Ge front load washer wcxh208a1ww does not agitate or spin
It drains and the pump and drains are clean. The belt is still in good shape and motor/drum will spin freely by hand. The shocks look fine. There is clicking as the timer advances but the motor does not move at all. Have not performed diagnostic test since I dont have a tester. I did find the tech sheet though but will admit to feeling a little over my head when i read it. Are there any other ways to narrow down the potential problems?
4 Suggested Answers
  • 1894 Answers
SOURCE: My GE Washer won't Agitate or Spin
hello sir
Posted on Mar 09, 2008
  • 1294 Answers
SOURCE: Shocks broke, now drums spins freely
What you need to check thoroughly are the belt & the 2 shocks (dampers). The dampers should be replaced & fitted tightly, broader ends fitted below.
Posted on Mar 17, 2008
HansPP
  • 2510 Answers
SOURCE: my front loader fills with water, pumps and drains
Remove the back panel of the machine and operate it to check that the drive belts are being engaged to drive the drum. Observe the operation from a safe distance when you have the back off as there are live terminals within reach and you could be severely shocked if you come into contact with any one of them. Unplug the machine again before checking anything withing the workings.
Posted on May 21, 2011
Washer wont drain or spin. Thewasher will agitate.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 24, 2011 | GE WSM2480DWW Unitized Spacemaker Washer...
Model WJSE4150B2WW ser# AF171808G GE washer agitates but won't spin with front cover off motor turns belt in the right direction for just an instant and then stops interior basket can be turned...
When spinning the motor freezes up and will not spin. I released the motor and took off the belt off and the motor ran fine. However the pulley that the belt is also on will not spin the proper direction, only backwards.
Mar 03, 2011 | GE WJSE4150B Top Load Washer
Washer fills with water and drains but will not agitate or spin out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 26, 2010 | GE Profile WPRE6100G Top Load Washer
Washer does not spin but water goes out. Agitation does occur during wash cycle. Belt is in place and does move when pulled. When turning the agitator the tub moves. What would need replaced?
Motor will not turn the one way...
heatman101
Sep 19, 2010 | GE Spacemaker Washer and Dryer Electric...
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
My AEG Lavamat W 1000 runs properly but won't spin
a little late to solve your problem...if it ever happens again, change the 16 micro farrad capacitor in the upper rear right corner of the machine. This capacitor controls the starting torque in any motor mode
May 15, 2010 | AEG Lavamat W1450 Front Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Ge front load washer, 7 years old
speed control module faulty replace it .Close Ireland bye bye
Nov 22, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
