Question about Philips "32PFL3505D/F7 32-Inch LCD Hdtv, Black"
No power I connected my 110v tv from US to an Indian 220V supply and blew it.
  • Philips Master
  • 32,281 Answers
You have destroyed the TV. Most likely it would be cheaper to buy a new TV than to repair this TV.
You maybe able to get a quote to repair the TV before you decide whether to repair or to purchase a new TV.
Posted on Dec 12, 2012
  • unniswaran
    unniswaran Dec 12, 2012
    Actually, the fuse just blew off.. All I had to do is replace the fuse.
Machine was purchased in USA what is a power supply?
USA standard is 110v. You need a "power adapter" to transform your 220v to 110v. Most US purchased electronics do not have switchable voltage.
Nov 23, 2015 | Office Equipment & Supplies
What could happen with CD player switching on power supply 220v instead needed 110v?
Feeding it with twice the voltage it needs to work on?
In the best case, only a fuse has blown. Worst case? The whole power supply has had a to high voltage, before the fuse blew. All components will be aged and can give up in a few hours, after the fuse is replaced, or in a few months.
It also could be there are already some defect components in the player.
I wish you luck and hope only the fuse needs replacement.
May 25, 2014 | JVC Audio Players & Recorders
My Cerwin vega xls 15s doesn`t work!
Blown circuit. The question is; was it the power supply that blew out or was it the amp? check for fuses and see if they are ok. If they are not, replace them. IF they are then you are going to have to get new amp and or power supply.
Apr 26, 2013 | Cerwin Vega Audio Players & Recorders
What will happen if inserted the 110v input d-link wireless router power supply to a 220v outlet? does my router busted or just the power supply?
Most likely you have damaged not only the power supply but also the D-Link wireless router unless the power adapter is a multi-voltage power adapter. Check the label on the power adapter and if the input voltage is a fixed 110 volt power supply you are in trouble.
You can try getting a 110v power adapter and connect it into the D-Link and if it works then you are lucky.
Dec 29, 2012 | D-Link DIR-615 Wireless Router
A friend from US gave me hp netbook-1103135- is it 110 or 220v please advise thanks
It most likely has a 110V plug on the power supply; however, all you have to do is buy the appropriate 220v cable for the power supply for your country, and it should work fine on 220V.
External power supplies are designed to use either 110v or 220v -- all you have to do is change the cable or use an adapter and you're good to go.
Dec 20, 2010 | HP Computers & Internet
My system 110v mode i am connect 220v now not working my be what is the problem
your power supply is shorted.. make sure to connect your new power supply to the actual voltage .. 220V is for 220V input PSU.... if you connect your 110V PSU to 220V outlet... it will fry your power supply..
May 24, 2010 | Gigabyte GA-945GZM-S2 Motherboard
What is the wattage onroomba 560
The power supply isn't a transformer, its a switching power supply. The power supply is different for different locations, but you should not plug a 110V only power supply into a 220v source or vice-versa. You should contact iRobot if you wish to obtain the correct power supply for another location or to determine if they have an autosensing model that can sense and adapt to either 110v or 220v. You can also use a step down transformer to convert from 220v to 110v. The charger should be using 20W or less, but it will be pulling the current in narrow surges from the peaks of the voltage wave (aka a high 3rd harmomic current) and you will need to use a 40W or larger transformer to avoid unexpectedly overheating the transformer core.
Aug 25, 2009 | iRobot Roomba 560 Robotic Vacuum
Using dryer in 220V country
There are two systems in use in the states
110v dryers are available that fit a standard 11v 15a socket
110/220v fit the oversize 'dryer' sockets, and they are two 110v phases 90 degreees apart
the motor runs of a single phase 110v.
there is 220v between the 'outside', the active lines of the two phases, at any time, but it is not useable to provide mechanical power as a single service, due to the complicated shape of the wave form when you add out of phase voltages together, but is ok to drive the heaters, they have no mechanical efficiency requirement
A 2 phase 110v heater it means 3kw can be supplied without a 30 amp circuit
but it becomes difficult to use a single phase 220-240v transformer to provide 2x110v 90degree 2 phase current unless you specially buy one in. .
High power applications in 220-240v are generally supplied by 415v 3 phase 60deg supplies,
Any transformer would be onsellable at the end of your posting, to your replacement, who would doubtless be in the same boat as you, with a heap of 'stuff' that needs to run.
UK Aus NZ may be sources of transformers, or dryers to suit.
check with Australian UK NZ suppliers as well as local Indian ones, as those countries are also nominal 240v single phase home suplies and they may have (1) the dryer, or (2)the transformer to suit the 110 2 phase dryer
Sep 10, 2008 | Kenmore 62602 Electric Dryer
Philips "32PFL3505D/F7 32-Inch LCD Hdtv, Black" Logo
102 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
