory error/SRAM
error. MEMORY FULL? Mfr. says "Print Buffer Page Memory or Work SRAM abnormality"
SORRY NO MORE.
Jun 24, 2008 | Office Equipment & Supplies
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
Error message
Canon has a decent trouble shooting guide for this model: http://tinyurl.com/rgu6o Click on the Step-by-Step Troubleshooting link under Tech Support Unfortunately for this error code, all it says is this: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
Sep 14, 2006 | Canon Pixma MP500 All-In-One InkJet...
Coffee Makers & Espresso Machines Logo
157 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
