Question about Mitsubishi VS-5043 50" Rear Projection Television
The red disappears intermittently, the set emits a burning odor.
My guess is the Red CRT is leaking coolant and need to be replaced.
  • 3 Answers
I had that problem 2 years ago but I don't remember the odor. The solder connections came loose on the red tube's small pc board. The wifes make-up mirror came in handy to resolder the loose wires.
Posted on Apr 11, 2009
My tv has a red tint to it not sure what to do?
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 17, 2013 | Philips Televison & Video
Changed crt coolant, better picture. red squiggily line starting at top center of screen, runs about a third of the way down. thought i saw scratch or small crack in green crt "c" lens. would this cau
Sounds like you may have just left one of the wires loose from the red tube. Not likely an issue from the gren tube but you can always cover the top of the lens and let just green shine up. That may help narrow it down also.
Here is more detailed info for you also.....
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 17, 2013 | Philips 60P8341 60" Rear Projection...
I have to much red and to muchblue it turns in togreen
CRT coolant needs replacement. The red has become dominate due to the green coolant needing replacement. The blue will soon follow and red will be the only color that wont get affected. You can get the phillips CRT coolant kit from www.tvrepairworld.com the kit contains the coolant and the CD with instructions.
Oct 21, 2010 | Philips 55PW9363 55" Rear Projection...
There is too much red, even after I've restored the dealer settings. The color is very red.
Sounds like the CRT coolant needs replacement in the Blue and green CRts which will make the red CRT dominate.
Aug 21, 2010 | Philips Televison & Video
The colour of our sony tinitron color tv model no.kv-xf21m83 has got fading (Red colour disappeared )and the indicator flashes red a number of times between 3 second intervals and the est is sparking
hi
this sounds as if the tube (crt) as a intermittant short in the red gun , try tapping the neck of the tube very softly with a screw driver handle, this just might just clear the fault
regards windyhouse
Apr 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Getting red, blue and green halos around images
I had a similar problem with red halos around images on my Hitachi rear projection TV. The problem was that the red convergence chip burned out. I replaced that and that fixed the problem. I found several forum posts on similar symptoms and fixes for Sony rear projection TVs by searching for "Sony rear projection convergence problem." Likely you've already tried the auto-convergence function for your set, if it has that.
Feb 28, 2010 | Sony KP-46WT500 46" Rear Projection...
PIONEER ELITE PRO730HD 64in Red lens lower assmbly losing fluid
You'll need to replace the red CRT . The coolant chamber of the original tube has been compromised. Hopefully, none of the fluid( ethylene glycal) has leaked onto the main chassis of the TV.
Feb 10, 2009 | Televison & Video
Blue CRT issues?
Yes the puddle is related to the Blue CRT coolant leaking. You are most likely going to need a new Blue CRT drive circuit board and quite possibly a new Blue CRT if the CRT got too hot from not haveing a sufficent supply of coolant. You can get replacement CRT drives and CRts at the following link.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | Samsung HCL4715W 47" Rear Projection...
Oil low in red lamp
The substance is a clear antifreeze. The purpose is to keep the phosphors on the CRT cool so it wont burn. If the liquid was low, it means there is a seal or bladder leak somewhere. The tube needs to be removed and the leak can be patched with silicone rubber or the blader needs replacing.( check for cracks). Refill with coolant and re install. Use rubber gloves because the liquid coolant is hazardous to your health.
Nov 18, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
