Question about Epson Office Equipment & Supplies
Printer gets offline for alternate print commands automatically
Model FX2175 O/S Windows server 2003 Printer installed on USB (Thin client N computing L300)
SOURCE: Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Posted on Dec 03, 2008
SOURCE: Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Posted on Jan 28, 2009
ohms
  • 1879 Answers
SOURCE: tm-t88iv epson made prnter driver for win 2003 server r2 std
Epson POS driver will not install on a Win2K3 machine due to the InstallShield Wizard w/c checks if your running XP/2K or not.
Download the driver from EPSON POS site & extract the contents first on an XP machine.(Installing the driver will create a C:\Epson folder where ACTUAL driver is extracted).
Posted on Mar 06, 2009
kiio
  • 31 Answers
SOURCE: i have windows server 2003 i want to install hp5610 officejet pri
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
310
Posted on Mar 17, 2009
  • 256 Answers
SOURCE: Use Printer Offline: Error Processing Command
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Posted on Aug 17, 2011
Printer offline
You did not specify if printer was formerly working, the model # of the printer, or what version of Windows you are using. All this information is needed for successful troubleshooting. However, the below is general resolution for your problem:
"Offline" means your computer cannot "see" the printer as connected and powered on.
In order of things to try:
1. Turn printer OFF. Unplug USB cord from printer (or other end from computer). Wait at least 30 seconds. Plug USB cord back in. Turn printer back on. Does it still show as "offline" under Start --> Devices & Printers?
2. Try replacing the USB cord (yes, they can and do go bad).
3. Turn printer off. Unplug USB cord.
Under Windows Start --> Printers and Devices:
RIGHT click the Konica printer icon. Select "uninstall" (or "remove device") and follow through until printer is successfully UNinstalled. If there is other Konica software installed, remove it also (via Start --> Control Panel --> Add/Remove Programs -or- Programs & Features).
4. Reboot your computer. Follow manufacturer printer installation procedure, step-by-step (consult mfr website if you do not have a printed installation manual). Do not plug in USB cord or turn on printer until instructed to do so.
If all else fails:
Ignore any manufacturer installation instructions.
Do # 3 only above.
Reboot computer.
Plug in printer and connect it to computer.
Let Windows try to automatically install it (in most cases, Windows can install the "basic" print drivers, which are smaller and sometimes more stable than the fancy drivers and excess software the manufacturer wants you to install).
If still no go, you probably have a dying or dead printer. Consult manufacturer website for help.
Mar 07, 2014 | Konica Minolta Office Equipment & Supplies
Tip
Server 2003 & client configuration
<p><span>Some days before I have done a job on Windows Server 2003 Enterprise edition & Client XP. It is departmental food court. In the office room of the restaurant have a system which will be Server system and main domain. There was another 8 system in every department of food <span> </span>with printer for billing.I</SPAN><br> <p><span>Windows Server 2003 includes a mission critical Windows Server operating system, such as security, reliability, availability, and scalability.</SPAN><br> <p><span>You have to install DNS server for DC without DNS the client computers wouldn't know which one is DC.You can host DNS on a different server than DC.</SPAN><br> <p><span>Before Starting the DC installation process you need to make sure the <span> </SPAN>following points</SPAN><br> <p><span> </SPAN><br> <p><span>1)You have installed Basic windows server 2003 installation</SPAN><br> <p><span>2)Make sure you have assigned a static ip address to your server</SPAN><br> <p><span><span> </SPAN>Now start DC and DNS Setup process</SPAN><span></SPAN><br> <a><span> </SPAN></A> <span><span>Domain Controller</SPAN></SPAN><span></SPAN> <span>Active Directory is a huge topic in itself. While DCPROMO is easy to run, planning of both the physical and the logical structure is the key to a trouble free active directory. </SPAN> <p><span>Domain controllers do not have to be your most powerful machines, however they must be reliable and always available to answer logon requests. </SPAN><br> <a><span>DNS (Domain Name System)</SPAN></A><span><span> </SPAN></SPAN><span>Role</SPAN> <p><span>Once DNS is setup, it runs itself thanks to the new dynamic component hence DDNS. TCP/IP knowledge plus understanding of how DNS works is essential when troubleshooting connectivity problems.</SPAN><br> <p><span>DNS enables client machines to resolve servers IP addresses. Once the client finds the server, Active Directory uses LDAP to locate services like Kerberos, Global Catalog that clients request.