Question about Samsung Galaxy Tab II 10.1 3G 16GB P5100
After few days of use there is no power
There was no power. tried charging but no power
Hello I Have a Dirt DEVIL KONE Champagne in Color. Not the Kurve But the KONE. It was Working Fine The other day, But Is now NOT Powering On When I Try to Turn The Switch on at the Top. The Indicator...
Hi Ross, sorry for this delay, but the email does not seem to be working, I will get on this as soon as I can and will efinatly have something for you shortly, been one of those days and I am not catching up yet.
Dec 07, 2011 | Dirt Devil Kone Vacuum- Blue Vacuum
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
Eco-drive BT0054-59E not charging.
I know what the manual says, but I have found that sometimes it can take a few days to charge.
I set mine directly under a UV lamp for at least a day to charge. I have found the PULLing the STEM OUT and setting it under a lamp to charge works the best. Try for a couple days, one day stem out another stem in.
If it still does not charge it may need a new secondary battery.
Citizen offers a good warranty on that secondary battery/ power cell and if it's just a few years old they should replace it for free.
This really is not something you should try to fix yourself as the cells are easy to mess up.
Good luck.
Oct 23, 2009 | Watches
Laptop Battery Not Charging
first try in other power socket if it works then you have to replace the power adapter...
Feb 18, 2009 | IBM ThinkPad R50e Notebook
Charging problem
how long have you had the phone? usually the longer you have the phone the more it uses battery. the same with cameras, laptops, etc... my guess would be that the battery is going bad. ive had a few phones for just a few months and the battery would barely hold a charge for a day. so try getting a new battery and hopefully that will solve the problem :). also make sure there arent any games or programs constantly running on the phone as that can also drain the power pretty quick. hope this helps!
Nov 04, 2008 | Lands Phones
Battery appears charged, but computer will only run when plugged in
does your battery have one of those charge indicator panels on bottom?
also, it's possible that the connection from battery to the internals is shot..if that's the case, then you're looking at a major motherboard swap
May 15, 2008 | Lenovo 3000 V100 Notebook
G2 PowerShot Power Problem
When you're charging the camera, make sure the power switch is set to OFF. We've run into the same thing- we could plug it in for days, but it won't charge at all if the power switch is on.
Hope that helps.
Jan 09, 2008 | Canon PowerShot G2 Digital Camera
My phone can't connect to the headset!!!
I don't know if it is the same case as mine, but my H700 does not connect or work at all after a few days of non use. Battery discharges completely. It is odd but if I connect it to charger - it is lit red and starts charging again... So try to charge your H700 fully, then after a few days try to connect (knowing you gave it a full charge a few days ago)and see if will work. If not - connect to a charger. If light goes red - you got a battery problem just as me. Hope it helps at least a little bit.
May 04, 2007 | Motorola Mobility H700 Wireless Headset
Samsung Galaxy Tab II 10.1 3G 16GB P5100 Logo
23 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
