Question about Lexmark P4350 All-In-One InkJet Printer
Error deleting problems
My lexmark x4550 is not printing, rather it is stuck. It occured on Monday January 12, when I trying to printer information from usconstitiution.net and it wouldn't print so I decided to cancel the print job and I got an error on obtaining the information. If you are wondering it was information on the 4th amendement and it was for my final exam in my debat. I have tried everything I could think of so far so I am posting this problem in order to get my x4550 printer/scanner/copier fixed because I am ready to scream.
  • mgoldstine Jan 13, 2009
    I tried that several time but it wouldn't work plus I unplugged the the printer and it still wouldn't clear
    Thanks for the solution. It worked.
  • 102 Answers
Press and hold the power button on the printer for 3 seconds to clear the printer memory.
Shut off the printer.
Restart your computer and see if the print Cue is cleared. (START---Printers and Faxes---select printer---)
If there's anything in this window highlight it and select cancel from the printer menu. When its cleared Restart you printer.
Also, sometimes when printing from a website it helps to select print preview first and print from there. I don't know why, but sometime this works better then a direct printout.
Posted on Jan 13, 2009
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Lexmark x4550 scan problem
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/g8G3VP. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 13, 2011 | Lexmark X4550 Multifunction Wireless Color...
Hi - my x4550 lexmark printer wont print, can you help?
If your printer won't print when you're making a copy using the Copy button on the operator panel, it could be due to your ink cartridges. Try to re-seat your ink cartridges into the printer and make sure they are properly seated.
If you're not able to print from your computer, it could be a communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
You may refer to this article for Wi-Fi connection issues: How to identify a Wireless Communication Problem and Resolution Tips
Aug 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
Lexmark X4550 not printing in Vista can't enable bi-directional
"Bi Directional Printing" is a statement of Parallel Port printing. Are you connected from your PC to the Printer via the parallel port?\
Did you disconnect the USB cable form the PC and then delete the current driver prior to installing the Win 7 driver?
Nov 18, 2009 | Lexmark X4550 Multifunction Wireless Color...
X4550 lexmark does not print to my mac osx
try reloading the driver and make sure it is compatible with your system
Aug 22, 2009 | Lexmark X4550 Multifunction Wireless Color...
Printing problem
To delete the file from printer cue, unplug printer, restart computer with printer unplugged, and delete file.
If it still does not work after deleting files, reinstall all printer software using software CD provided with the printer.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Sep 12, 2008 | Lexmark X4550 InkJet Printer
Printer (x4550) only prints last page of multipage document Sometimes will not print Microsoft word documents - they stay stuck in the queue. How do I get the latest driver for this printer?
  1. Go to the Lexmark Find Drivers/Product Selector page. Be patient, it's horribly slow and sometimes takes a while to load.
  2. Enter Lexmark X4550 under "Search by Model", and click the Search button.
  3. Select your OS from the dropdown (XP, Vista etc.).
  4. Click Download Now.
  5. If you're asked to Save or Run, choose to Run (it keeps you from having to go find the file and double-click it later).
Aug 06, 2008 | Lexmark Office Equipment & Supplies
Lexmark 5400 series all-in-one fax printer scanner copier
This is not so much a solution, but I have a lexmark 5400 printer -and I am also having problems with "alignment." I just replaced the cartridges an now I am getting an error message saying: "Alignment problem, remove tape from cartridges, check paper and then press the check-mark button." There does not appear to be anything wrong with the cartridges (there shouldn't be - they're new), but the cartridges will not center when the cover is lifted. So I can no longer print anything, and I can't check the cartridges - help!
Any information anyone can provide would be greatly appreciated. I'd hate to replace the printer, it's still in very good shape.
Thanks
Mar 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
106 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