</SPAN><br> <a><span>Print Server Role</SPAN></A><span></SPAN> <p><span>In my experience there is a contrast between the software settings which are easy to configure and the hardware which constantly need for attention e.g. paper jam, 'out of toner'. Check list for print server:</SPAN><br> <p><span></SPAN> <br> <p><span>Printer Priority</SPAN><br> <p><span>Network Printers</SPAN><br> <p><span></SPAN><br> <p><b><span>Client Configuration :- </SPAN></B><span>After</SPAN><span><span> Installation of Windows Xp give the IP Add on TCP/IP of IPV4.If you want to manually configure DNS server addresses, click</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Use the following DNS server addresses</SPAN></b><span><b><span>,</SPAN></B></SPAN><span><span> and then type the preferred DNS server and alternate DNS server IP addresses in the</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Preferred DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>and</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Alternate DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>boxes. After all job try to ping each other. I'm trying this and it also pinging. Files and data also can be shared through it.</SPAN></SPAN>
on Feb 15, 2011 | Computers & Internet
Zebra LP 2824 Plus Giving Endless Labels
OK where is the print spooler on the remote client or the server. Have you check whether this is clearing and not an issue with your remote setup and not the printer does the printer work correctly attached directly to the server break the problem down in stages
Dec 07, 2012 | Zebra LP 2824 Plus Thermal Label Printer
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
I have ncomputing L300 thin client with usb port. I attached Cannon Laserjet LBP2900 to thin client usb. also installed drivers on host. printer is detected & shows printer ready. but when i give...
Since you posted this four months ago, there has been some major updates from NComputing to improve the USB architecture. This should improve support for peripherals such as your printer. Download the latest software for either W2K3 (v4.9.5) or W2K8r2 (v6.1.3) and update your system. Lastly, it is critical, and I mean absolutely critical, that you update the firmware on the L300 as well. The firmware is included with the vSpace update so once the host is updated, go to the L300 and tell it to update the firmware. The current firmware version that works with v6.1.3 or v4.9.5 is v1.4.1. As of this writing, 8/16/11, those are the current versions.
Apr 21, 2011 | NComputing L230 Network Terminal
Hi, I have a hp t5325 thin client that uses a ica connection to connect to a windows 2003 server. I have to connect a usb printer into the front of the client and print from my session on the 2003...
wow and HPE enterprise question at FIXYA,
we are HP nor for SURE, HPE, enterprise, why not ask HP.
not only that , thin-net is a very complex topic.
sure ask HP
here they are, and their forum if FULL of questions just like that.
so you can read and learn what others did.
or just ask. there.
here we go to real HP, The REAL DEAL.
can I recommend getting an account there, its free.
the post to their forum???????
https://www.hpe.com/us/en/support.html
Nov 30, 2017 | HP t5325 Marvell ARM 12GHz Thin Client ...
Hi. I want to set up a server and run dumb terminals (thin clients) off of it. Can anyone give me a basic run-down about how I do that?
You would setup Windows Server. Windows Server 2003 and 2008 Small Business Server comes with a license of Terminal Services Server.
You would first need to setup your Windows Server. Install it according to at least minimum requirements.
Make sure you assign this server the correct role. If this is the primary server and if you intend on hosting dns and dhcp on this machine, then please make sure you are assigning this server these roles.
You will need to create user accounts so that you can log into from your thin clients.
Next you need to run the install for Terminal Server.
Next you need to configure each thin client.
Next try to access each thin client via Remote Desktop as well as the server.
This is the basic run down of the process. If you do not know how to setup a server then you will need to ask that question as this is very detailed. Also you will need to be more detailed in your question as to whether this is a linux based network or a windows based network.
Hope this helps. Please don't forget to give me a good rating as well as your vote.
Apr 02, 2010 | Network Computing Devices (NSH800S/A)...
To connect TVS MSP 345 Dot matrix printer with Laptop (Compaq) Usb port
Click here to open TVS-E support page, if the driver is not present on their website contact them at their toll free number.
alternatively you can download drivers below, after completing free subscription , following indication and chosing the free download to hard disk option.
download drivers here after completing a free subscription.
Nov 04, 2008 | Parallel USB Print Server 2 Port USB&1...
Unable to use printer over network with Server 2003 64Bit
Probably the best and easiest solution for your problem would be to buy an EDIMAX USB-Ethernet print server, or something equivalent. I have several of these running on the network at work. They're easy to setup and they work great.
Nov 11, 2007 | Konica Minolta magicolor 2430 DL Laser...
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
