Question about Stoves 600SiDOm Gas Kitchen Range
Stove won't turn off
    Sergeant:
  • 462 Answers
Defective switch most likely
Posted on Dec 12, 2012
Oven won't turn on because someone played with timer
Try turning the mains supply off and it will probably reset everything.
Feb 01, 2018 | Moffat Ovens
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Sometimes my gas stove won't turn on
The ignitor is going out on it. Even though you may see it glow, but the ignitor has to draw 3.2 amps to open the safety valve to allow gas to come into the machine
Jun 06, 2012 | Kenmore Kitchen Ranges
Maytag accellis 2x stove won't heat-up, does power-up, light comes on but no heat
Buy a new stove element. If you open the stove look in the back. It should be black. It might have a crack or be clearly broken. This is a cheap fix. If you want to be sure that it is working at the connection unplug the element and pull it out. Put a volt meter into the prongs. Turn stove on and see if its putting out voltage.
Jun 02, 2012 | Maytag Stove / Oven / Range Cooktop -...
I have a Whirlpool super capacity 465 gas oven that won't stay lit. It often lights up the first time just fine but then it turns off which is normal but when it tries to relight itself the ignitor...
That sound to me like yall have some carbon buildup on the igniter. On this stove the igniter does 2 jobs. It lights the burner and verifies back to the control that Houston we has ignition. If junk is built up on that ignitor then she won't be sending verification of ignition back to the control. That white residue needs to be removed. NOTE: I don't have your model number I am going by what you describe that this stove is a Direct spark ignition model. If you have a normal ignitor it probably is weak and not drawing 3.5 amps to open the valve. Post a model number (bottom drawer frame)
More Here
Sep 08, 2011 | Ovens
Gas oven won't turn on, stove top works fine.
check if the igniter is getting a 110 volt power if yes replace the igniter
Sep 05, 2011 | Kitchen Ranges
Just moved in, used stove for the first time, a little red light won't turn off.
You might need to turn off the stove entirely. If there is even one function slightly on, the red light may not turn off. Try unplugging the stove if you can't figure out why its not off still.
May 22, 2011 | Jenn-Air JED8345 Electric Cooktop
What are the install recommendations for the franklin stove model 98?
Best recommendation is - don't install it. This stove was manufactured originally by Martin Industries. They were a very good company. I did business with them for 10 years. However, they have been out of business for 5 years, now. In addition, that old a stove does not meet the current EPA, NFPA or Home Owners Insurance standards. It's efficiency rating is less than 60%. Although the stove may look new, in the end, it won't be what you expected. It was good in it's time, but now, depending on where you live, it can't be legally installed
One other word of caution. If you do decide to proceed with the installation, check with your Home Owners Insurance carrier, to see if they will cover a loss, as a result of a wood stove. Many won't.
Apr 20, 2011 | Heating & Cooling
Stoves 600SiDOm Gas Kitchen Range Logo
74 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
